2000rpm max and no codes.
Most all NAPA stores have an alternator bench tester.
new radio yaaay!
I jumped in as well. Finally got cheap $39 China Made stereo that has bluetooth. It can play video files from micro SD card. Bluetooth music from your phone as well as picking up phone calls. Back up camera is included. I'm holding out on the camera for right now it just too cold to lay on the floor routing wires over a frozen frame full of ice and slush. Very small unit in size. No CD ability. Even comes with two remote controls. I'm going to try the steering wheel remote and see how it does. https://www.amazon.com/gp/product/B07BLVWWG4/ref=ppx_yo_dt_b_asin_title_o01__o00_s00?ie=UTF8&psc=1 I tend to have all my MP3 file on my phone already and get all my new music from MP3Juices.cc .
Autocomputerspecialist
Make sure you get ahold of @pepsi71ocean and give a review of this ECM/PCM provider. Need to keep a running tally of different shops and reviews. This helps other get good idea where to go.
Even stock setup with a fresh alternator would be in the 0.030 AC volt range or 30mv AC volts. To be 0.57mV AC I don't think is possible. This could be because its a low grade DVM and not capable of measure varying AC frequency.
This is why I suggested verifying with a bench test to make sure that its not just a "Cheap DVM" that can't measure odd frequencies.
Cruise, wiper solvent motor?
Depends. Automatic transmission - The Steering wheel controls are received by the Central Timer then past on down the CCD Network to the PCM. Where the PCM talks to the ABS module to get road speed and then controls a vacuum motor pulling the throttle. This is because the throttle valve on the transmission needs to sense throttle position. Manual Transmission - The Steering wheel controls are received by the Central Timer then past on down the CCD Network to the PCM. Where the PCM talks to the ABS module to get road speed and then controls the ECM directly. (Fly by wire). As for wipers it could be the multi-function switch in the column is worn out.
@Auto Computer Specialist is in Florida. I had to make sure to make my phone call before 2pm MST. I would call first thing in the morning. I've always gotten the receptionist in the morning hours.
Wait to start delay
Yea... Its a corrupt ECM if the WTS is lagging now. this is a sign its having trouble booting up and getting to the first command to light the WTS light.
Remember there based in Florida so be aware of time zones.
Dead tach, water temp & oil pressure?
Either P1698 or P1694 codes. One is PCM failure on the net. Then the other is ECM failure.
Go over the articles look up P1698 code and then look for the CCD network article. Then you'll want to test your alternator and do the W-T ground mod. As for CCD error double check the big connector in the PDC and the two connectors near the valve cover on the cowl.
3rd gen brake conversion on a dually
Better off with an exhaust brake. This set of brake pads are going to clear 200k miles. Not worth it still doesn't change the wear aspect upgrading to 3rd Gen brakes.
High Pitched "Cricket" Buzz
I've heard of intake gaskets blowing out and having the same sound too.
Suspension setup help
No track bar. No sway bar. Possibly will change once its all assembled and tires mounted.
Ham radio operators
I kind of wonder if the battery could hold up long enough. Say a night time operation. No solar. Vehicle is disabled or away from a vehicle with battery source.
Spare tire bumper mounted carrier
After all the pictures. I just sit back and wonder how much longer my factory OEM spare tire (Michelin) is going to last. It only been on the ground 3 times for less than 100 miles. Looks new. But the tire is over 17 years old now. Do I need a spare not really I so rarely use the one I've got.
24 v care and feeding
B2 biodiesel still beats petroleum diesel. Any bio should be in the 200's HFRR score.
Connector tube tool
Yes sir it did. Now to get time to test it.
Machine shop
@dripleyYou're just going to have to pull that head off and get the head rebuilt while its off. Then new gasket kit for the upper end of the engine.
@IBMobile you need the 2 cycle oil for those augers so you can bore holes in the ice up at the lake so you can go fishing. Or your chainsaw to cut a hole in the ice. Still need 2 cycle oil.
Searching for this emblem
I remember that back in the day. The member was making these with a lit up LED Cummins lettering. It was short lived and no longer produced as far as I know.
P0103 - Mass Air Flow Sensor "A" Circuit High
P0103 - Mass Air Flow Sensor "A" Circuit High Theory of Operation The Mass Air Flow (MAF) Sensor is a frequency based device. A constant voltage is applied to a heated wire. This wire is positioned in the air stream and is heated by the electrical current that the voltage produces. As air flows across it, it cools down. The heated wire or film is a Positive Temperature Coefficient (PTC) resistor, which means that the resistance of it drops when the temperature drops. The drop in resistance allows more current to flow through it in order to maintain the programmed temperature. The current flow is changed to a frequency, which is sent to the Powertrain Control Module (PCM) and interpreted as air flow. Adjustments for air temperature and humidity are taken into consideration, since they also affect the temperature of the heated wire or film. The engine running monitor compares an estimated fresh air flow value to the MAF Sensor reading. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the ignition on. Set Conditions: • The Powertrain Control Module (PCM) has detected the Mass Air Flow (MAF) Sensor value is above a calibrated threshold. Default Actions: • The MIL is illuminated. Possible Causes MAF SENSOR SIGNAL CIRCUIT SHORTED TO VOLTAGE MAF SENSOR RETURN CIRCUIT OPEN/HIGH RESISTANCE MASS AIR FLOW (MAF) SENSOR POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. ACTIVE DTC NOTE: The MAF Sensor, EGR Cooler Bypass Valve and Turbocharger Actuator get a 12V power supply from the PCM. 1. Ignition on, engine not running. 2. Record freeze frame data and clear DTCs. 3. Turn the ignition off for one minute. 4. Turn the ignition on. 5. With the scan tool, read DTCs. Did the DTC return? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (K157) MAF SENSOR SIGNAL CIRCUIT SHORT TO VOLTAGE 1. Turn the ignition off. 2. Disconnect the MAF Sensor harness connector. 3. Turn the ignition on. 4. Measure the voltage of the (K157) MAF Sensor Signal circuit in the MAF Sensor harness connector. Is the voltage equal to battery voltage? Yes • Repair the short to battery in the (K157) MAF Sensor Signal circuit. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 3 3. CHECK THE (K957) MAF SENSOR RETURN CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Turn the ignition off. 2. Disconnect the PCM C1 harness connector. 3. Measure the resistance of the (K957) MAF Sensor Return circuit between the MAF Sensor harness connector and the PCM C1 harness connector. Is the resistance below 5.0 Ohms? Yes • Go To 4 No • Repair the (K957) Mass Air Flow Sensor Return circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 4. CHECK THE MASS AIR FLOW SENSOR 1. Turn the ignition off. 2. Reconnect the PCM C1 harness connector. 3. Reconnect the MAF Sensor harness connector. 4. Turn the ignition on, engine not running. 5. With the scan tool, clear DTCs. 6. Disconnect the MAF Sensor harness connector and read DTCs. Does the scan tool display DTC P0102 as active? Yes • Replace the Mass Air Flow Sensor in accordance with the Service Information.(Refer to 14 - Fuel System/Fuel Injection, Diesel/SENSOR, Mass Airflow (MAF) /Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 5 5. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: • Proper connector installation. • Damaged connector locks. • Corrosion. • Other signs of water intrusion. • Weather seal damage (if equipped). • Bent terminals. • Overheating due to a poor connection (terminal may be discolored due to excessive current draw). • Terminals that have been pushed back into the connector cavity. • Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6. Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7. Reconnect all related component harness connectors. Be certain that all connectors are fully seated and the connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P0102 - Mass Air Flow Sensor "A" Circuit Low
P0102 - Mass Air Flow Sensor "A" Circuit Low Theory of Operation The Mass Air Flow (MAF) Sensor is a frequency based device. A constant voltage is applied to a heated wire. This wire is positioned in the air stream and is heated by the electrical current that the voltage produces. As air flows across it, it cools down. The heated wire or film is a Positive Temperature Coefficient (PTC) resistor, which means that the resistance of it drops when the temperature drops. The drop in resistance allows more current to flow through it in order to maintain the programmed temperature. The current flow is changed to a frequency, which is sent to the Powertrain Control Module (PCM) and interpreted as air flow. Adjustments for air temperature and humidity are taken into consideration, since they also affect the temperature of the heated wire or film. The engine running monitor compares an estimated fresh air flow value to the MAF Sensor reading. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the ignition on. Set Conditions: • The Powertrain Control Module (PCM) has detected the Mass Air Flow (MAF) Sensor value is below a calibrated threshold. Default Actions: • The MIL is illuminated. Possible Causes INTAKE OR EXHAUST SYSTEM LEAKING OR RESTRICTED MAF SENSOR SIGNAL CIRCUIT OPEN MAF SENSOR SIGNAL CIRCUIT SHORTED TO THE RETURN CIRCUIT MAF SENSOR SIGNAL CIRCUIT SHORTED TO GROUND MASS AIR FLOW (MAF) SENSOR POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. ACTIVE DTC 1. Ignition on, engine not running. 2. With the scan tool, erase DTCs. 3. Start the engine and let idle for at least two minutes. 4. With the scan tool, read DTCs. Did the DTC return? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (K188) MAF SUPPLY CIRCUIT 1. Turn the ignition off. 2. Disconnect the MAF harness connector. 3. Turn the ignition on, engine not running. NOTE: Check connectors - Clean/repair as necessary. 4. Measure the voltage of the (K188) MAF Supply circuit at the MAF Sensor harness connector. Is the voltage greater than 11.0 Volts? Yes • Go To 3 No • Repair the (K188) Mass Air Flow Supply circuit for an open or short to ground. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 3. CHECK FOR THE (K188) MAF SUPPLY CIRCUIT SHORTED TO THE (K957) RETURN CIRCUIT 1. Turn the ignition off. 2. Disconnect the PCM C1 harness connector. 3. Measure the resistance between the (K188) MAF Supply circuit and (K957) Return circuit at the MAF Sensor harness connector. Is the resistance below 10k Ohms? Yes • Repair the short between the (K188) Mass Air Flow Supply circuit and (K957) Return circuit. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. CHECK FOR THE (K157) MAF SENSOR SIGNAL CIRCUIT SHORTED TO THE (K916) RETURN CIRCUIT 1. Measure the resistance between the (K157) MAF Sensor Signal circuit and (K957) Return circuit at the MAF Sensor harness connector. Is the resistance below 10k Ohms? Yes • Repair the short between the (K157) MAF Sensor Signal Signal circuit and (K957) Return circuit. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 5 5. CHECK THE (K157) MAF SENSOR SIGNAL CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Measure the resistance of the (K157) MAF Sensor Signal circuit between the MAF Sensor harness connector and the PCM C1 harness connector. Is the resistance below 5.0 Ohms? Yes • Go To 6 No • Repair the (K157) MAF Sensor Signal circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 6. CHECK THE (K157) MAF SENSOR SIGNAL CIRCUIT FOR A SHORT TO GROUND 1. Measure the resistance between ground and the (K157) MAF Sensor Signal circuit at the Mass Air Flow Sensor harness connector. Is the resistance below 10k Ohms? Yes • Repair the (K157) MAF Sensor Signal circuit for a short to ground. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 7 7. CHECK THE INTAKE SYSTEM 1. Visually inspect the Intake System for any restrictions. 2. Perform the INTAKE AIR PRESSURE TEST diagnostic procedure. (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing) Were any leaks or restrictions found? Yes • Repair as necessary. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 8 8. CHECK THE EXHAUST SYSTEM 1. Visually inspect the Exhaust System for any restrictions. 2. Perform the CHECKING THE EXHAUST SYSTEM FOR LEAKS diagnostic procedure. (Refer to 29 - NonDTC Diagnostics/Drivability - Diesel - Diagnosis and Testing) Were any leaks or restrictions found? Yes • Repair as necessary. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 9 9. CHECK THE MASS AIR FLOW SENSOR 1. Replace the MAF Sensor in accordance with the Service Information.(Refer to 14 - Fuel System/Fuel Injection, Diesel/SENSOR, Mass Airflow (MAF) /Removal) 2. Reconnect the PCM C1 harness connector. 3. Turn the ignition on. 4. With the scan tool, erase DTCs. 5. Start the engine and allow it to idle for one minute. 6. With the scan tool, read DTCs. Does the DTC P0102 return? Yes • Go To 10. No • Test Complete. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 10. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: • Proper connector installation. • Damaged connector locks. • Corrosion. • Other signs of water intrusion. • Weather seal damage (if equipped). • Bent terminals. • Overheating due to a poor connection (terminal may be discolored due to excessive current draw). • Terminals that have been pushed back into the connector cavity. • Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6. Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7. Reconnect all related component harness connectors. Be certain that all connectors are fully seated and the connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P0101 - Mass Air Flow Sensor "A" Circuit Performance
P0101 - Mass Air Flow Sensor "A" Circuit Performance Theory of Operation The Mass Air Flow (MAF) Sensor is a frequency based device. A constant voltage is applied to a heated wire. This wire is positioned in the air stream and is heated by the electrical current that the voltage produces. As air flows across it, it cools down. The heated wire or film is a Positive Temperature Coefficient (PTC) resistor, which means that the resistance of it drops when the temperature drops. The drop in resistance allows more current to flow through it in order to maintain the programmed temperature. The current flow is changed to a frequency, which is sent to the Powertrain Control Module (PCM) and interpreted as air flow. Adjustments for air temperature and humidity are taken into consideration, since they also affect the temperature of the heated wire or film. The engine running monitor compares an estimated fresh air flow value to the MAF Sensor reading. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the Engine running. Set Conditions: • The Powertrain Control Module (PCM) has set the EGR flow equal to zero, but the Mass Air Flow sensor value does not equal the charge air flow estimate. Default Actions: • The MIL is illuminated. Possible Causes TURBOCHARGER, EGR OR INTAKE AIR SYSTEM RELATED DTCS MASS AIR FLOW (MAF) SENSOR AIR FILTER AIR INTAKE LEAK Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. ACTIVE DTC NOTE: If there are any other EGR, Turbocharger, or Intake system DTCs present, repair those DTCs before proceeding. 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Start the engine attempt to duplicate the conditions that set the DTC. 6. With the scan tool, read DTCs. Did the DTC reset? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE MAF SENSOR 1. Start the engine. Warm the engine up to operating temperature and then let it idle for five minutes. NOTE: This is how long it takes for the EGR Valve to close. 2. With the scan tool in Data Display, verify that the EGR Valve is at 0%. 3. With the scan tool, read the MAF Sensor value. Does the Mass Air Flow Sensor read from 3.0 - 6.75 lb/min for an auto transmission, or 3.5 - 7.5 lb/min for a manual transmission? Yes • Go To 3 No • Replace the Mass Air Flow Sensor in accordance with the Service Information.(Refer to 14 - Fuel System/Fuel Injection, Diesel/SENSOR, Mass Airflow (MAF) /Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 3. CHECK THE AIR FILTER 1. Remove lid from air filter box. 2. Remove air filter and inspect for excessive debris or filter media damage. 3. Make sure the filter was installed properly. Was the air filter damaged or full of debris? Yes • Replace the Air Filter in accordance with the Service Information..(Refer to 09 - Engine/Air Intake System/AIR CLEANER/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. CHECK THE MAF SENSOR 1. Turn the Ignition off. 2. Remove MAF sensor from the air filter box. Is it free from debris? Yes • Go To 5 No • Clean the Mass Air Flow Sensor using low pressure air and reinstall, repair complete. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Base Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 5. CHECK FOR AN AIR LEAK IN THE INTAKE SYSTEM 1. Perform the INTAKE AIR SYSTEM PRESSURE TEST procedure. (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing) . 2. Any leak between the air box to the intake manifold could cause this fault. Were there any Intake Air System leaks? Yes • Repair the leak in the Intake Air System. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure No • Replace the Mass Air Flow Sensor in accordance with the Service Information.(Refer to 14 - Fuel System/Fuel Injection, Diesel/SENSOR, Mass Airflow (MAF) /Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P0093 - Fuel System Leak Detected - Large Leak
P0093 - Fuel System Leak Detected - Large Leak Theory of Operation The Powertrain Control Module (PCM) determines that there is a leak in the Low Pressure Fuel Delivery system based on inputs from the High Pressure Fuel system, Fuel Tank Level Signal, Emissions systems, and other engine conditions. The PCM will turn on the MIL on after this diagnostic runs and fails for two consecutive drive cycles. This DTC will cause active regeneration to be disabled. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the engine running. Set Conditions: • The Powertrain Control Module (PCM) has detected a leak in the Low Pressure Fuel system. Default Actions: • The MIL is illuminated. Possible Causes PRESSURE LIMITING VALVE FUEL LEAK IN THE LOW PRESSURE FUEL DELIVERY SYSTEM POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). Diagnostic Test 1. OTHER DTCS 1. Turn the ignition on, engine not running. 2. With the scan tool, read DTCs. Are any other injector/fuel pressure related DTCs present? Yes • Diagnose and repair all other injectors/fuel pressure related DTCs before performing this diagnostic tree. No • Go To 2 2. ACTIVE DTC 1. With the scan tool, record all Freeze frame data. 2. With the scan tool, erase DTCs. 3. Turn the ignition off for 75 seconds. 4. Operate the engine until the coolant temperature is above 82.2°C (180°F). 5. With the scan tool, read DTCs. Did DTC P0093 reset? Yes • Go To 3 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 3. EXTERNAL FUEL LEAKS 1. Put on personal protective equipment. 2. Operate engine at idle when looking for fuel leaks. 3. Use the scan tool to operate engine at a variety of engine speeds. Any external leaks detected? Yes • Repair or replace component with external fuel leak. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. CHECK THE FUEL DELIVERY SYSTEM 1. (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing) and perform the CHECKING THE FUEL DELIVERY SYSTEM diagnostic procedure. Were any problems found? Yes • Repair as necessary. No • Go To 5 5. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: • Proper connector installation. • Damaged connector locks. • Corrosion. • Other signs of water intrusion. • Weather seal damage (if equipped). • Bent terminals. • Overheating due to a poor connection (terminal may be discolored due to excessive current draw). • Terminals that have been pushed back into the connector cavity. • Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6. Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7. Reconnect all related component harness connectors. Be certain that all connectors are fully seated andthe connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
