  1. @dieselautopower @Quadzilla Power @Jthor I finally made the first step of meeting vendors for the first time. Happen that @Wet Vettewanted to catch up with her older daughter. Being I was only 30 miles from Layton UT I had to go meet Jacob Kidd in person. It only a 8 hour drive over to DAP from my home. Most would say this didn't happen unless there is photos right? Big shocker for most of you... Starting from the left, myself Mopar1973Man, Yup no more pony tail on me... Then Marco From Quadzilla and then to the right is Jacob Kidd. Just behind Jacob is Micthell all you can see him ducking and hiding. Other face to the far right I've already forgot the name. (shame on me) I still hard time keeping name and face right... Then under my arm is my new set of +50 HP injectors of my 2006 Dodge. @Wet Vette was trying get photos of the rest of the crew... Some were trying to hid from camera view but she managed to get them. But you looking at the call center area for DAP. I did get to go into the shop which I couldn't take any photos back there. I will say @dieselautopowerhas a awesome injector shop and crew back there. Jacob was showing me around how CR injectors are tested and scored. Some of the internal parts with in a injector. For a fair size shop they do handle all injectors in house for our Cummins trucks. Highly impressive injector shop. Then wondered out back to look in the warehouse. He's got other work stations out there for cleaning up cores and getting them inspected and ready for building again. Then wonder through rows of pallet racks full of new parts, some racks where full of cores (injectors and turbos). I'm really surprise even Jacob consider waste management for chemicals and cardboard. Most of his cardboard is ran through a shredder to turn it into a packing material for shipping again. Cleaning and testing fluids wise he's managed to keep waste to low levels too. Oh, yeah that friendly voice most of hear as we call DAP. Lexi (forgive me if the spelling is wrong) she right there to greet you as you come in the door. Really nice after all these years of calling and her asking what I needed then tell her its "Mopar1973Man" calling again. The crew here is super awesome all very dedicated to getting the job done and staying focused. All I can say is Diesel Auto Power is here to provide all the needed parts for our Cummins trucks... Even the Fords and Chevys too. Being I just bought @Jthor injectors through DAP for his 1995 Ford 7.3L diesel +50 HP injectors. Then just before leaving the exhaust brake came for a customer for a Duramax I've got to install. Give them a call they are here to help you... DIESEL AUTO POWER (801) 927-4600 QUADZILLA POWER (801) 872-5472
  2. Lower pop pressure more ADVANCED the timing. Hence why I went to 320 bar making it slightly RETARDED which now you can stack more timing. Starting at 13 and going up by plus 5... 13, 17, 22, 27... Start there. The 13 degrees will give awesome spool up being you popped low you could start at 12 and work up.
  3. Pull it out and inspect. Mine I caught before the contact finally quit. Yup got a RockAuto switch after looking up a NAPA price. I was getting random hit miss starts.
  4. Clutch safety switch is cheap through Rock auto. For info purpose still zero problems with Mobil 50 SAE Transmission Fluid still a very good option for heavy towing.
  5. Pop pressure of the injectors or dragging torque converter. Another member by @pepsi71ocean had the same problem found out the injectors were popped to low. Like my 7 x0.0085 injectors SAC had issues with stalling swapped back to VCO problem gone. Like my current injectors 7 x0.010 are popped at 320 bar with VCO nozzles.
  6. Nv4500 transmission 3.55 gears 245/75 R16 tires 66 MPH is exactly 2k RPM 82 MPH is exactly 2.5k RPM. Final to the ground is 3.69:1.
  7. Simple and main computers ground do not go to body metal in stock form. ECM, PCM, and VP44 are all on the passenger ground cable. After the W-T mod the computer will not be on the passenger battery but the gear near the VP44. All other subsystems ground to body metal. Like ABS grounds near the driver side headlight.
  8. Get some fluid from both the transmission and transfer case the one with glitter is the bad one.
  9. Actually it does still turn while unlocked. The shaft rotates slower but still it will turn. Does on my 1996 Dodge with CAD axle.
  10. Next time I see you @JAG1 I'll drop an manifold bolt in your intercooler.
  11. Don't have to do the other grounds because the W-T mod will relocate the grounds. That would be a waste of time cleaning up the old ground to relocate to a new place which will force you to create a new clean ground.
  12. My video is still around on the youtube channel. Just hang the whole assembly and pump hard and fast in on the slave cylinder and then slowly let it out. Slower the better that way you don't draw air back down from the reservoir.
  13. There was another member here with the exact same issue. DTT transmission with stalling. Everyone swore the torque converter was the problem. Nope. He had his injectors sent back to DAP and had then popped for 325 bar IIRC. The stalling issues STOPPED completely. The pop pressure was too low making the injection event too early and the engine could not recover quick enough so it stalls. After @pepsi71oceanupped the pop pressure his stalling quit. Might take ot him and ask him for more details of what he's done. Like my truck I had a set of +75 HP 7 x 0.0085 SAC injectors after a long run down the interstate and get to Boise my truck as a manual would stall coming to a stop again this set was popped to 305 bar. After have those swapped out and went back to VCO injectors and popped at 310 bar all was well again but the life span was a mere 75k miless and started to misfire after that. This when I built the 7 x 0.010 VCO injectors popped at 320 bar.
  14. Most pre-bled kits will cost you extra. Then there is roughly 1 and 10 chance that it work out of the box. So many times I've gotten pre-bled and have to pull the system back out and rebled the master and slave over again. The problem is with shipping and handling did any air travel back into the master? etc. The last one I got from Valair worked out of the box but late... I had to pump the pedal several times to work some small amount of air out. This is installed on the 2006 Dodge. I did one for Russ truck last winter and it was a prebled as well. PITA to get adjusted to prevent hyper-extending the throw bearing. If you do it will ruin the pressure plate fingers. Still got OE styled on my 2002 truck and manually bled every time no issues. 431k miles.
  15. I've never been a huge follower of oil studies. Typically the results go to the big brand names, AMSOil, RedLine, etc. There is other oil studies done here that people gone a long ways without big brand oil. Take to @cajflynn 1.3 Million miles and Never used any synthetic oils ever not to mention changed oil every 20k miles. Then there was @dorkweedthat ran over 84k miles on Walmart SuperTech Universal Diesel Oil 15w-40 and tested every 7k miles. Not to say the tested oils are bad but don't discount others. Seeing members running past 1 MILLION MILES mark and not using high dollar big brand oils is proof enough for me... Like @cajflynnjust Chevron Delo 15w-40 and Fleetguard filters nothing special. Like myself I'm either Chevron Delo or NAPA (Valvoline) for oil 15w-40 and NAPA filters right now.change interval of 10k typically. We've got another member here right at 950k miles now...
  16. Popped too low in pressure id your rising above 800 RPM at all. All Cummins ISB engine idle at 800 RPM. The only way to increase idle speed is to drop the pop pressure below 290 bar. Then to show the specs even Dodge FSM specs say 293 bar is bottom. Like my OEM stock injectors tested out at 260 bar at 120k miles. The idle was 850 RPM. Span plus or minus... 4500 - 250 = 4250 4500 + 250 = 4750 PSI to Bar 4500 PSI = 310 Bar stock 4250 PSI = 293 Bar 4750 PSI = 327 Bar Proper injectors should hover with +/- 10 RPM from 800 RPM. The engine load should be like 7% to 10%. Show you reversal. I'm 7 x 0.010 injectors (+150 HP) and popped at 320 bar. Cleaner, no smoke, slightly less flow but idles exactly 800 RPM +/- 5 RPM. Engine load when new was 13 to 14% this shows the VP44 working a bit harder to get pop pressure. Now with nearly 100k miles on the injectors I'm down to 6 to 7% engine load but rock solid at 800 RPM idle. NOTE: There is members that had injectors loose over -10 bar after running about 20k to 40k miles. If you popped too low near the lower margin then it will be a very short life of the injectors. Like shops popping for 300 bar only last like bare 50k to 75k miles and already popping too low.
  17. Your is done. Worn out... Should not be signs of rust and moisture which you have this master is cooked and no longer good. While you at is order a new clutch safety switch from RockAuto. Once your up around 400k miles that switch will die.
  18. What sized tires are you running and what is your axle ratio? This is what makes or breaks a good setup. You need optimally after tires and wheels 3.55 to 3.73 final ratio to the ground. I've got 3.55 gears but with the 245/75 R16 tires my final ratio is 3.69:1 to the ground. Then I'm not running a monster huge turbo but a Hybrid HX35/40 which is (60/60/12). Speed wise I'm at perfect 2,000 RPM at 66 MPH and then at 2,500 RPM I'm doing 82 MPH this is a good proper ratio. Let's say with NV4500 transmission I'm in 4th gear (1:1 direct) by 25 to 30 MPH. Most go up to 35 inch tires on 3.55 gear and now the final ratio is more like 3.27 to the ground and the truck struggles to make power. 37 inch tires on 3.55 is a perfect 3.00 to the ground. Anything with 35 to 37 inch tires REQUIRE 4.10 axle gears. No way around this fact. For every ONE pound of rotational mass you add to the tires, wheels, driveline is like adding another 8 pounds on the frame. Bigger tires will always consume more fuel to get spinning or excessive heat the brakes because of stored energy and stopping. Hence why my brakes last over 200k miles per set. Not to mention going down in tires size lighten them even more. Reduction of rotational mass. http://hpwizard.com/rotational-inertia.html So now you understand why I went down to 30 inch tire on 3.55 gear to enhance the torque output which it did, it reduced roughly 100*F off EGT's, it reduced my transmission temps by another 20 to 40 degrees, then improved towing MPG's 14 MPG towing my 31 foot travel trailer (Jayco).
  19. What is the engine load in park or neutral? What is your idle speed in park? What pop pressure were the injectors set to?
  20. Some version do have a relay and fuse. Then like the DDRP typically don't the plug directly into the ECM which when it does lock the motor up it burns up the ECM circuit. Typically the relay is mounted on the cowl (at least I do this)
  21. Yeah common for Raptors. The bearing and seal fail and pumps diesel into the motor then locks up and blows the fuse. Only solution is replacement... My 3rd Gen AirDog 150 died the same way. When you call for a new pump ask for the 4th gen pump the bearings and seal is upgraded.
  22. Are you getting fuel from a farm tank or similar? Really common out here the farm tank gather water and all kind of issues can come with it. Check with your local fuel station to see if they run water blocking filters on their pumps. I know my local Chevron does have water blocking filters. Check for air leaks as well. I just got done with @Jthorinjectors went down to the dump to ditch the trash in the bed. We had less than 1/4 tank and got up on the top of the pad short climb and it was lopey. Shut it down and looked around nothing leaking out or anything. Dump the trash went to start and it lost prime (long hard start). Ran home grab my wallet and dropped $40 in the front tank problem is gone. Idle fine every stop. So he's got a sucking air leak either on top with a rotten rubber hose or bad pickup in the tank.
  23. Just for info... From the part number book.
