Modern Power Point
Bring this back around. I need to do the power point down below now. I'm finding now that I've got @Wet Vettein my life we are constantly looking for one more port for charging phone. Then any passengers are without too. So I'm going to be ordering a standard 2 plug port WITHOUT volt meter. So far the first one has held up to some serious abuse and dead device but always charges fast and cool.
Drawstraw Users - How low can you go?
I just got busted for that in the 3rd gen section...
28 lbs. boost
Opps... Gotta pay attention. Need coffee yet... Still in all then swap the Quad for Smarty Touch. But the only problem its too complex for most people to even tune.
All sorts of problems w/quad download
With my High idle kit switch... Yes the only two ways of enabling the ECM high idle is Smarty tuner or the Dealer. The only way to turn it off is the dealer. No I don't... I've got my Quadzilla display up typically and see the IAT before even starting. If the IAT is even close to 32*F I will disable the Quadzilla. Then come spring again then I will turn on the Quadzilla being the temps are nowhere near 32*F on the IAT. ECM is always ENABLED and ARMED it the Quadzilla that I selectively turn off and on. Still in all the 3 CYL function is WAY FASTER than the Quadzilla high idle. Yes I've got both. I can only selectively turn on and off the Quadzilla. Period. The ECM high idle is always armed and no way to turn off. So any time the IAT is near 32*F then the Quadzilla high idle is turned off and use the ECM high idle. Yes you can just disable the Quadzilla for winter time and use the ECM high idle. Spring time return back to the Quadzilla. Been that way for the entire time I've owned the Quadzilla. I enabled my ECM high idle long long time ago and never turned it back off. ECM HIGH IDLE 6 CYL - IAT must be below 32*F with the grid heaters on. ECT must be below 140*F. 3 CYL - IAT must be below 15*F with the grid heater on. ECT must be below 140*F.. For me really soon I will be shutting down the Quadzilla high idle being the next week is going to be single digits. So bye bye to the Quadzilla high idle till spring. Notice both the delay and the warm up mode are both turned OFF! It will continue the rest of the winter with the ECM high idle now. I'll just use my high idle switch to control which mode I start with. Remember to set the switch on the mode before you start up.
28 lbs. boost
BD fueling box needs to go. Replace that... That turbo would be for about 150 to 200 HP injectors. Plus a Quadzilla then you might really light that turbo.
Happy Birthday - Fifty Years Old... Ugh!
Well the last two days I've been lazy and taking 2 days off. The last 5 weeks I've more or less worked everyday. If I wasn't turning wrenches I was doing home stuff. Wore out... Ive got a Jeep transmission to swap tomorrow. Fun...
Geez.. Happy times right? I've got to say at least I've got my health.
I know about the tow truck comment. Your good... As for fuel temp 160*F is high... Even my trip to Mohave Valley AZ this summer I towed the RV down there and had outside temperatures of 117*F and fuel temp only made it to a mere 145*F...
Rough idle
Coasting with the clutch in that is normal. ECM can see road speed and holds the idle up for that 1,100 to 1,200 RPM till the road speed drops near zero. TPS signal should not wonder when at idle. Nope that is correct the TPS value should drop to ZERO and stay there when idling. Shouldn't bounce or anything as long as your foot is off the pedal.
@Dieselfuture I would love to see your fuel temps in the VP44. No. I do what has to be done to get vehicles running and fixed. If I gotta barrow a trailer and haul it back I will.
Rough idle
Might consider getting it replaced. But yes you can try a reset... Most likely do nothing being the APPS reset only reset the min and max values of throttling but does nothing to set the IVS for idle.. It has ZERO to do with the IVS (Idle Validation Switches) inside the unit. Now the IVS is controlled by voltage in a stock APPS where a Timbo's APPS is based on position of the sensor. APPS reset will not change that fact. Most likely...
Best batteries for our trucks
Looking into it. Most likely a permission switch over looked.
Now that I found it again...
Part of why I made this post is to show that old school drawstraws can perform just fine if installed correctly. The other factor I'm finding is fuel temps on the old school drawstraws are typically lower than sender based straws which recycle the same hot fuel back to the injection pump. Then being able to drive long distances and no 1/4 tank pressure drops as fuel sloshes around. After all these year the AirDog is still holding a solid fuel pressures and no issues with old school draw straw. The biggest problem is people cutting the straw to short, cutting the end diagonal, etc. Even the sender based straws are typically hotter for fuel temps being fresh cool fuel is nowhere to be seen being same fuel is reused over and over.
Yes. You can measure voltage drop along the main power cable. Like I verified my ground cables and have a mere 3mV drop (0.003 volts) from end to end of both ground cables. Basically BLACK probe on NEG post then RED probe cable on clean metal of the block. Same can be done with positive cables. Again RED probe on the battery terminal and black probe at the next positive terminal it should never rise over 0.2 Volt under load. The article uses the starter to load the cable.
After 422k miles I'm on my 3rd Sending unit. I just changed the sender just a couple of months ago. I've never ran it below an half a tank while Mom was going back and forth. Now my last trip I barrowed a trailer and would you know it no lights on the trailer. I had magnetic lights but only the right flasher worked. I knew I had to run for home in the daylight. I didn't stop for food or fuel at all. Just kept driving and made it home by just dust. That what I had left after the trip to town to get fuel this morning. I'm also a 35 gallon tank but since my batteries went dead my gallon amount on the iQuad app was zero'ed out and didn't have accurate data to work with. Rather not chance the thought of running out of fuel when its subzero here. Walking would be a bad idea...
Would be nice... Just like Sunday did a rescue of a vehicle in Boise drove down and back with the car. I'm trying to get out of here and go to Boise for a bit of fun and time off. I've still got a ton load of work here at home. I could take off and head to the other shop and pull a transmission.
27.641 Gallons after hauling a car back on a trailer from Boise, ID did 14.76 MPG. Still solid fuel pressure and no issues, no pressure dropping while driving. Remember this is for old school DrawStraw users and not in the sender straws. Lets see how low you guys can go with your old school straws.
No joke... Wow!
Rough idle
TPS should show ZERO at IDLE. It should not wander up and down. This tells me the APPS is still in the throttling mode being is reading TPS signal. IDLE mode the IVS switch ground a second pin which tells the ECM to IGNORE the TPS and use on board idle software which typically the TPS value is ZERO.
At least in my position NAPA in McCall ID is a tourist trap town. It happens to have everything typically. But prices lately are higher, then Valley Co. added another 1% sales tax on top. (7% total sales tax). So by the time you start with $140 per battery and now double $280 for just the batteries. Now when you remember that there is only what 3 companies that manufacture batteries brand names don't amount to much any longer. When I saw the WalMart Batteries were 810 CCA and only $113 a piece and the last set made 4 dead cycles (zero volts) and then last 8 years... Yup I tried again. NAPA - $139 a piece - $278 (770 CCA) WalMart - $113 a piece - $226 (810 CCA) Yup Walmart won the price and CCA battle.
Just went back to Walmart and picked up a new set of 810 CCA batteries. My last set were ran dead at least 4 times and with my efforts made it to 8 years. This winter they gave up. REMEMBER: Stock is 750 CCA batteries.
All I can say is turn off the Quad high idle or turn off the ECM software. If you want the Quad which is only 6 CYL you'll need to turn off the ECM software at a dealer. Personally I kept the ECM software because 3CYL high idle is way faster to warm up cold engine. I only use the Quad during the summer and then use my high idle kit and my exhaust brake.
I'm officially old as dirt today. I've got to say Thank You to @Wet Vette, Jacob and Breck Thoreson for the awesome birthday present. They got me an Samsung Tab S4. Very impressive tablet. Been quietly setting this up so I can continue to do work on the road since my previous laptop blew up back in Jan, 2020. I'm taking the day off and doing absolutely nothing... So after this post I'm outta here... Chillin'
24 valve reman pump issues
Metering solenoid is physically on the injection pump in the middle of the distributor. Those two wires go back to the PSG on top of the VP44. This means there is a wiring or circuit problem between the PSG on the VP44 and the fuel solenoid in the middle of the distributor. The PSG senses this issue and returns the code P0252 back to the ECM to report for OBDII purpose. So yes the pump is dead... This is why I tell people to know where there pumps are being rebuilt. So where does XDP get there pumps from? Are they rebuilt by a Bosch Certified shop? If it is rebuilt properly that pump has to run on Bosch 815 test stand for 3 hours to verify and the flash the PSG with all the settings after the 3 hours of testing and calibrating. Non-Bosch rebuilder have been known to reused PSG's and not bench test at all...
