  1. Basically Edge products (Edge EZ, Edge Comp and Edge Juice) are a canned tune. The software is based on stock injectors. Larger injectors require a shorter amount of injection duration vs a stock injector. So all these canned tune boxes won't work with larger injectors cleanly. Now Quadzilla Adrenaline you can cut below stock rate. If you set at 100% fuel across the board that would be stock fuel. Like myself I'm running those 7 x 0.010 @ 320 bar injectors. Now Being the pop ressure is higher they are cleaner burning. Require slightly more fuel duration starting at 85% and working my way up to full 150% now. I've got my wire tap turned OFF. I'll come back to that soon. But I'm looking at getting the most MPG's from the injectors as I can. Being that they are popped at 320 bar I needed to RETARD timing. Yeap... Retard it about 3 degrees from what my past injectors need. Net result... Weather lows -9*F and highs +33*F for today. The very next MPG after the 15.5 MPG dip was the last run of the 7 x 0.0085 which the pop pressure was way off... MPG history. Cost per mile... 2 cents per mile cheap now even with larger injectors.
  2. That would help to list all active error codes this will at least point us in the right direction.
  3. Remember if you remove the VP44. This will not resolve all the electronics on the truck still. Still going to have an ECM that will be screaming codes. There will be still the PCM and other computers. P7100 pump will not remove these computers. P7100 pumping a fly by wire cruise will disable cruise control for your truck. No way to feed fuel data to missing VP44. Lose the dynamic timing of the Vp44 for static timing of the p-pump.
  4. Quickie on induction cooktops and the principals... Basically the high current flow there the cable is the magnetic field and the nut being the iron content. The magnetic field now heats the nut.
  5. Links are in my first post for what I used.
  6. I hate when I give it away that I'm not stock. Like sitting at a left turn light, snaps green make your left and roll into the throttle and the tires start smoking. Now either the race is on or they give up. Dang...
  7. Oh yeah, I know the feelling... Like myself, I've got my herbal way of relaxing... Work mode fading away...
  8. Same here but both of us have 4 inch exhaust where @Dieselfuture is running 5 inch exhaust and there is not enough room.
  9. Heated seats require the High Line CTM and it wiring loom. Power seats again require the circuit breaker (cab fuse panel) and the wiring loom.
  10. Explain more. Are you stabbing the throttle and getting hanging RPM?
  11. Yeah, @JAG1 keeps Chipmunking all my bolts into his intercooler pipe. I won't argue that statement. I've gotta be nuts to hang out with all you on the internet.
  12. I would pull it completely and inspect the shift fork and the sliding collar. In the case of my 1996 Dodge 1500 the vacuum motor had been struck by an object and then was bent enough that the vacuum motor have issues. (Binding issues). You might find the shift fork is worn or the shoes on the fork are worn.
  13. Hmmm... Seem like you got the infection too.
  14. There is a reason it took me 17 years to finally buy 150HP injectors. I been doing my own study work to make sure choices I make are going to be a working choice.
  15. I find these goofy photos and go ... Are people this dumb? Really?!?!
  16. Bingo. Just like I learned years ago. This what made it impossible to upgrade to larger injectors. Just like I said the Edge Products are designed for stock injectors. @dripley just confirms what I said about the larger injectors. It all based on the fuel map being too steep for any other injectors. This was the problem in the early years when people started upgrading but the tuners could work with oversized injectors. Like I'm learning about the larger injectors. Being the bigger injector nozzles can flow more fuel in a shorter time this focuses the fuel right in time. Instead of the smaller injectors that spread it over a long period of time because it flows much less. Then you crank up the rail pressure (either by CANBus or Wiretap) now you're making the injection event longer to flow the extra fuel on a small injector nozzle. This actually would reduce the stress on the VP44 on the pump section. If I idle with 13% engine load and to cruise at 60 MPH I'm barely 17% engine load.
  17. P007C - Charge Air Cooler Temperature Sensor Circuit Low Theory of Operation The Charge Air Cooler Temperature Sensor circuit is represented as the Intake Manifold Temperature Sensor circuit on the Cab and Chassis. On the Regular Cab it is still called the Charge Air Cooler Temperature Sensor circuit. In both configurations, this DTC refers to the circuit that runs from the Powertrain Control Module (PCM) C1 harness connector / terminal 62 to the Temperature/Pressure MAP sensor / terminal 3. The Powertrain Control Module (PCM) supplies 5-Volts to the Charge Air Cooler Temperature signal circuit. The PCM monitors the change in voltage caused by changes in the resistance of the sensor to determine the Charge Air Cooler temperature. The PCM will illuminate the Malfunction Indicator Lamp (MIL) after the diagnostic runs and fails in two consecutive drive cycles. During this time the customer may notice periods of white smoke as well as the fan running more often. The MIL lamp is turned off once the diagnostic runs and passes in four consecutive drive cycles. • When Monitored: The PCM monitors the change in signal voltage and converts this to a temperature value. • Set Condition: The CAC Outlet Temperature Sensor Signal circuit goes below a calibrated threshold. Possible Causes CAC OUTLET TEMPERATURE SENSOR SIGNAL CIRCUIT SHORTED TO GROUND CAC OUTLET TEMPERATURE SENSOR SIGNAL CIRCUIT OPEN/HIGH RESISTANCE TEMPERATURE/PRESSURE MAP SENSOR POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). Diagnostic Test 1. ACTIVE DTC 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Turn the ignition on. 6. With the scan tool, read DTCs. Did the DTC reset? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (K48) CAC OUTLET TEMPERATURE SENSOR SIGNAL CIRCUIT FOR A SHORT TO GROUND 1. 2. Turn the ignition off. 3. Disconnect the Temperature/Pressure Map Sensor harness connector. 4. Disconnect the PCM C1 harness connector. NOTE: Check connectors - Clean/repair as necessary. 5. Measure the resistance between ground and the (K48) CAC Outlet Temperature Sensor Signal circuit at the Temperature/Pressure MAP Sensor harness connector. Is the resistance above 5.0 Ohms? Yes • Go To 3 No • Repair the (K48) CAC Outlet Temperature Sensor Signal circuit for a short to ground. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 3. CHECK THE (K48) CAC OUTLET TEMPERATURE SENSOR SIGNAL CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Measure the resistance of the (K48) CAC Outlet Temperature Sensor Signal circuit between the Temperature/Pressure Map Sensor harness connector and the PCM C1 harness connector. Is the resistance below 5.0 Ohms? Yes • Go To 4 No • Repair the (K48) CAC Outlet Temperature Sensor Signal circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 4. TEMPERATURE/PRESSURE MAP SENSOR 1. Replace the Temperature/Pressure MAP Sensor.(Refer to 14 - Fuel System/Fuel Injection/SENSOR, TMAP-Intake Manifold/Removal) 2. Turn the ignition on. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Start the vehicle. It may be necessary to drive vehicle to reset DTC. 6. With the scan tool, read DTCs. Did the DTC return? Yes • Go To 5 No • Repair is complete. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 5. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: • Proper connector installation. • Damaged connector locks. • Corrosion. • Other signs of water intrusion. • Weather seal damage (if equipped). • Bent terminals. • Overheating due to a poor connection (terminal may be discolored due to excessive current draw). • Terminals that have been pushed back into the connector cavity. • Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6. Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7. Reconnect all related component harness connectors. Be certain that all connectors are fully seated and the connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
  18. P007B - Charge Air Cooler Temperature Sensor Circuit Performance Theory of Operation The Charge Air Cooler Temperature Sensor circuit is represented as the Intake Manifold Temperature Sensor circuit on the Cab and Chassis. On the Regular Cab it is still called the Charge Air Cooler Temperature Sensor circuit. In both configurations, this DTC refers to the circuit that runs from the Powertrain Control Module (PCM) C1 harness connector / terminal 62 to the Temperature/Pressure MAP sensor / terminal 3. The Powertrain Control Module (PCM) supplies 5-Volts to the Charge Air Cooler Temperature signal circuit. The PCM monitors the change in voltage caused by changes in the resistance of the sensor to determine the Charge Air Cooler temperature. The PCM will illuminate the Malfunction Indicator Lamp (MIL) after the diagnostic runs and fails in two consecutive drive cycles. During this time the customer may notice periods of white smoke as well as the fan running more often. The MIL lamp is turned off once the diagnostic runs and passes in four consecutive drive cycles. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the ignition on. Set Conditions: • The Powertrain Control Module (PCM) detects that at key on engine off, the Intake Manifold Temperature Sensor Signal reads differently than the EGR Orifice Temperature Sensor and Coolant Temperature Sensor. Or, while the engine is running the Powertrain Control Module (PCM) does not read a change in value on the Intake Manifold Temperature Sensor Signal over a pre-determined amount of time. Default Actions: • The MIL is illuminated. Possible Causes AIR CLEANER BOX NOT SEALING PROPERLY TO THE INLET AIR TUBE DIRT OR DEBRIS IN CHARGE AIR COOLING SYSTEM TEMPERATURE/PRESSURE MAP SENSOR Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. ACTIVE DTC NOTE: If there are any 5-Volt supply DTCs present, repair those DTCs before proceeding with this test. 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Turn the ignition on. 6. With the scan tool, read DTCs. Did the DTC return? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE AIR CLEANER BOX FOR PROPER SEALING 1. Check the connection between the Inlet Air Tube and the Air Cleaner Box to make sure that it is sealed properly. Is the Air Cleaner Box to Inlet Air Tube installed and sealed properly? Yes • Go To 3 No • Repair the connection between the Air Cleaner Box and the Inlet Air Tube. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 3. CHECK THE CHARGE AIR COOLER AND SYSTEM FOR DIRT OR DEBRIS 1. Remove the hoses at the Charge Air Cooler and Turbo outlet and inspect the system for signs of excessive oil, dirt or debris. Does the Charge Air Cooling system show signs of excessive dirt or debris? Yes • Clean the Charge Air Cooling system in accordance with the service information • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. CHECK THE TEMPERATURE/PRESSURE MAP SENSOR 1. Let engine cold soak up to eight hours. 2. Turn the ignition on. 3. With the scan tool, monitor Temperature/Pressure MAP Sensor, EGR Orifice Temperature Sensor and Coolant Temperature Sensor. NOTE: Make sure ambient air temperature is above -6.7°C (20°F) when performing this test. NOTE: Make sure there is no external heat source, such as a block heater, operating during this test or within the 8 hour cold soak. Does the CAC Temperature Sensor read differently from the other sensors? Yes • Replace the Temperature/Pressure MAP Sensor in accordance with the Service Information.(Refer to 14 - Fuel System/Fuel Injection/SENSOR, TMAP-Intake Manifold/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 5 5. TEMPERATURE/PRESSURE MAP SENSOR 1. Turn the ignition off. 2. Disconnect the Temperature/Pressure MAP Sensor harness connector. 3. Remove the Temperature/Pressure MAP Sensor and reconnect the wiring to the sensor. 4. Turn the ignition on. 5. With the scan tool in Sensors, monitor the Temperature/Pressure MAP Sensor while heating the sensor with an external heat source (DO NOT USE OPEN FLAME). Does the reading from the sensor increase at least 5°F on the scan tool? Yes • Go To 6 No • Replace the Temperature/Pressure MAP Sensor in accordance with the Service Information.(Refer to 14 - Fuel System/Fuel Injection/SENSOR, TMAP-Intake Manifold/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 6. POWERTRAIN CONTROL MODULE 1. Disconnect all PCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: • Proper connector installation. • Damaged connector locks. • Corrosion. • Other signs of water intrusion. • Weather seal damage (if equipped). • Bent terminals. • Overheating due to a poor connection (terminal may be discolored due to excessive current draw). • Terminals that have been pushed back into the connector cavity. • Perform a terminal drag test on each connector terminal to verify proper terminal tension. Repair any conditions that are found. 5. Reconnect all PCM harness connectors. Be certain that all harness connectors are fully seated and the connector locks are fully engaged. 6. Reconnect all in-line harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged. 7. Reconnect all related component harness connectors. Be certain that all connectors are fully seated and the connector locks are fully engaged. 8. With the scan tool, erase DTCs. 9. Using the recorded Freeze Frame and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 10. With the scan tool, read PCM DTCs. Did the DTC return? Yes • Replace the Powertrain Control Module (PCM) in accordance with the Service Information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Powertrain Control/Removal) . • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Test complete. • Perform the PCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
  19. Keep hunting there out there. Cummins started producing retro kit 4BT's for Jeeps and other small vehicles.
  20. Just consider CR engine owner ever 100k to 150k miles putting $4,000 worth of injectors in. $1,100 VP44 is nothing compared to a CR engine. Then VP44 are lasting 200k to 300k miles. DAP has a new revision of 028. Then it's less than a $1,000. https://www.dieselautopower.com/bosch-027-vp44-fuel-injection-pump-standard-output-235hp-wire-tap-voids-1-year-warranty-vp44027year
  21. No, not that I know of. The other problem is the calibration will be all out of wack most likely. This is why the Bosch 815 test stand is to run the pump for 3 hours and flash the PSG with calibration. Modifying the PSG or repairing with another transistor you are taking a risk. That is called a "Limited Pedal" typically that is an ECM problem caused by a bad alternator. Need to test the alternator for excessive AC noise. Then replace it if failing. Then you want to do both the W-T ground wire mods and my PCM protection mod. As for the ECM you want to contact @Auto Computer Specialist and have them test the ECM for you.
  22. Something to consider. Injector builders are typically building for maximum HP/TQ output. Doesn't mean that it going to be a good daily driver injector. Like myself now playing outside the normal realm and jump to the 7 x 0.010 @ 320 bar injectors it does change the playground a bunch. My flow rates are not as high as @Dieselfuture quoted me I'm actually reduced flow rate but clean burning they are for sure. MPG is still early in the game but looks promising.
  23. Same software just no extra toys like the screen, and extra settings like EGT etc. Edge Comp is just the simple version of the Edge Juice. Sent my OEM stock injector bodies in for new nozzles. Then specified the pop pressure I wanted. Might be true. Most here tend to use the VCO over SAC nozzles. SAC for some reason I had bad stalling problems and nasty lope issues. Now with the VCO nozzles and the current set up its lopes very mild and no stalling issues. The lope is only during coasting to stop with the clutch in. Only if you going to keep the Edge Juice. If you upgrade to the Quadzilla the smallest I would suggest is the 7 x 0.010 injectors (+150 HP). The 7 x 0.0085 were OK but you got to add quite a bit on the Quadzilla to make them work to the full potential. The 7 x 0.010 you actually cutting fuel back. Not having to stress the VP44 pump 150% more. My current max is 120% fuel (out of 150%). Wiretap is turned down to a minimum of 1,200us pulse (out of 2,200us pulse). Drop in level is going to be a drop in timing (not good). This was a huge problem I had with Edge Comp as well. The timing was good on level 5 but with bigger injectors, it got too smoky. Need to unbind the fuel and timing so the fuel goes down and timing goes up. The other problem is to control over when the cruise timing happens. Edge Products follow the ECM which is about 20% engine load. Above that, it drops the cruise timing advancement.
