6 Speed manual transmission ~ NV5600 ~ General Questions
I'll just keep my trap shut...
Help out a fellow forum member
Tim called again today... He's looking for more things if possible come on gang help out a fellow forum member make it through his time. Tool catalogs LMC Truck Ford old body style LMC Truck Dakota (2nd Gen) Few websites he mentioned.. https://www.summitracing.com http://www.advancedplating.com/ http://www.thermotech.com/ https://www.woodwardfab.com/ https://www.koolmat.com/ http://designengineering.com/ Come on guy jump in and get him some catalogs and reading material. He's asking still please help him out.
Nv4500 always hard to shift?
Carbon syncro's require a Synthetic GL-4 lubricant. WARNING: GL-5 lubricants will damage carbon fiber syncro's. I can't speak for engine oils or ATF+4 for a transmission lubricant. Might be too thin for good protection. Like during my rebuild on my transmission the 5th gear itself was worn and required replacement. The hard facing was gone. I ran strictly the 75w-85 Mopar Fluid and it failed to protect. Which is the same values of 15w-40 engine oil. When I reach 362k miles will be 100k miles on this transmission with 50 WT. Take me 8 more trips to Ontario, OR and I'll have 100k miles. My morning temperatures are dropping in the teens through New Meadows and Tamarack Mill. Very cold and the transmission temp is not even moving the transmission temp gauge off 100*F at all. I need at least 50*F outside temperature to even reach 110*F transmission temperature. Here before long, I'll be down in the -20*F realm for winter time.
This is why you can't judge the 50 WT transmission fluid as a cause being you've added more rotational mass in your clutch. Then blame the fluid. Very very common. Now if you had a single disc clutch you would see the very same thing I do with good shift quality. Way too many time people claim they changed fluids attempting to resolve a shift problem beforehand and then the problem worsens after the fluid change and the blame is tossed on the fluid instantly. When in fact the majority of the time the shift problem is a pre-existing clutch issue or pilot bearing issues. Personally, I think the 50 WT will provide better protection overall being the lubricant is much thicker and withstands temperature better than a thinner grade of lubricant that would get too thin in heavy towing or high summer heat. Being 50 WT transmission fluid is designed around the Eaton Fuller transmissions and hauling 80,000-pound loads. It should be a piece of cake for the 50 WT to do its job for a mere 8,000-pound truck.
Just wanted to say thank you to all of you
Thank you in return for the wonderful message!
Dual disc clutch tend to have more rotational mass and the syncro's can't slow down the input shaft fast enough because of the rotational mass of the dual disc. What you doing with double clutching is giving the discs enough time to slow down and syncro's can do there job now.
Quadzilla display project
A stupid and crazy idea... @Quadzilla Power ... I wonder if its possible to change over the Quadzilla communication to USB for a cellphone. That would be killer option too. Being my LG G5 cellphone already has Type C USB and just change up the app to communicate over the USB instead of the bluetooth. The killer part is the USB cable could supply power to the cellphone.
Engine stumbles
Might not be worn out but pop pressure to low and getting inefficient.
Engine stumbles
Like im going to be next on injectors. My DAP 7x0.0085 are getting a bit dirty, haze, and faint misfire. I've got close to 100k on them.
Axle shaft u joints
When I did my wheel joint the passenger side I beat on for four hour using heat, PBlaster, and more beating. Driver side I could even start one cap. This shaft required a press which was extremely violent when the caps let go. There was no amount of hammer to free the driver side. Hence why I don't want super life span again by that time of 16 years and 350k miles the caps will be bound up again.
Axle shaft u joints
Yeah, I might have gotten 350k miles from my factory OEM joints. Still, the fact remains it was a horrid nightmare to get those joint out and replaced. I would much rather have a joint that is not going to last very long and replacement and greasing much easier. So what if I got to change u-joints every 100k miles much better than beating on stuff for over 4 hours with 6 pound hammer. A lot of people like the seal units. With all the flood highway and snow I travel its just not a good idea. Now that Idaho is using strictly all salt its making suspension part fail sooner. Causing issues on replacing simple things like u-joint a royal beach.
Axle shaft u joints
Those could of last much longer if there was a grease zerk and able to flush the old debris out and keep them lubed.
Damn stalkers
I did get an email back from him.
New Tire Size found 235's to 245's
I've been enjoying the 245's. way more power on the highway I can accelerate much faster now. Still the MPG is not changed much. Still drifting around the 19 MPG with winter fuel now in full swing. The higher final ratio really does make a huge difference in acceleration. I like the fact I can remain in 5th much longer now. I'm in my top gear sooner.
Modern Power Point
Need measurements. I've got plenty of scrap metal and a grinder.
Modern Power Point
Crap I don't want to buy another socket. Just want the tool.
No Bus question
Geno's is just a vendor. dodgeram.info.
Rattlesnake Fire, Idaho - 2018
I've not even gone up the trail behind the house beyond the dam yet. I've even asked around to see if anyone else in the neighborhood has... Nope... I've gotta take a ride up there and post some pictures as well. I know the hunting in the area sucks and animals are not around. I saw my first deer today in the yard. Finally, some animals to eat all the fallen apples.
No Bus question
http://dodgeram.info/tsb/2000/08-05-00.htm Found...
No Bus question
Yeah I'm going to bet loose cluster. I'm pretty sure there was a TSB for cluster related no bus issue too.
Boost gauge hookup
That hollow bolt is just risky either break the bolt torquing or the tubing get broke every time you pull the valve cover or injector lines.
Charging system issues
Secret. The minimum voltage that ISB Cummins will run is 8.00 Volts.
List of OBDII Scan Tool Live Data Available?
Not much really. Intake Air Temperature Coolant Temperature Engine Load MAP RPM MPH Volts and a few more I can't remember right now. But then the rest is all calculated information from the given information from the port. Like, estimate GPH fuel flow, MPG gauge. etc. Basically, the OBDII port can't provide any more than there are sensors for.
Extreme erratic loss of power, feels like driving over washed out road
Any current error codes? What is your fuel pressure? Are you drawing air into the fuel causing it to cut out? You should be able to see this in fuel pressure.
Check Guages Light
There are only the green and blue wires on the back of the alternator. Green is a variable ground for the alternator field. Blue is +12V when the key is turned on.
