  1. Can the transfer case be just removed. Then split the case and reseal it? It looks like it sealed with silicone. Is it?
  2. 7 to 12 PSI during cranking is fine. Above 12 PSI and hard starts happen. What happens the ECM attempt to advance timing too quick so the lift pump pressure is reduced by cycling the power at 50% duty cycle so the pressure fall and the VP44 can advance timing till the RPM's come up.
  3. Yup that's about right. Being the fan has to sense the heat from the radiator to get the thermostatic coil to twist the clutch to lock up. If the Radiator is shedding heat then the fan will lock. If the thermostat is close or barely open the face of the radiator is rather cool to the touch not enough heat to lock. As long as the fan lock around 205 to 210 your good. That is the high normal mark on the gauge.
  4. Yes sir. There is a plastic bushing. Take note to the firewall if it moist with brake fluid just change the entire master.
  5. That's what so baffling to me. P-pump the make the ECM choke on errors, then attempt to get a TPS signal from the ECM to send to a PCM (Firepunk trans controller). Which it never does. Just gets rid of the VP44 injection pump... ECM and PCM still remain with buttload of errors to swim through now. Which may just limp mode both computers. (Unknown).
  6. Most likely master cylinder is worn out. There is a bushing in the rod too.
  7. Just remember Mopar does NOT produce any fan clutches just like they do not product thermostats. Nor does Cummins. I've seen plenty of people go down this road. Friend of mine in Ontario, OR just bought a Cummins thermostat for $60 bucks and it was junk. Seen the box and every thing. Again Cummins just buy whatever re-labels and sells under there name. Even Mopar does this. Just like Mopar sell Fram filter with Mopar logo. Right there is a Mopar Filter that is just a relabeled Fram.
  8. I'm not sure what to say. I've got no idea what is left of the stocking wiring. Can you read error codes?
  9. Yes. It does. Mirrors the same signal from the ECM.
  10. Kept yelling at the my truck to quit peeing in the shop. After 17 years you figure the truck would be house broke right?
  11. Fan does NOT lock till about 210 to 215*F. My truck runs 197*F to 205*F. Normal for my 195*F thermostat. About two needles width from the 190*F mark. Even my A/C temp rises in traffic and slow moving. Fan isn't locked and this totally normal.
  12. Not the UVs that kills the dash. Its the out right surface temperature that is cooking the oils out of the plastic. Then just takes vibration to crack the plastic.
  13. Doesn't matter. Its the thermostatic coil in the front that makes it lock or unlock. Housing doesn't mean anything.
  14. Yup. 208F to 212Fwhen mine locks the fan. Been like that for 17 years.
  15. Yup... Like myself I blew my PCM, broke the mainshaft in the transmission, blew up the driver side front wheel bearing. Forget the idea of spare parts...
  16. I just places an order for gauges for a gent in Ontario. @mr.obvious. Going to be installing ISSPro EV2 gauges (Boost, Pyro, and EGT). He's also running a intank fuel pump. We both know the fuel pressure is sub-par with a intank lift pump. As for dash you can extend the life of the plastic by using Armor-All. The trick is to wash the plastics all off and the spray the Armor-All on and leave it cook in the sun. It will change from whitish to clear shine. This keeps some of the oils in the plastic for a bit longer. Mine is cracking but I'm holding it at bay for now. Eventually I'll need to do a dash top replacement like @dripley has. As for the HVAC system I've replaced the evaporator and heater core once. Blend door is still fine. Then vacuum motors still working fine. A/C works good. The heater works awesome even in subzero.
  17. Not worth it. 17 years later I'm on the same ECM. You would have to send that spare in and have it reflashed with your software. There is 52 different version of software per year. You would be better off doing the W-T ground wire mod. Then doing the PCM protecting fuse. Way cheaper and no need to buy a second ECM and have it flashed.
  18. Typically I aim for about 35 PSI low side. The hi side should be about 225 PSI on a hot day.
  19. Could you fill out your signature so we know what we are working with exactly. Most likely the torque converter clutch is failing or the clutch packs in the transmission are done. Assuming 48RE... @Dynamic is a site transmission guru.
  20. Finally had to change a oil cooler gasket on my truck. It has been seeping for the last 5 to 6 months leaving a small bit of coolant on the floor of the garage. I will let you all know that oil cooler gasket set is a Cummins only thing. I tried NAPA, Autozone and few others and no one stocks this gasket set. As for changing it out is pretty straight forward. You need to remove the air filter and the oil filter. On the oil filter housing remove the oil hose for the turbo. Then the bolts holding the oil cooler in place are all 10mm heads. After I got it pull out I compared the new and old gasket to realize that the rubber seal lip had failed. You can see its completely missing on the old gasket. This is where my coolant leak was from. Most likely just old age. Filter side of the oil cooler. Coolant side of the oil cooler. These photos are without clean up. Just removed and photos taken. 17 years of tap water and creek water the block has 385k miles and no signs of scale build up at all. As for clean up. Sharpen my puddy knife and scraped off the old rubber seal. Be very careful that no debris get into the oil holes below. I used a bit of brake clean and cleaned up the outer housing. Oil cooler I buffed the sealing edge with a scotch brite pad in a drill. Very lightly to just smooth the seal surface again. I did an extra step and chased the threads on the bolts to clean them up going back in. They were kind of corroded from dried coolant and oil. I used a 8mm x 1.25 die. The sandwich gasket between the filter and the cooler came off super easy and peeled off clean. I will mention that it much easier to stack up all the parts and pass two bolts through and get that started. DO NOT use any sealants here! Just bolt it up. I check the Dodge FSM for torque specs and found nothing about the oil cooler for installation. I was aiming for about 15 foot pounds on these bolts. Make sure to pull the thermostat so you can refill the block with coolant. After you start the engine and let it run a bit make sure to check the oil level too. I dumped the oil filter out and ended up adding oil to be in the normal range again.
  21. @Auto Computer Specialist will test the ECm before even starting a repair and then notify you of what has failed as well.
  22. Yup. This is true. Still at this time its just little commuter cars. Still in all all the heavy duty stuff is handled by diesel engines. When I see trains running strictly electric then I'll worry. Still even today trains are diesel over electric motors. I don't think diesel engines are going anywhere. I still think at some point electric cars will fail. Because the US electricity grid is not capable of handling that kind of load. I've got a friend that has a family member in Cally with a electric car and pays MORE to recharge his electric car because of the price of electricity down in Cally is just scary high in price. Then if you use too many kilowatts then the price jumps again and nearly doubles. This just makes it better to own fossil fuel vehicle over electric. But even in Cally it $4.xx a gallon for either fuel.
  23. Time to tag @Dynamic he would know exactly what to do.
  24. Yup. I figure that exactly what it was. My stupidity... Now I check the BHAF every time I install it by hanging it downward and shaking a few times. Even doing that with oil filters now too. Also will not pre-fill any oil filter any longer. Too much risk of any debris being accidentally poured in the filter.
