  1. Umm... this is what I did back on the Edge Comp and +50 HP injectors. Before even the Quadzilla or the +75HP injectors. The 245's let out more torque than the 235's did. This is nice because of fewer chances of breaking stuff again.
  2. Still there is no replacement for good a-pillar gauge setup! Even I tend to favor the A-pillar ISSPro gauges over the Quadzilla Gauges.
  3. I love the sleeper mode. "Ah, just a stock truck I can whip it." Yeah right. I actually hunt for 4th Gens with lift kits and minimum of 35" inch tires. Those jacked up 3rd and 4th gen I kill for fun. No problem. Surprises everyone when the tires let go and the truck is gone. Where did it go?!?! My design is all about shedding all the excessive drag and maximize my torque value. Which I've done.
  4. 30k miles or once a year would be best. Brake fluid is hygroscopic in other words absorbs moisture from the air. As the moisture level builds in the fluid the boiling point of the brake fluid goes down. Then the other side is more moisture the more oxidation it will do inside the plumbing. Again you need to open up the system and inspect not just push the debris into the bottom of the calipers. This is why bleeding should only happen after the calipers are cleaned and the system is already empty.
  5. Just run it. It will come out in time. Typically I leave thermostat out during the time I'm filling with coolant to ensure that majority of the air is removed. Empty heater will have its own air to add.
  6. Between the head gasket and property taxes coming due. I'm not going to be able to replace my injectors. Then Christmas coming I might not see injectors for quite a while. MPG is sliding backward some. I wonder if it can read our goofy MAP sensor correctly? Even the Quadzilla is close but not absolute on the mark.
  7. When the calipers are removed and the pistons removed. Now remove the seal and test fit the piston back in the caliper. The piston should drop to the bottom without being PUSHED. If the piston is hanging up then you have to lightly sand off the caked up brake fluid or just replace the pistons. Just working the piston in and out doesn't remove the debris in the bottoms of the piston cylinders which will cause them to bind again. Like seen here the piston falls to the bottom easy without the seals in place. The only time I've seen brake hoses come to play is when people run brake fluid like a lifetime time fluid. Now the fluid is BLACK and the rubber has degraded from the excessive amount of moisture in the fluid. Now this debris is typically settling in the bottom of everything and the calipers and there is no amount of bleeding going to remove that. You need to open all 4 calipers and clean and check everything.
  8. If you would have just changed out the brake fluid that would of all needed to be done. When the brake starts to absorb water from the air it starts to oxidize in the system causing the pistons to stick. So just changing brake fluid and disassembling the calipers and cleaning them out would have done way more good. The problem is all the debris is drop in the bottom of the caliper and the bleeder screw is on top.
  9. Drop 1 or 2 degrees on the entire base timing.
  10. The only factor that changed for sure is the cetane of the fuel being that higher cetane is going to ignite sooner and most likely gaining cylinder pressure with the colder air mixture. Wrapping my mind around that... Being the air is in the cylinder the entire time regardless of the fuel timing. Being the fuel is injected 30° of timing that coupled with high cetane fuel that burns faster and ignites earlier I'm going to bet more on that the fuel was lighting off way sooner than usual and cylinder pressures came up. Where with lower cetane fuel of the summertime tend to lag a bit more in ignition time. Hence why like myself I saw a good drop in MPG's when the cetane finally kicked in fully and then drop the timing 2° and now gain back the MPG's. Cold air I'm at +10°F in the morning and IAT is at roughly 62°F during this time. My max is 27° of timing. Just beyond that, I just start the bucking game.
  11. The sensor has to have distance from the snubber to allow the pulses to fade in the distance of travel. Hence why I created this write up and still to this day my ISSPro EV2 sensor is still working perfectly. A common mistake to place the sensor right on top of the snubber and then to lose the sensor shortly afterward.
  12. Ummm... Seriously doubt that several inches comment. Being that from the bottom of the case drain plug to the bottom fill plug is only 6 inches. I've got 7 inches of oil in the case which is over the top of the sensor. There is oil over the top of the sensor even if I put the gearbox in 5th gear rough road speeds RPM (~1,800) and transfer case in neutral and check it still got oil over the sensor. I've checked this too.
  13. Just be aware. If coolant temperature starts to rise back off and slow down. Typically coolant will start to rise if the EGT's are held above 1,100*F for long periods. I know for a fact a stock ISB engine can and will run past 1,400*F just towing at highway speeds. I learned this lesson on my first trailer towing job hauling a friends Chevy pickup back from Boise, ID over Horsebend grade. Just barely install my DiPricol Pyrometer and still no injectors or tuners yet. The EGT's could rise to 1,400*F easily towing in top gear at 60 MPH which is posted speed limit. But I had the 3.55 gears... 5th Gear (NV5600) is direct 1:1 ratio this is the gear you want to be in towing over grades if you want to play it safe.
  14. Slightly overfilled about a pint. Just checked the fluid today and its still over the top of the sensor. Just got to lightly tip the sensor sample the oil for color and screw the sensor back in and plugin again. Putting the sensor at the bottom will get a false cooler reading since heat rises to the top. This is quote the "hot side" of the transmission which most have heat shields, exhaust blankets and such to keep the transmission cooler. Again mine is cooler from the start without any fast coolers, blankets or heat shields. Now figure that out... All I'm running is that GL-4 50 WT Mobil Transmission Fluid... @AH64ID had the same comment to and we already dealt with that problem. Like today I crawled the entire truck checking lubes and inspecting brakes and everything the last thing I want is get total covered in oil and dirt. I keep after my leaks and keep the dirt and mud rinsed off. Winter time salt does it task when you leave a ton a mud under the truck. This why I been able to hold the rusting at bay so long!
  15. I found a scrap piece of steel strap and ground it down to fit the cigarette lighter lever it over and was stuck. After a bit of tugging on it the locks on the black ring gave up and the entire cigarette lighter socket and the lock ring came out together. My tool is permanently stuck in the cigarette lighter. Now taking a old chainsaw file slowly working the hole open I managed to just make the hole big enough to push nearly snug in. Finally a real Android Quick Charger for the truck. My LG G5 phone sees the charger shortly after powering up. This is super nice no more parasitic draws. I will add the nut here shortly. Daylight was short today and getting cold outside.
  16. Most local part houses don't carry diesel style gauges mostly all gasoline stuff. Even with today's cars gasoline engines are now in the 40-60 PSI range with fuel injection and throttle body injection (old school). Good call... But I'll let you know the 4 ways to kill a VP44. 1. Low fuel pressure - 14 to 20 PSI is optimal. 2. poor filtration. Aim for a good 3um filter if possible or double stacking. 3. High AC noise - Bad alternator diodes will kill a VP44. 4. Poor lubricity - Bosch states fuel should be <460 HFRR all today US diesel fuel is ~520 HFRR.
  17. You can pull the clutch off the same on 24V 2nd Gen. Just pull it up through the top. Where I live I'm in the mountain of Idaho my morning temperature here could be downright cold at zero or +10°F outside then roll on down to Ontario, OR and have daytime temperature in the 60's or 70's for a high. I found out by just being lazy and not taking them off to learn the fan will take care of the cooling just fine. Might try the fanless idea this winter and pull it off and leave the winter front off. Winter is stalled and late to start here. Temperatures are cold enough just no snow or rainfall yet. Then daytime highs have been mild.
  18. As long as the grill is the only cover it will engage when the fan senses hot enough air. I've run this style of grill cover for the year with temperatures as high as 70°F outside and the fan will naturally lock on its own.
  19. The only shock I would mention is the Monroe shocks are of low quality. I've got those on my 1996 Dodge Ram 1500 now and they are well too bouncy and don't dampen enough.
  20. Hmmm... Strange I've got trouble with 50 WT lube to get above 100°F on the transmission temp. It like the viscosity of 90 WT gear lube. I've got to be above 50°F outside temp to even break above 100°F trans temp. Without FASS coolers... I've finally made 100k miles on 50 WT oil still going strong no issues to report. Now heading for 200k milestone!
  21. Still the fact remains API gravity MUST change to alter cetane. Being Cetane and BTU are directly related you can have high cetane and high BTU's together scientifically impossible... Like the most common PPD used in US diesel fuel is Xylene typically at the 8% to 12% levels in winterized fuels. Xylene is also used in some cetane boosters as well again there is all kind of chemicals on the market to change the fuel. Still even after the adding of these chemicals, you can still measure a change in gravity. BTU's come from the fact of long carbon changes in the fuel long the chain the more BTU's. Cetane is the ability to ignite easily in cold weather. The only way I know how to do that is cut the carbon chains shorter. When this happens the API gravity can measure the density of the fuel now because the carbon are no longer long then have been shorten. As you make longer carbon chain length you start heading towards oils and high BTU's as you shorten the chains you start going to light distillates like gasoline which have lower BTU's. This is a primary reason why gasoline has a high API gravity and lower BTU's content that diesel.
  22. Kind of like dropping gasoline in diesel or waste oil. Still it chemical altered but you can still measure the API gravity change. Really common for WEO and WVO running that are chemical altering fuel to meet the needs fo the season and you can still measure a chemical altered fuel with a API gravity. Hence API gravity goes up the BTU's go down. Still if you can measure API change then there a cetane difference. If there is no API gravity change then cetane didn't change.
  23. Never seen this before. When you change the cetane of the fuel your basically changing the API gravity of the fuel and making it lighter. Which is going to move the vertical axis to the right as high cetane. When you look at the scale provided by ASTM labs it rather difficult to keep high BTU content at the same time of having high cetane levels. The horizontal axis is the cloud point of the fuel and how soon it will gell up. I just don't see it possible to chemically alter the cetane and BTU value high. impossible to change the API gravity of a fuel and have if both heavy and light at the same time. Just for point of reference right around 115k BTU is where super unleaded starts.
  24. Someday we need to sit down and chat on the phone. I can fill your head with a ton of info on these truck and it would make your head spin on why did they do this and that.
