  1. Mine is a True Pyrometer flue temp not just pipe temp.
  2. Yeah typical winters for me have my truck in lots of flooded highways and lots of slush. At least now every oil change I can lube all these now.
  3. I'm wanting to replace my Kenwood soon. I've got a wonderful MP3 player but I'd like to have Bluetooth.
  4. I went with NAPA wheel joints. NAPA wheel joints are greaseable. My problem was the bearing caps where rust to the shafts. Driver side required better that 20 ton press to get the cap to even move. Passenger side took me over 4 hour of beating with hammer and MAP torch to get the passenger side apart. I'd rather have them fail before 100k that fight to get 350k wheel joints to even move with 4 hours of swing 6 pound hammer.
  5. No longer made. As far as u know there is no new ECM available. Just like VP44 only rebuilt units.
  6. Mine only creosote the last 2 foot of chimney just above the roof. Even with chimney temps above 1,400 at 12 inches above the stove the chimney top is just too cold to even bother creosote. I've got 6 inch pipe stainless as a liner in the brick chimney.
  7. Reason why... 2002 and older is a Sagnaw steering box which is designed for power steering fluid and don't forget the hydrobooster. All the seals are designed for power steering fluid. 2003 and newer is a FORD steering box. Yes, it's a Ford Motor Company steering box and pump hence why the change over to ATF after 2003.
  8. P0576 is cruise control voltage low error. This has something to do with steering wheel control if I'm not mistaken. You can unplug the PCM and see if the truck starts. Only need the ECM for the engine to run.
  9. 1st Gen no listing of any fuse or fusible link... Dodge Factory Service Manual. 2nd Gen... Clearly shows the fuse... As for 3rd gen and up I'll have to EAT MY WORDS... There is a fusible link but it in the loom somewhere.
  10. So now search back on the internet and you find no such thing has ever happened. The diode will burn out like a fuse and that the end of it. The circuit is now open.
  11. @W-T got me thinking about the whole thing too. When you check back on the Dodge Ram truck history. 1st Gen 89 to 93 - No alternator fuse. 2nd Gen 94 to 02 - 140 Amp Alternator Fuse in PDC 3rd Gen 03 to 07 - No alternator fuse. 4th Gen 07 to 18 - No alternator fuse. 5th Gen coming out in 2019. Most likely won't have an alternator fuse either. You should see mine I still got all the OEM cables yet and excellent condition and never corroded once!
  12. Correct. The heavy cable has way less voltage loss in the travel. This why the charge lead needs to be as short as possible. I cut off over 4 foot of cable and down to a mere foot or so of cable to the battery. A huge reduction in voltage loss in the run across the front of the engine back to the PDC.
  13. Mine just past 360k miles and started a coolant leak at the top corner.
  14. Same with mine. Dead silent operation.
  15. Bingo. The Injection pump automatically raises pressure as you throttle up. Now if the injector pop pressure is too low then the fuel mist is much larger droplets and then it tends to smoke more than burn because there isn't enough time to heat the large fuel droplets to go BANG! So when you raise the pop pressure back up the 310 to 320 bar realm the droplets are much smaller and all the fuel is burnt like its meant too and the smoke is minimized.
  16. Just like my AD 150 replacement has been rock solid. No issues with the pump I still need to fix my regulator spring which I might jump into this weekend.
  17. Here is the timing kit by DAP... https://www.dieselautopower.com/diesel-auto-power-cummins-timing-kit-9498ctk
  18. Make sure not to get any gasket debris in the oil ports. A tip gave to me by another member!
  19. Ugh. That wiretap most like is a weak fuel solenoid connection. I would pull the VP44 off so you have good access and solder and shrink tube the wire back together. Those scotch locks need to be tossed in the trash. I hate those darn things. Stealth plate is the best option.
  20. Too much voltage loss not required.
  21. Fuse does nothing after the mod. Unused. Only 2nd Gen trucks have a alternator fuse. Then 3rd gen trucks dropped the fuse idea.
  22. Like I said varies vehicle to vehicle.
  23. White smoke is a sign of retarded timing. P-pump has a timing plug on the back of the pump. Where you remove the plug a little engine oil will drain out. Now inside the plug is a plastic alignment tool. Now roll the engine over to TDC #1 there should be a metal tab in the hole now. The plastic plug is to hold the pump shaft. The hard part is the tightening the pump nut without turning the pump shaft and breaking the plastic plug off inside.
