ECM/PCM
@Auto Computer Specialist is one of the vendors here. You might want to look them up.
Diff Covers....................Interesting
Link, please.... I wanna see.
Days like today lots of snow
Weather is OK down here. Funny I made my 8.2 mile ride and just started to snow on me within about 1/4 mile from my truck.
Ontario, OR. Clean and clear. Snow line is about 2,500 feet and Ontario is just below that. Damn stupid people. Everyday dealing with a dumb driving along at 20 MPH in panic mode. Please people put you Toyota Prius away and get your 4WD your pickups out.
P0336 / ECM trouble beyond standard troubleshooting
Heck if your close enough come to my shop, ill break out the beer, and get it done. But you already this far along.
Gets better for me... Time to turn down the Quadzilla to Level 3 and keep the tires under the truck. From what I can see the snow goes from Pollock, ID to Weiser, ID and the roads are snow covered. It's going to be a long day for me.
No fuel pressure but Fass pump is working.
Edge Products and Quadzilla ZERO impact. All it does insert commands on the CANBus with high priority and has no impact on the ECM. ECM has no clue the tuner is even there. Now Smarty or any flash tuner puts stress on the EPROM which has a finite number of times it can be flashed. Then if the flash goes wrong you can make a mess out of the ECM that requires reflashing or replacement. Smarty and SuperChips wipe out all the ECM software and reflash with completely different software. Addon... Like my combo of the Quadzilla Adrenaline and the 7 x 0.010 injectors, this reduces the stress on the VP44. Being my idle engine load is about 13% and then my cruising 60 MPH engine load is only 17%. I'm not down to running Level 3 (No wiretap) which is the cleanest overall runs with the same power as stock injectors and Edge Comp with about 35 PSI of max boost.
Northwest Bombers
That also happened with ITD (Idaho turbo Diesels) they also had a Bomb party too and had guys attempting to steal tools, free work, and at dyno events attempting to get free dyno runs.
Quadzilla Adrenaline, Edge Products, no. They do not leave a footprint. Smarty is a possible footprint but they claim it undetectable.
@Alterego could I get you to write an article about the tone ring install? I'll make it worth your while.
DAP Injector Upgrade 7 x 0.010 @ 320 Bar
I think some good gains can be had with ecomony and smoke control with added pop pressure. I will admit the flow rate is reduced I'm pretty sure of that.
Northwest Bombers
I've a got a membership over there but wasn't fond of the members...
2000rpm max and no codes.
Get that alternator tested if it fails replace it.
No. Engine won't run without a tach signal. No. There is no way to fool the crank sensor. Naw... I'll drop a bolt in your manifold...
I would pull that alternator and have it bench tested to verify that its failed for sure. Then it would be time to look towards an alternator replacement. I would disconnect the field lead on the back and go for a test drive and see if the problem goes away. If not you might be looking at having that ECM verified being it might already be damaged from the AC noise.
Looks like the insert came out and rest got damage as it got slung off the crank. Make sure you index that gap section right.
P0087 - Fuel Rail Pressure Too Low
P0087 - Fuel Rail Pressure Too Low Special Tools: Click to display a list of tools used in this procedure When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the engine running. Set Conditions: • The Powertrain Control Module (PCM) detects that the actual fuel pressure reading is below a calibrated threshold. This DTC will cause active regeneration to be disabled. Default Actions: • The MIL is illuminated. Possible Causes P000F PRESENT EXTERNAL FUEL LEAKS GELLED FUEL NO VOLTAGE AT CHASSIS MOUNTED FUEL HEATER NO VOLTAGE AT ENGINE MOUNTED FUEL HEATER CHASSIS MOUNTED FUEL HEATER-FUEL FILTER ENGINE MOUNTED FUEL HEATER-FUEL FILTER HIGH PRESSURE PUMP INJECTOR LEAKAGE IN TANK LIFT PUMP FUEL PRESSURE LIMITING VALVE Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. P000F PRESENT 1. Ignition on, engine not running. 2. With the scan tool, read DTCs. Is DTC P000F active? Yes • Perform the Diagnostics for DTC P000F first. • If DTC P0087 is still active or pending after the P000F Diagnostics is completed, begin this Diagnostic Tree again. No • Go To 2 2. CHECK FOR OTHER DTCS 1. With the scan tool, read DTCs. Are any other injector/fuel pressure related DTCs present? Yes • Troubleshoot other injector/fuel pressure related DTCs first. No • Go To 3 3. CHECK FOR EXTERNAL FUEL LEAKS 1. Put on personal protective equipment. 2. Operate engine at idle when looking for fuel leaks. 3. Use the scan tool to operate engine at a variety of engine speeds. Any external leaks detected? Yes • Repair or replace component with external fuel leak. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. CHECK OPERATING CONDITIONS 1. Determine the environmental conditions at or near the time the DTC set. Has the vehicle been operated or cold soaked in ambient temperatures below freezing? Yes • Go To 5 No • Go To 7 5. CHECK FOR GELLED FUEL/PERFORM THE IN-TANK LIFT PUMP FLOW TEST NOTE: Before performing the IN-TANK FUEL LIFT PUMP FLOW test, verify that the fuel level in the fuel tank is above 1/4 full. If fuel tank is not above 1/4 full the pump will take in air causing the test results to be inaccurate. 1. Disconnect the low pressure fuel supply line from the High Pressure Fuel Pump. Connect the Decay Tool, Fuel 8978A to the low pressure fuel supply line. WARNING: To reduce the risk of fire and serious possible serious or fatal injury, place the Reservoir Assembly 534960 (3) on the floor and out of the way so that it is not a trip hazard. 2. Perform the following to purge air from the system: • With the scan tool, actuate the In-Tank Fuel Lift Pump Module. • Open the Flow Test Valve and allow the fuel to flow into the Reservoir for 10 seconds, then close the Flow Test Valve. • Turn the ignition off. • Disconnect, empty, and then reconnect the Reservoir Assembly. 3. Perform the following three times to find the average flow rate: • With the scan tool, actuate the In-Tank Fuel Lift Pump Module. • Open the Flow Test Valve (1) for 10 seconds, then close the Valve. • Turn the ignition off. • Measure and record the amount of fuel in the Reservoir Assembly. • Disconnect, empty, and then reconnect the Reservoir Assembly. 4. Add the three recorded measurements and then divide the total by three to calculate the average flow rate. NOTE: The flow rate specification is 500 ml in 10 seconds. Does the average flow rate meet or exceed the specification? Yes • If the vehicle exhibited symptoms related to fuel gelling such as hard start, start and stall, and/or low power, but no longer exhibits these symptoms, fuel gelling may have been present but corrected itself. The fuel temperature may have increased through normal operation or if the vehicle was parked inside a warm building. Verify both fuel heaters are receiving power with the ignition on, and also check for proper operation of the fuel heaters. (Refer to 14 - Fuel System/Fuel Delivery, 6.7L Diesel/HEATER, Fuel/Diagnosis and Testing) . • Then, Go To 7 No • Leave the Fuel Decay Tester installed. Remove both fuel filters and inspect for fuel gelling/wax build-up and other contaminants. If wax build-up is found, the fuel has gelled. Replace both fuel filters and correct the fuel gelling accordingly before any further testing. Verify both fuel heaters are receiving power with the ignition on, and also check for proper operation of the fuel heaters. (Refer to 14 - Fuel System/Fuel Delivery, 6.7L Diesel/HEATER, Fuel/Diagnosis and Testing) . • If no wax build-up or signs of fuel gelling is found, replace both Fuel Filter/Water Separators in accordance with the Service Information. • Then, Go To 6 6. RECHECK IN-TANK FUEL LIFT PUMP FLOW 1. Perform the following to purge air from the system: • With the scan tool, actuate the In-Tank Fuel Lift Pump Module. • Open the Flow Test Valve for 10 seconds, then close the Valve. • Turn the ignition off. • Disconnect, empty, and then reconnect the Reservoir Assembly. 2. Perform the following three times to find the average flow rate: • With the scan tool, actuate the In-Tank Fuel Lift Pump Module. • Open the Flow Test Valve for 10 seconds, then close the valve. • Turn the ignition off. • Measure and record the amount of fuel in the Reservoir Assembly. • Disconnect, empty, and then reconnect the Reservoir Assembly. 3. Add the three recorded measurements and then divide the total by three to calculate the average flow rate. NOTE: The flow rate specification is 500 ml in 10 seconds. Does the average flow rate meet or exceed the specification? Yes • Repair complete. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Use the wiring diagram as a guide to check the In-Tank Fuel Lift Pump wiring for an open, high resistance, or short to ground. If the In-Tank Fuel Lift Pump wiring is okay, remove the fuel tank and replace the In-Tank Fuel Lift Pump Module in accordance with the Service Information. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 7. CHECK THE FUEL DELIVERY SYSTEM 1. (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing) and perform the CHECKING THE FUEL DELIVERY SYSTEM diagnostic procedure. Were any problems found? Yes • Repair as necessary. No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P008A - Low Fuel Pressure Fuel System Pressure - Too Low
P008A - Low Fuel Pressure Fuel System Pressure - Too Low When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the engine running. Set Conditions: • The Powertrain Control Module (PCM) detects that the Low Pressure Fuel Delivery pressure is below a calibrated value for a calibrated amount of time. Default Actions: • The MIL is illuminated. Possible Causes HIGH PRESSURE FUEL DELIVERY LOW PRESSURE FUEL DELIVERY Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). Diagnostic Test 1. OTHER DTCS 1. Ignition on, engine not running. 2. With the scan tool, read DTCs. Are there any other DTCs related to Fuel Pressure? Yes • Perform the diagnostics for those DTCs before proceeding with this one. No • Go To 2 2. ACTIVE DTC 1. With the scan tool, record all Freeze frame data. 2. With the scan tool, erase DTCs. 3. Turn the ignition off for 75 seconds. 4. Turn the ignition on. 5. With the scan tool, read DTCs. Did DTC P008A reset? Yes • Go To 3 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 3. CHECK THE FUEL DELIVERY SYSTEM 1. (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing) and perform the CHECKING THE FUEL DELIVERY SYSTEM diagnostic procedure. Were any problems found? Yes • Repairs are complete. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P0073 - Ambient Air Temperature Sensor S
P0073 - Ambient Air Temperature Sensor Circuit High Theory of Operation The Ambient Air Temperature (AAT) Sensor is located in the driver's door mirror. The Driver's Door Module (DDM) receives the data from the AAT sensor and sends it to the Body Control Module (BCM). The BCM then passes the data on to the Powertrain Control Module (PCM). There are two rationality tests. The first test is: Ignition on/engine running. The second test is: After an eight hour cold soak, at key on the readings for the AAT, Charge Air Cooler (CAC) temperature (D2, DJ), Intake Manifold Temperature (DD, DP), and the Engine Coolant Temperature (ECT) Sensors are all compared. If the temperatures differ by more than a calibrated amount, then the appropriate sensor fault code would be recorded. The PCM rationality check looks at the temperature reading from the sensor over time and ensures that it changes with the engine running. If the sensor reading does not change over a calibrated time limit, the fault will be recorded. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the ignition on. Set Conditions: • The Powertrain Control Module (PCM) detects that the Ambient Air Temperature (AAT) Signal circuit value is above a calibrated threshold. Default Actions: • The MIL is illuminated. Possible Causes AAT SENSOR SIGNAL CIRCUIT OPEN/HIGH RESISTANCE AAT SENSOR SIGNAL CIRCUIT SHORTED TO VOLTAGE DRIVER MIRROR HEATER RETURN CIRCUIT OPEN/HIGH RESISTANCE AMBIENT AIR TEMPERATURE (AAT) SENSOR Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). Diagnostic Test 1. ACTIVE DTC NOTE: There is no direct circuit input from the Ambient Air Temperature Sensor to the PCM. If there are any Loss of Communication DTCs related to the DDM present in the Body Control Module or elsewhere, perform those diagnostics before continuing with this diagnostic tree. NOTE: If there are any other DTCs related to the Ambient Air Temperature Sensor present in the BCM, DDM, or any other module, perform those diagnostics before continuing with this diagnostic tree. 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Turn the ignition on. 6. With the scan tool, read DTCs. Did DTC P073 reset? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (G31) AAT SIGNAL CIRCUIT FOR A SHORT TO VOLTAGE 1. Disconnect the AAT Sensor harness connector. 2. Measure the voltage of the (G31) AAT Signal circuit at the AAT Sensor harness connector. NOTE: The voltage should read approximately 5.0 Volts with connector disconnected and key on. Is the voltage above 5.2 Volts? Yes • Repair the (G31) Ambient Air Temperature Signal circuit for a short to voltage. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 3 3. CHECK THE (G31) AAT SIGNAL CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Disconnect the DDM harness connector. 2. Measure the resistance of the (G31) AAT Signal circuit between the AAT Sensor harness connector and the DDM harness connector. Is the resistance below 5.0 Ohms? Yes • Go To 4 No • Repair the (G31) Ambient Air Temperature Signal circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 4. CHECK THE (C160) DRIVER MIRROR HEATER RETURN CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. 2. Measure the resistance of the (C160) Driver Mirror Heater Return circuit between the ECT Sensor harness connector and the PCM C1 harness connector. Is the resistance below 5.0 Ohms? Yes • Replace the Ambient Air Temperature Sensor in accordance with the Service Information.(Refer to 24 - Heating and Air Conditioning/Controls/SENSOR, Ambient Temperature/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Repair the (C160) Driver Mirror Heater Return circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P0072 - Ambient Air Temperature Sensor Circuit Low
P0072 - Ambient Air Temperature Sensor Circuit Low Theory of Operation The Ambient Air Temperature (AAT) Sensor is located in the driver's door mirror. The Driver's Door Module (DDM) receives the data from the AAT sensor and sends it to the Body Control Module (BCM). The BCM then passes the data on to the Powertrain Control Module (PCM). There are two rationality tests. The first test is: Ignition on/engine running. The second test is: After an eight hour cold soak, at key on the readings for the AAT, Charge Air Cooler (CAC) temperature (D2, DJ), Intake Manifold Temperature (DD, DP), and the Engine Coolant Temperature (ECT) Sensors are all compared. If the temperatures differ by more than a calibrated amount, then the appropriate sensor fault code would be recorded. The PCM rationality check looks at the temperature reading from the sensor over time and ensures that it changes with the engine running. If the sensor reading does not change over a calibrated time limit, the fault will be recorded. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the ignition on. Set Conditions: • The Powertrain Control Module (PCM) detects that the Ambient Air Temperature (AAT) Signal circuit has fallen below a calibrated threshold. Default Actions: • The MIL is illuminated. Possible Causes AAT SENSOR SIGNAL CIRCUIT SHORTED TO GROUND AAT SENSOR SIGNAL CIRCUIT SHORTED TO DRIVER MIRROR HEATER RETURN CIRCUIT AMBIENT AIR TEMPERATURE (AAT) SENSOR Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). Diagnostic Test 1. ACTIVE DTC NOTE: There is no direct circuit input from the Ambient Air Temperature Sensor to the PCM. NOTE: If there are any Loss of Communication DTCs related to the DDM present in the Body Control Module or elsewhere, perform those diagnostics before continuing with this diagnostic tree. NOTE: If there are any other DTCs related to the Ambient Air Temperature Sensor present in the BCM, DDM, or any other module, perform those diagnostics before continuing with this diagnostic tree. 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Turn the ignition on. 6. With the scan tool, read DTCs. Did DTC P072 reset? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (G31) AAT SIGNAL CIRCUIT FOR A SHORT TO GROUND 1. Turn the ignition off. 2. Disconnect the AAT Sensor harness connector. NOTE: Check connectors - Clean/repair as necessary. 3. Measure the resistance between ground and the (G31) AAT Signal circuit. Is the resistance below 10k Ohms? Yes • Repair the (G31) AAT Signal circuit for a short to ground. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 3 3. CHECK FOR THE (G31) AAT SIGNAL CIRCUIT SHORTED TO THE (C160) DRIVER MIRROR HEATER RETURN CIRCUIT 1. Disconnect the Driver Door Module. 2. Measure the resistance between the (G31) AAT Signal circuit and the (C160) Driver Mirror Heater Return circuit at the AAT Sensor harness connector. Is the resistance below 10k Ohms? Yes • Repair the short between the ((G31) AAT Signal circuit and the (C160) Driver Mirror Heater Return circuit. • Perform POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Replace the Ambient Air Temperature Sensor in accordance with the Service Information.(Refer to 24 - Heating and Air Conditioning/Controls/SENSOR, Ambient Temperature/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
Reduced fluid level does nothing. No real change in MPG. Topped off again. As for checking fluid temps but with the wet and snowy weather I'm seeing only temps in the 70 to 100*F range for both front and rear axles.
Yes, it's true it will start and run without a lift pump and drive at low speeds for safety yet. So does the AirDog pump and it will still suck fuel through the pump and run. My last AirDog failure it locked the pump motor up and blew the fuse. ISSPro EV2 gauge dropped to zero and lit the fuel pressure warning light. I was at a traffic light and still running. Drove a short distance to a parking lot and left it idling and tried changing fuses to see the 20A fuse blew. I drove to a safe parking spot. Then made the phone call for a tow truck. During my 2 hour wait, I was still starting the truck and getting heat in the cab to keep MoparMom and myself warm. VP44 is still doing just fine. Since I keep 2 cycle oil in the fuel this keeps the wear stress down and allows me to escape the low-pressure problems easier.
Try the ground point on the negative post of the battery.
what are common bad cam sensor symptoms?
Then the ground wire mod after your sure the alternator is good. Get a code reader. The only year the key trick works on for sure is a 2002. P1693 is a code meaning there is codes on the other computer. Get a code reader and report back the error codes.
fighting through my scenario............
No issues as of yet. I get more "thank you" and good comments from people and law enforcement for open carrying. Never once had any issues. Most of the restaurants, coffee shops, and stores I visit the owners and employees love the fact I carry openly. They feel more secure. In Oregon, it's legal to open carry never had any issues with law enforcement at all. Even while making my bicycle rides or shopping in these stores. Idaho now is concealed carry without a permit and even then never had any issues with laws enforcement. I think I've been open carry now for like close to 10 years.
