  1. I'm petless at the moment. You all remember "Diesel" the Doberman, right?
  2. Not normal. I run typically a high coolant temp of 220F going all out hauling my 8k pound Jayco. Normal conservative driving I bare break over 212F for coolant and about 170F transmission temp in summer heat. Pyro I've got enough fuel to tag 1,400F but conservative and using Quadzilla on Level 3 I struggle to get to 1,200F.
  3. On fueling to build a quick curve. 0 to 5 +1 each PSI 6 to 10 +2 each PSI 11 to 15 +3 each PSI 20 to 25 +4 each PSI Etc. Just use the starting number like @Me78569 suggest and use that to ramp it up.
  4. Hard to rest up. In still driving 250 miles 3 days a weak. Like right now I'm in Ontario. Be heading home soon into a snow storm. Be home by about 7:30pm tonight. Still even with what happened to me Mom still needs dialysis treatments.
  5. Low pop pressure means advanced timing. Then being you don't have a tuner the ECM cranks up another +4 degrees advancement. Yes MPG fooler prevents that +4 jump in timing. Then lower pop pressure means early injection event. This why when you raise pop pressure above 310 bar you now start regarding timing and possible make it difficult starting because retarding.
  6. Typically timing advancement is what makes the knock. Retarding makes it quiet typically.
  7. More exciting when you been driving the 5 speed then hop in an auto and stab the brake pedal for a clutch to shift and grabbing that ghost stick.
  8. @01cummins4ever be careful I might have to call you when I'm bummed out and need a voice to talk to...
  9. Funny stuff... The only problem either it's misspelled or its a different Michael or Micheal...
  10. At this point I'm letting @Me78569 make the lead decisions for the site. I'm hanging around to give guidance so when I'm down and out the BoDs will be in control. Part of my agreement back when the BoD was created.
  11. Matter of fact what I typically suggest is the master and slave cylinder from NAPA. The go through the bleed process. This way you build the system from the ground up and have it bled out before you install the system and it typically works the first time without issues. I've built my system twice this way and work the first time each time.
  12. He had me laughing on the phone. Yes, I did get his joke. As for that, I've been trying my best to eat the best I can with all the road time. I typically can resist cold and flu bugs rather well I've got a strong immunity being I only had one minor cold last winter. I'm typically pretty good about keeping up with a multi-vitamin and just trying to eat the best I can on the road. I look at it a bit differently. The Good Lord gave me the talent to share with the world. I'm doing exactly that. I see that it will be the family members of the M73M that going help me through this. Basically, see it in reverse. I created the vibration, but the vibrations of the family members here are going to give me the strength to overcome this. I've already talked to @JAG1 , @IBMobile and @dripley . All these wonderful people have been taking the stress off my mind and allowing me to relax. Again thank you all!
  13. Are you using the right length of control arms? It's possible that as the lift kit is pushing the axle down a bit more and rotating the axle forward changing the angles of the camber. Remember the lift kit not lifting the truck off the axle... It actually pushes the axle down away from the frame pivoting the axle forward as the axle drops. That pivot occurs from the length of the control arms. I would make sure the axle relation is like the factory height and not rolled forward.
  14. I don't suggest the upgraded hydraulics. Most people think its great because it's adjustable and already assembled and bled. The problem is adjustable it's very possible to hyperextend the throw-out bearing past the fingers of the pressure plate and destroy a clutch quickly. The other downside is you still end up bleeding that system again because air bubbles tend to get back in from shipping and handling.
  15. Might want to talk to @Me78569. He said if I drop dead he'll just sell the M73M website to the highest bidder... Thanks...
  16. The biggest thing is just to make sure MoparMom gets her treatment.
  17. 100% Absolutely agree... I understand most doctors are kind of back and forth about medical weed. There is more than getting stoned. The CBD family is more of the medical side of thing compared to the THC side which most people want to get stoned. Truthful there is benefits from both families of weed. I'm not shy about the idea at all. It's my body, my choice. To be totally honest that is one of the few reasons why I never was a big alcohol drinker because of the effect alcohol took away my mental abilities. I always thought the same about weed. I've listened to several on this but never got into it because I was healthy. Now the story changed and time to be proactive on healing as much as I can herbalistic and naturally as much as I can. I know I'm still got to go in and get the growth removed but... Why rely on big pharma?
  18. How about herbal... https://www.projectcbd.org/cancer
  19. Yeah, I'm that way. Not much stops me typically. Absolutely. That one thing both @MoparMom and I agree on. After yesterday we were so happy to get away from the city and the craziness. Go home last night driving in a snow flurry. Got home and made my nest on the couch just trying to unwind. I feel better now that I've had breakfast, a shower and got dressed and feeling a bit more normal. I'll admit that my blood pressure been up every time they get me in the office (white coat syndrome). Like I told Mom I've got to get my mind right and keep heading forward. It doesn't help when your stress out about yourself and MoparMom, driving in snow, trying to keep schedules and dealing with traffic.
  20. You could always hang one and be happy with a clutch pedal.
  21. Now that I'm at home and can see this on a normal monitor. The compressor wheel got trashed. Looks kind of like when I fed my turbo a hose clamp. The bearings are for sure shot you can see where the compressor wheel made contact. Oil is the other thing there is a lot of engine oil another sign of bearing failure.
  22. 375-190 is the 190F thermostat 375-180 is the 180F thermostat
  23. Sad to say this hard to put into text on the forum. Christmas Day I was working around the house and thought I picked up a UTI of some sort. It got worse through the evening. The next morning its started to clear then turned into I can't urinate. I drove to the hospital and found out I've got a tumor in my bladder partially blocking the right ureter. Never the less I was outfitted with a catheter and sent home with an appointment for a specialist in Meridian, ID. The ran the camera in me and sure enough, there is a fair size growth. The plan is by next Wednesday to have it removed. I'm going be out of action for a while. Anyone local to me I would like to ask for assistance if possible. My Great BoD's here are going to have to pick up the operation of the site for a while. I'm alive and well for the most part. Shaken by this, Oh hell Yes! The huge burden of trying to take care of myself and MoparMom dialysis. Then the mental stress of it being possibly cancer. Today I'm going to try and just as much as possibly gain some strength so I can just keep trucking. I've got to keep rolling for MoparMom's sake. Again I'm tapping @BrianAtSmarty for the day of my operation being I will be in the hospital for at least two days. He's going to put us up at his place and shuttle MoparMom on my days I'm down.
  24. Be aware the Cummins thermostat looks like NAPA's previous version thermostat. I've have had excellent results so far with NAPA thermostat's. I can say Gates is rather flakey and poor quality. Cummins Thermostat and NAPA old version on the left. The NAPA current version on the right. Much larger mouth. Also the current NAPA 190F is actually a 192F. On my truck I swapped back in the 190F and it runs about 197F to 201F with the winter fronts on the truck and outside temps running 20-30F with freezing fog.
