  1. Nope it will leak out. You'll need the second step to seal. Caps are cheap and if you just break off the vacuum valve it holds no pressure but loses no coolant being it just pushed into the coolant reservoir.
  2. The biggest thing that made a huge improvement was the W-T ground wire mod. Ac ripple is now about 11mV AC. Since then I quit having alternator issues completely.
  3. Make sure to clean all rust and black oxidation off the terminals. If you want to never clean them again just keep them moist with engine oil. That's all.
  4. I vote for dirty terminals. Most likely would say it was during starting the engine and being it takes about 500 to 700 CCAto turn over. Being the connection was dirty and high resistance yup it will melt lead.
  5. Yeah even myself I'm also fighting the hard start in the mornings because of loss of prime in the fuel system. I'll admit when I did the head gasket last time I notices the crossover tubes and the injectors went in rather easy without much force. What I've done so far is change the crossover tube o-rings. I've just ordered a set of o-rings for the injector bodies. I ordered a second set for extras to have on hand for customer rigs. I just rolled Beast back into the shop and started doing an inspection of the head area for weeping and appears to be dry. I really need to roll the power washer out and give the engine a good washing down with degreaser from all the scattered oil and fluids. Get a bbetter picture of what is actually leaking or not. My morning starts have been long winded and rough starting. Lots of white smoke but once the lines are cleared it starts good all day long with no smoke or anything. Yeah I need to just put the wrench time on my own truck now.
  6. Might of needed just to loosen the line holders a bit and allow them to move into place better. Last set I got that was technically new but laying in the cab of a truck I had to assemble one at a time them place the holders back onto the lines. They lined up perfectly. Just because the lines are assembled doesn't mean they were placed right in the line holders.
  7. 0 to 3 is where you run the Quad. You can run higher but the wire tap is not present so no extra fuel is provided. 0 - Stock 1 - Valet mode 2 - Stock Fuel with timing 3 - CanBus Fuel with timing
  8. I'll jump in with you. I'm in the same problem right now with my own truck as well. After I did my head gasket the last time I notices that crossover tubes and the injectors went back in rather easy without much force. I'm betting my issues is just the o-rings. I just finished the o-rings on the crossover tubes. I just got off the phone with @dieselautopowerand ordered 2 sets of injector body o-rings. Now beyond that for things to look for is... Return banjo at the rear of the head. The sealing washers might be bad and leaking. Return tee at the rear of the engine with bad o-rings. Bad quick connect seals in supply or return at the rear of the engine. AirDog pump with quick connect leaking air in. You might try a bit of grease around the stem to see if it temporarily seals.
  9. No. Only as a band-aid fix for cracks or leaks. Even blown head gasket (coolant leaking out) as long as there is no pressure you could possibly get away with that band-aid for quite some time.
  10. Cut the vacuum valve off the radiator cap. No pressure means less of a leak. Now maybe epoxy would hold up as a patch.
  11. Ok that sounds good... I better go hungry for about 2 days first...
  12. Any line could break from vibrations. Only point I would make here is there any reason to invest double the amount of money on lines? Are you planning on dyno queen or 1/4 mile track truck? Then I would consider the expensive lines. For most daily drivers I would opt for the least expensive lines.
  13. Must be nice... Across the pond here in Idaho USA it can reach over 110*F (43*C) then fall as deep as -40*F (-40*C). Which I've seen both extremes here in the last 30 years of living in Idaho. I will admit I would love to just visit over there to understand and sample the lifestyle once. Hope it works out better this time.
  14. Wish it was an option for you. HID lighting was a huge improvement for me. I'm serious that it such a difference. No Hotspot. It's just smooth equal light cast over a wider area and vertically I can see tops of trees at 1/4 mile and cast light vertical over 50 feet up. Putting my old 1996 Dodge 1500 LED headlights beside the 2002 Dodge 2500 with HIDs. Hands down the HID won for lighting quality. I've tried... Stock headlights with quality halogens. (Bad quality) Sport Headlights with quality halogens and relay mod. (Bad quality) Clear lens headlights with LEDs. (Ok but poor pattern) Morimoto D2S lens retrofitted in Dodge clear lens (the best quality). As for driving lights I've done aircraft landing lights. (Good) Store brand driving lights (ok) PIAA LEDs Driving lights (best)
  15. Hang in there I'm sure there is a few people around that have installed this kit. Me personally, I've never had a need for it since I kept the geometry of the front axle in check from the start. The only thing I can suggest is Monday morning contact DOR and see if they can send the PDF file of the install to you.
  16. Not a problem I figured the technology actually started from back east I thought. But I guess not. It was a shot in the dark...
  17. LOL... You better come to Idaho there is very little for stations like this for trucking companies or even electric vehicles. Like Swift truckers come through here and 90% of them are dumb drivers that don't know better. Just think this way between Lewiston ID and Boise is 300 miles. No bad right? Now depending on the route you take you can add more in grades to climb or not. Either way a electric vehicle will not make the 300 mile drive now without running out because of grades. As for charging stations so far lot of listed charging stations are a misprint out here. Like Motel in New Meadows has a Tesla Charging station but... You must be a paid guest of the motel to use it. Then listing the RV park in Riggins, ID is not a charging station. Again look around Idaho and there is actually less charging stations for electric vehicles. Especially out here in the New Meadows - Riggins area.
  18. Only reason we can't reach these goals is because our own Gov't is constantly thinking of themselves and what they can do make themselves richer and us poorer. Space flights to the space station oh WoW! NOT! It is not like you can live there, make a living and go grocery shopping. I'm humble enough to say planet earth is my home I don't plan on leaving this planet for something better. Heck I've not explored most of the United States yet let alone the world. Just think your up in space and need to run to WalMart... Not happening.
  19. Doesn't surprise me at all.
  20. Finally getting around to doing repairs on my own stuff rather than everyone's else vehicles. The previous owner of Thor just hacked up the tail light wiring and made a huge mess out of it. So I went out and order a weather-tight 7 terminal bus bar box. That way all the hitch connectors and the tail light wiring have a place to be without just be hanging under the bed as a knot of butt splices. The interesting part of the 3rd Gen bodies and electrical it is way over wired for the rear. Basically, there are two sets of wiring trailer/tow is one set with solid colors like green, yellow and brown. Then the body electrical is white stripped something. Dodge managed to do everything backward for color typically yellow is left, but Dodge used white/green. After test lighting and going through a ton load of wiring diagrams and retesting again. I found the brown for marker light on the trailer is not working from the TIPM. The green and yellow for turn signals and brakes work fine. I high jacked the body marker light lead (white/tan) for the trailer. I've got to get some plugs for typical push-in light like the round markers on my flatbed. I'll get a photo here in a bit this morning when I head back down to my shop.
  21. Only other thought would be switch over to UK / EU HID lights. That would have the shutter cut off for the proper side. Like my HIDs in my truck have a step in the light pattern so the on coming traffic is chopped off a bit lower not to blind them but on my side of the road slightly higher path of light to aid in visibility for the driver. That would be my only other way I could see fixing that problem. Being any replacement reflector housing will be for left hand driver vehicles. Since HIDs don't use the reflector at all the shutter and lens would have to be EU / UK design for proper cut off.
  22. Like the Good Lord said, " Man can create nothing nor destroy any thing." This meaning that when you look at carbon on the planet the same amount is here and won't change. Kind of like hydrogen when burned it binds with oxygen so now it turns to water. Hydrogen can be separated back out of water with electricity. Sae amount of hydrogen just different forms of it. Back to carbon like oil is nothing more than long chains of carbon and hydrogen which binds with oxygen giving carbon monooxide and carbon dioxide. Carbon never destroyed but changed forms. Trees and planets convert that back to oxygen as well. Adding on... So how is the green new deal going to work? How are they going to mine all the lithium for car batteries? Since diesel fuel is supposed to be no longer used what is going to power all those big dump trucks hauling that out? Then lithium batteries are very toxic and burn rather well again the smoke from the batteries are toxic too. I don't hear power companies expanding and making more power plants. Who is going to pay for the power used to charge cars up? I'm still in a logging area up here in Idaho. I'd love to see how the whole electric-powered over-the-road truck works out pulling logs out the backcountry in the dead of winter. I wonder what gives the driver heat on an electric vehicle because no matter what it will cost the battery quite a bit to produce heat or A/C. Some day just my own travels I can lay down over 400 to 500 miles in a day. I've not seen any electric vehicle that can travel that far in one charge loaded to GVWR. There is going to be a huge impact on freight just think a FedEx truck that is hauling your Christmas present is electric-powered Opps... Only can do 180 to 250 miles on a charge then it will take HOURS to recharge before traveling another 180 to 250 miles. The entire electric vehicle thing is a sham. Just consider I've got to travel 180 miles to get to Boise, ID any electric vehicle would have to be parked at a charging station just to get back home again. My Cummins I can fill up and do 2 trips back and forth from Boise on a single tank of fuel. Remember I'm running 20+ MPG now. If I could hold 28 MPG every trip that would be 980 miles of travel on 35 gallons of fuel. Just food for thought. Now make thing more interesting that the democrats are now looking at pulling the dams off the snake river for the salmon population. Now that means less electricity for Idaho and we would have to buy more power from neighboring power providers. How is helping anything?
