Towing...Your Experience Is Appreciated 98.5 24V 2500
@Royal Squire very impressive tow there!
Egt’s
Just to see if I can come close or reproduce his issues. So what I did was created a fairly massive boost leak by pulling my wastegate hose and then pulled a bolt out of the manifold. This you can audibly hear blowing air still building 35 to 40 PSI of boost. Very little difference in smoke. EGT's really didn't change at all. Just drove over 50 miles plus climbing the grade from Riggins, ID to home. The results... Even with climbing a grade from Riggins, ID to home with the cruise set at 70 MPH (don't want a speeding ticket). I can say without a doubt his problem is more gearing than boost being even with a massive boost leak. EGT's are still controlled and nearly unchanged at a cruise state. You can audibly hear the boost air rushing from the two holes. No issues with EGT's. NOTE: -50*F for EGT's and +1 for Speed to be correct.
Isspro gauge programming
Enough for the shipping it back would be nice. Remember if I set the fuel pressure for 10 PSI it will trip the light at 9 PSI. So if you want the light at 10 PSI I've got to set for 11 PSI.
So many tow mirrors to choose from.
I would love to jump for the 3rd gen fold out mirror just don't want to give up the power options I've got now. Quite pricey yet.
Front Brakes
I'm curious. I'm also curious how quick the pads eat the rotors which ceramics pads tend to be harder than the rotors from the information I've gotten from others.
Not your average vp44 question
CCD Network the PCM is Master, ECM is secondary. CANBus the ECM only. No PCM data.
Sure, I've got the programming cable. https://mopar1973man.com/contact/ Send to that address and I can program it. Just remember to send a note with contact information and return address. If you have other gauges I can program them as well like EGT's.
Stacking tuners is a bad news period. You just turn the throttle into a light switch going from 0 to 100% in mere 1/3 throttle. Be better off upgrading to a full Edge Juice or Quadzilla. Both will give you a wider range of fuel control but Quadzilla is more controllable. The problem with stacking is there is only 0 to 4095 in CANBus signal stacking like I said just makes it reach 4095 quicker but will never exceed 4095. If you wanting more fuel or power you are going to have to consider wiretap this will extend the fuel even more. Either way, both Edge EZ and Smarty have to play by the ECM rules period and can't exceed that. Wiretap is where you break than limitation.
Like my 1996 Dodge Ram 1500 would be good one for the CAD lever mod. If you got the older series axles you can convert to manual pull cable for the axle. Like my 2002 is a solid axle so this is not possible. The vacuum CAD is a rather pain in the butt. Like 1996 Truck has always had issues with locking and unlocking the axle and also staying locked. Pull knob is a good solution for those issues.
Egt’s
Yup... I understand when someone mods out a truck with a lift kit and larger tires the chances of asking them to go back is near zero. This where the fun of figuring out other ways of reducing the EGT's and engine load. Being the lift and tires typically stay it a matter of reducing drag. I know better not to ask anyone to change out tires for someone that is lifted it's not happening. Being the fuel creates the heat, boost controls the heat. Side note and comparing... Yesterday a friend invited me to run out to Lost Valley Reservoir for hot dogs and just a fun afternoon. The only time I have seen EGT's above 1,000°F was climbing the grade from the highway at about 30 MPH which all the old muddy dirt road with potholes, ruts, and washboard would allow. But out on the open highway at 65-70 MPH (~2,000 RPMs) I was lucky to see 550-600°F at 2-3 PSI of boost. But I've only got a mere engine load of 15% to 17% on the flats of New Meadows. I wish I had a picture of the trail down to here it was a rough nasty mess.
Egt’s
I didn't see the boost as an issue being he stated he's reaching 30 PSI after adjustment. You can't gain boost if it's leaking right? So if he adjusted and gained about 10 PSI of boost and if it was leaking the gain wouldn't be there. Right? Engine load is fairly high. That is fuel being added. I'm trying to figure out what is adding so much fuel. Being he got huge gain in engine load (fueling). Being boost typically reduces EGT's with more boost right? Back to the fuel side what increasing the engine load?
Egt’s
I would for sure say YES boost leak if it was WOT operation for sure.
Egt’s
This is what I'm working with CRUISE state on the highway not WOT. Yeah. This is what I'm talking about. He's not WOT. This is a cruise state were the boost should be low. Using what I've seen out of my truck typically around 5 to 7 PSI at cruise state at highway speed. Being we both have the same setup injectors, turbo and Quadzila. I could understand boost leak more relevant when the OP mentions WOT operation and high EGT's. As I quote its cruise state. This is why I dismiss the turbo/boost issue. Not to meantion he increased the boost. The only thing else I could think of the extra load he's running is dumping the cruise timing and dropping out to performance timing on the Quad. If he's too retarded it will get hotter. Like I quoted. It CRUISE state not WOT. Boost should be low anyways.
Egt’s
No. Wrong. I realize how the tire does affect load and final ratio. You have to remember I work and lots and lots of truck driven all kind of truck with lifts and 35" and 37". Yes, it has an impact on EGTs. Now I understand people that do a lift are not going to give up heir larger tires or the lift kit this going to stay. Pure and simple. Now knowing that you create the inefficiency by bringing the final ratio back closer to what the engine was designed for which optimal 3.55 to 3.73 is a good range. 3.39 is too low of a ratio this adds to engine load. This is NOT a 4th gen truck, this is NOT a 4th gen transmission, this is NOT a 4th gen axle. I'm NOT asking the OP to swap to 245's. I'm asking him to change the axle gear to correct the final ratio to reduce engine load and EGT's. He can keep the tire just correct the final ratio. Very common issue on the 2nd Gen and larger tires. I've got one in McCall I just done a few years ago guy loves his truck now and EGT's are lower and MPG is higher. 37" inch tires with swapped 3.55 to 4.10 gears. Michael West in McCall. So since tires are going to remain. Gears a typically the solution. But like I said to test this theory only takes swapping tires for a simple test drive. The problem goes away then the tires was the cause was the problem. Not hard at all.
Smoke/vapor from vent tube.
I have seen a repair done another truck where the line got melt by the exhaust heat. I see what the owner did was using Air Brake line and was fairly impressed with the repair but gave me the idea of a full replacement with the air brake line.
Egt’s
Really? So, what's your theory in this?
Your welcome. I plan on doing that here soon too. I'm going to super different and not route like factory but get into the hollow of the fender and then tucked up on the cowl properly. I hate the factory route where it's in the middle of everything.
Egt’s
Not the turbo... The engine load and fuel usage that creates the EGT's heat because of excessive drag. More drag from the wheels and gearing means more fuel used to make it move. More fuel means more EGT's. Reduce the drag and EGT's fall pretty simple. As the OP posted... I'm down lower at 23% to 25% and 82 MPH which I've reduced the drag. Both 2nd Gen, but tires are much taller on OP tire vs. mine where the gearing now 3.39 to the ground for him vs 3.69 to the ground for me. EGT are a mostly drag in his case then the engine load is high side for holding cruise timing which will make it hotter, this makes the timing retarded and EGT's higher. He's running the same turbo technically as I am and the same injectors. This leaves all that out. What is different? Is final gearing and tire size. Now I'm comparing Apples to Apples. Him: 2nd Gen Me: 2nd Gen Him: 150 HP injectors Me: 150 HP injectors Him: Hx40 turbo Me: Hybrid HX35/40 turbo Him: Quadzilla Me: Quadzilla Him: 275 70 R18 3.39:1 final ratio Me: 245/75 R16 3.69:1 final ratio
Secret... I've not done this yet either but just get Air Brake Line it much stronger and holds up longer without cracking. Just use small pieces of rubber vacuum hose to join the ends.
Made it to 300k
Won't be long I'll be leaving the 300k family for 400k.
Egt’s
Might be true but not the same engine, not the same HP/TQ or not the same gears so it doesn't work on a 2nd Gen at all. Apples to oranges don't work.
Mechanical lift pump
Same with AirDog design also... Prefiler before the pump and then the main filter after the pump.
Tire pressure
If I had tire capacity weight at pressure amounts I could use my truck weights to finish out the math.
Vacuum discharge dumps right into the crankcase. The vacuum pump turns into an air compressor when there is a vacuum leak.
Tire pressure
Do it by weight...
