New Tire Size found 235's to 245's
You want to come down toward the 3.73 mark more so. At 3.69 ratio 65 MPH is right at 1,960 RPM's. 3.55 is a bit better for strictly interstate travel at 80+ MPH. 3.73 seem to be way better on the standard 2 lane mountain roads and even towing. You have to consider what you do the most. Remember Quadzilla shows -1 MPH off this is actually 65 MPH.
Overdrive Problems - Vibration / Lots of Black Smoke / High EGT / Sluggish
Sublevels at least for my old Edge Comp. 1 33% stock fuel till 20 PSI of boost 2 50% stock fuel till 15 PSI of boost 3 67% stock fuel till 10 PSI of boost 4 Some extra fuel at low boost 5 Full fuel at zero boost
Fuel economy on iQuad
That's where everything stops. There is no option to open period...
Edge Products work on two settings. Main level which you see on the main screen. The second number is the sublevel it called something different on the Juice. But it in the menu for how aggressive the fueling occurs. Main Level 40 HP 60 HP 80 HP 100 HP 120 HP Sub level wise is how much boost is required to unlock the fuel.
Right here... https://tiresize.com/gear-ratio-calculator/
Unfortunately I have to put my old headlights back in
I'm assuming you did these? I love my Morimoto's. Better than any LED or Halogen light that for sure. Curious what color bulb did you use? 4300k, 5000k?
I need help spending some money
The biggest thing is to get over your fears and just do it. The biggest thing is to make sure the KEYWAY is up at 12 o'clock, not the TDC marker. This requires the nut to be removed and washer to see the keyway. Beyond that just removal. The only other trick is to leave 3, 5, and 6 lines on the engine they do not have to be removed. 1, 2, and 4 have to be removed at a unit. There are 2 bolts holding the rear bracket down by the power steering pump. Then the 4 nuts holding at the gear case. Be nice to all your fuel lines and don't bend anything you can flex them a bit but don't purposely bend them.
What size tires? What gear ratio? Any boost leaks? Could you get us more specs on the turbo? Typically most report the 3 numbers (54/60/12) 54mm compressor wheel, 60mm turbine wheel, and 12cm2 exhaust housing. What level and sublevel are you running? What size injectors are you running? Just looking again you might look at the TV cable adjustment.
Good idea. It only a few more bolts to do the tappet gasket and simple as heck to do. Just please don't get stupid with a ton load of silicone sealant. Typically I would just light fill the gap of the gasket with a thin layer of silicone then slip the clean cover into the groove. THat bit of silicone will aid in sealing the cover better. The face to the block doesn't really need anything the rubber will seal just fine.
Way taller. 47RE is 0.68 NV4500 is 0.75 NV5600 is 0.73 What I'm finding for final ratio at around 3.60 to 3.70 is awesome. Mine is at 3.69:1 ratio to the ground with the 245's now. I just towed the RV home tonight. I'll admit I was being abusive to the truck to see how far I could reach. Needless to say you can push pretty darn hard on it now. Few grades I left the cruise set for 60 MPH. Walked on over. The best part was a Ford flatbed tow truck was empty couldn't pass me as I left it in 5th gear hauling on over the grade doing 60 MPH. Then another grade I down shifted to 4th (direct) and beat on it some more running up the grade at 55 MPH which is up around 2,300 RPM now. But it pulled great. Still had power to spare. Transmission temperature was great floating 160 to 170*F remember that is just a factory NV4500 no coolers, no heat shields, and just the 50 SAE oil in the case. I did push hard enough to get engine coolant temperature up in the 210-220*F range. Like I said I was being a bit abusive to see how far I could reach. I'll say there is way mode towing power. Runs cooler EGT and engine wise on the flats. I'll also admit with the Quad on any wiretap mode it will pull the tires out from under itself. Level 3 is perfect you can mat the throttle to the floor and it stops just short of 1,200*F in top gear on flat ground. (Quadzilla and +75 HP injectors)
@JAG1 been bugging me to fix his A/C on his truck.
All my tips are in that thread... Not hard. I was even able to teach @JAG1 how to change his first VP44.
Can't import at all for some reason. Just tried that files are grayed out and do nothing.
Now if I can con you to come over here. Hint hint....
Intermittent idle sputter
I would say still either air in the fuel issue or a injector with pissy spray popping low.
Dude... That means I've got to rebuild my tunes... Not cool. Oh well.
High Fuel Temp
Only if the temperature is below 70*F. Then it switches off above 70*F. With all my driving back and forth, I can say without a doubt IAT and fuel temp typically are within 5 degrees of each other.
Thought I would share a little carnage
Sad part the water pump is purely a coolant flush issue. If the coolant was flush at a proper time you wouldn't eat the water pump bearing. I'm at nearly 350k miles on the OEM water pump on the Cummins. I've got 172k miles on the V8 water pump. Still to this day all shop I visit they all do the same thing test for freeze point but don't test for pH level. Then when the pH gets corrosive then it eats the bearings and any other metal the coolant touches.
I've done the flash. Nothing has changed no extra gauge. I've even selected the vehicle again. What am I missing?
Being I'm still doing roughly 60k miles a year I'm sure I can.
I've got to get my VirtualBox fired back up again.
Black Smoke - Normal? If not where to start looking?
High timing should only be used for low cetane / cold weather. I've had to retard quite a bit as the temperatures here have started rising. The IAT temperatures are higher so the fuel ignites easy and so you don't need the timing on a hot day. My problem is my early morning startup might be 48-52*F and IAT to match for several miles. Then it gradually rises over the day then by 11am when I get down in the high desert of Ontario it now getting up to 130*F worth of IAT now I find myself changing the tune and dropping about 1-2 degree total across all the EQ sliders.
Quadzilla Adrenaline Economy and MPG
Like another thing I'm finding out is that you need to consider the IAT temperature in your tune. Being I've got wild swings in temperature starting as low as 48-52*F IAT as I roll out in the morning through the canyon. Then by the time I'm returning home I could be as high as 125 to 130*F IAT and find myself moving all the bands of timing up and down to keep a sweet spot. Cooler mornings you can run more timing by the heat of the day you need to retard this some. With the smaller tires, the EGT's have been low. Engine load is low too like around 15-19% at 60 MPH on my last trip home. Also going to split up the tunes again.
crazy fuel pressure & engine speeds
- Black Smoke - Normal? If not where to start looking?
Nope... Single HX35/40 Hybrid. +75 HP injectors (7x0.0085). A matter of fact I'm splitting my tune out to reach for more. I've been trying to keep all in one tune which is not possible really. Light load requires different timing than WOT or racing. Not to mention I was attempting to build a fuel map one size fit all. Nope doesn't work, some conditions give smoke most others don't smoke. - Black Smoke - Normal? If not where to start looking?
