P or LT tires on 2013 Silverado 1500 1/2 Ton
Just remember GAWR is the absolute maximum weight of the axles. So even using that number it will be below that specified pressure. As for scales... Just in my travels, I know of at least 4 free scales I pass 3 times a week. Truck scales are every where and if you simply ask a lot of times the shop or shop will hand write down your numbers. Like I know of another scale on a public road in Nyssa, ID you can access and scale on your own. There is another trucker scale over in Horsebend, ID that is always on. Just drive up and look at the display. Scales are everywhere just most people just don't think about it.
CAD&Free spin kit Advice
Factory configuration... I've covered 360k miles on my truck and its 16 years old. I've replaced... 1 set of wheel joints (357k on the joints when the passenger side failed) 2 sets of unit bearings (roughly 180k a piece) 1 set of ball joints 1 set of tie rod ends 1 set of brake pads 2 track bars
Even my little 1500 Dodge has different front and rear pressures because of very different axle weights.
Scales are needed for either method.
Well, bad news post w-t mod.
W-T ground mod just reduces the AC noise but bad alternator diodes create the noise. What it was the charge lead ran past the ground lead dumping the AC noise back in the ECM side and fouling the ECM tach sensor and such. I say to disconnect the alternator and go for a test drive. If the weirdness stops then you know its the alternator. As for APPS sensor the only way it will create that issue is if the rheostat is worn out in one spot. Typically you can see it on a live data tool and watch the TPS jump up and down rapidly.
Quadzilla on a stock truck
I'm running 7 x 0.0085 injectors (+75 HP) no problem making a smoke free tune.
The red crimp is NOT factory. That one needs to be looked into.
Sensor Ground is not the same as body ground.
AC noise look OK. Kind of high for W-T ground wire mod. It should be closer to 10mV range your showing 34mV most likely as grid heaters hitting. Gumbo is rock solid. No electronics and completely mechanical design. No voltage to set or adjust. Basically your setting the bellcrank angle when you install the timbo APPS.
Nv4500 atf+4??
I can now get 50 SAE maybe a bit below $200 a 5-gallon bucket now. Don't need the flashy "Mobil Delvac" name I can pick up any GL-4 50 SAE fluid and do the same thing. I can cut a ton off the price. Lots of other names out there without the price with the same spec. At any rate it WAY cheaper than factory Mopar Fluid...
Wrong... Scale weight of each axle NOT GVWR!
Test for AC noise.
Coolant leaks - Oil Cooler
I think mine is mostly coolant pH issue. This last go around I was way past due for the coolant change being MoparMom's adventure. I know that coolant was way past due and I'm betting the pH level was corrosive enough to eat the head gasket and now the oil cooler gasket. The very thing I preach not to do is the very thing I did...
In my case it's the top side of the oil cooler towards the front. The head is dry.
Nv4500 atf+4??
Ask @AH64ID he's the AND Oil guru.
Rear sway bar end links
Rear seat bar make a huge difference in launching with that South Bend Clutch. Much smoother with the rear bar rebuilt.
Thanks for the warning on the oil passage. Ill make sure to watch that close.
I'm not looking forward to doing the front sway bar. I'm beting my clunk noise is there too.
I'll pick up a gasket for that and get it done.
Here is a way to get the pressure close to right.
Dang! I'm not catching any breaks these days. Doing my weekend inspection on the truck and noticed my coolant reservoir is down to the add mark just about and then noticed the small drip puddles on the floor. Tracked down the leak to my oil cooler gasket is leaking. Hopefully, that is a fairly straightforward repair for that gasket. Any information on this task would be great.
3rd gen track bar on a 2nd gen
Been running NAPA track bars and with 235's and 245's I can clear 100k miles on a track bar but I do that amount of travel in about 1.5 years. The problem is the leverage force placed on the track bar by the larger tires. Rotational mass isn't the focus here but the ability of the tire and wheel lever against the track bar causing the failure.
Fuel pressure bouncing
Then there is nothing to worry about. You don't even have to worry about change oil up for the extreme cold. Personally, myself we do get minus weather at least once a winter but I typically don't sweat it because the first part the truck is parked in a unheated shop for the night typically around 40*F through the winter. Then sub-zero typically for us only last a few days to a week or so. Not worth going into panic mode. I pay attention to the logging companies and I've got friends that work the shops so I typically get heads up of temperature related issues.
Most with CAD axles rave about the idea of having the manual pull cable to allow for 2WD LO for backing trailers and other stuff around.
Not even cold yet. 55*F in the morning is a typical summer morning for me. Cold is when you start diving below 0*F now that's cold now you should consider using the block heater. Right around 32*F I start using grid heaters on the first start of the day. I don't even worry about plugging in the block heater till it diving below ZERO. Sad, part is when I'm traveling I don't have an option to plug in if it below zero. I just cycle the grid heaters twice and fire up and let it warm up for just a bit. This is why I don't panic about plugging in because once I travel somewhere there is no way to plug in again. Why worry...
