Grounding Accessories’s
Correct that +12V from the alternator. If you do the W-T ground wire mod that would be an open terminal. Still +12V. Ground should be as SHORT as possible and to body metal. Ground does not require running all the way to the battery.
ADR V2 Staging Flash - Race Only
Need to specify built automatics only. I don't see being able to do this with 5 speed handshaker.
Changing levels doesn't have effect
Not true. I left mine unhooked an entire year while my VP44 warranty was in effect. No issues after hooking up. The only thing is possibly a bad connection.
Recommended thermostat opening temp
Experiment with the idea. Nothing more. Like right now sitting in the truck idling to stay warm. Sitting at 172*F.
Intermittent strange high idle.
@cajflynn No blame on you... You were clear about the injectors being in the 400k realm I knew it was barrowed time. I got one year of service from those after having them pop tested and cleaned up. True a bad injector will cause all kinds of issues.
Fan is completely removed. 180°F thermostat, operational temperature is about 185 to 188°F. I can sit and idle for long periods never rise above 172°F.
The high step just before stopping is normal even my truck does the same thing. Now like the 820 RPM part is most likely the pop pressure of the injectors getting too low. This advances the timing of the injection event and tends to slightly increase idle speed. Like even my truck is starting to creep up in the idle speed because the injector pop pressure is starting to fall off. The next step I'm watching for is the misfire at idle warm and the injectors are now below 250 bar. That's what happened to my RV275 I had long ago I got from @cajflynn used.
Help I screwed up
Most likely some pup with a huge lift kit and oversized tire and end up breaking the box in no time flat. At least I know the box I got from Ryan has the same kind of care and attention my own box had and co be sure I've got a quality box now.
7x.0085 75HP POP pressures
I've got a set of stock injectors looks beautiful, nice and clean but absolute junk only thing that is good is the bodies. The nozzles and pintles are all shot and the pop pressure is down around 260 bar. If you plan on putting the stock back you better off just having them bench tested and see if they are worth the trouble to put back. Don't get me wrong my stock injectors still run but the spray quality is horrid. 16-17 MPG best even with Quadzilla tuning. Like my current injectors are closing in on the 100k mark too. I know the pop pressures are off and the quality of the spray is going south on me. MPG are slowly fading on me and its a fight to keep close to even 19 or 20 MPG now. I know I'm due to either replace or re-pop.
WTS LAMP
P0381 code would verify the bulb and save you a ton of work if you just check the codes.
High idle is typically because someone has been playing with the APPS voltage and attempting to adjust to match the tag on the stock APPS sensor. Another thing that affects idle is ECT coolant temperature. The COLDER the coolant the higher the idle. You can verify this by a live data tool and check the ECT values.
Rumble in 4x4
A piece of cake... Less than one hour.
This problem has me stumped!
Try replacing the fuel pump relay in the PDC.
WTS LAMP
Possibly... P0381 code would tell there is a bulb problem or wiring problem to the bulb. There could be other codes like P0380 or P0382 codes which the grid heater relay have issues and not firing. The only other thought which I would call a long shot is the WTS circuit of the ECM is damaged. I've never heard of that happening.
WTS LAMP
You going to have to stop at a local part store and have them plug and read the codes. 1999 trucks don't have any means of reading codes. There is no key trick. you might be talking the cluster test but that light remains off in the cluster test because it's controlled directly by the ECM and not the cluster.
WTS LAMP
Any P0381 error code?
W-T is still with us!
I got a PM from @W-T this evening asking me to give him a call. Sad to say that he's lost his home and belongings. He's still got his truck. He wants to let me know as well all of you that his alive and doing well. The fire and its complex nature its created is preventing him from being active on the website at this time. Like I told him we'll keep the light on for him and wait for him to return.
Tcase dead, what are my options?
I've got to ask the question what was the cause of the failure in the first place? That is something that has to be looked at too.
Not you got me looking at the NOAA weather page to see when I get to go play next.
Something I'll pass along to you. Go out and find a safe place to go play in the snow. Parking lots, large field, etc. I'm not saying high speeds but build enough speed and then to hard turns or hard stops and then try to correct out of it. Get used to the feeling of the truck gliding, the feeling of the point of G-force it takes to break free to start sliding. Now every start of winter I go do this and it pays off every year. Now when the truck starts to give way or slide a bit no surprise to me I know the limitations and how just a light correction can make it track straight again. I've had my truck start to whip the rear end on a corner with ever so slight correction and a light change of throttle she straightens right up. MoparMom looked at me and said, "You handled that like a Pro!" as she was gripping the "oh crap" handle tightly. That is where 90% of people get in trouble is the feeling of the vehicle breaking free and gliding on the road surface and the first thing they do is stomp on the brakes in a panic trying to stop the wild ride which is now set in motion till the vehicle comes to a true stop now. Now if the fear doesn't set in your mind will react accordingly and correct the problem before its issue.
Dodge ECM
Auto don't have the anti-stall feature. Manual do have this feature. Fueling map wise basically the same. Idle speed is a idle validate switch that trigger the ECM to seeing that idle is set and uses a totally separate software for controlling idle. Once the throttle moves and shows throttling now the idle software is dumped and the ECM now follows the APPS values for fueling commands.
As they panic at 25 MPH in 65 MPH speed zone. Out here it's laughable I find all the oversized tire and lifted Ford's out running around and only rolling 30 to 35 MPH in 65 MPH zone because they have no traction and unstable. I buzz right around them and keep on hauling a comfortable 55 to 60 MPH. The funny part, I rarely ever use my 4WD. Most of my highway travels in 2WD only.
Dyno with quad
You going to need to run it on the street through the RPM bands and see how it performs. Be aware high cetane fuels will create an early ignition and high cylinder pressures. Your 30° max might be too high. There was one gent here that just blew a head gasket with 30° timing and had ARP studs already and about 70 PSI of boost.
Towing without gauges
Like I see roughly 60-65 PSI on the highway. Idle at about 35 PSI fully warmed. Anything about the stated minimums. Excessive high oil pressure is not good either being you take the risk of blowing out the plastic oil cooling jets for the pistons. This is one reason that cold startups Cummins suggest to allow the oil warm a bit before rolling so the oil pressure doesn't get too high starting out in the morning. Mind you the block heater does not heat the oil or the oil pan at all. All that is the same temperature as the outside air. The block heater only heats the coolant jacket. So the first minute or so the engine oil will pass there the oil cooler and rise to the coolant temperature.
cold engine quiet
Clue. When an engine gets quiet the timing is retarded. This tends to make me a bit worried and want to check for error codes like the P0216 code. even like my last VP44 when it failed it died with the P0216 code as well but it was stuck in full advancement it rattled and knocked badly. As timing retards engine gets quiet. This is because the fuel is actually igniting slower and later and actually doing it work after TDC. As timing advances the ignition of the fuel is happening before TDC so you start to hear the rattle as the fire starts the ignition BTDC and then pushes over the top and finishes with the power stroke. You might look at other factors as well. Fuel and cetane amounts. Higher cetane fuels are lower BTU's but ignite much faster. Low cetane fuel will have more BTU's energy and burn slower and later.
