  1. 5.9L V8 gasser with 46RE transmission with 3.55 gears.
  2. A matter of fact I just checked my oil yesterday and its still between full and the add marks. Black but oh well the engine still spins and makes that Cummins music I listen to for over 6 hours a day. Another way I look at oil and filters. Look at your big over the road trucks and what they run and the trucks go for long distances without failures. If it works for the bigger Cummins series engines there is no reason it won't work for the smaller ISB engines.
  3. Yeah, I know that... LOL
  4. What is your EGT's like? What size tires are you running? What temperature thermostat are you running? Where did you buy the thermostat?
  5. Yeah, it is the door sticker size. Mine was sold with the 265's from the factory. I opted for the 235's to reduce steering wear and front axle wear. Which it did. Now I'm looking to gain a bit more by changing the ratio up. Instead of like 99% of the people here that go bigger like 285's, 35" inch and 37" inch tires I found that with 3.55 gears and 245's is an awesome setup. Here is a tweak I'm going to do to the 1996 Dodge. I found out it was manufactured with 245's as well but I'm going to switch that truck from the 235/85 R16 to 215/85 R16. That is the same as 245/75 R16 just an inch narrower. This will improve the MPG's on that truck and give better performance on snow-covered roads. That truck is about 2,000 pounds lighter than my 2002 Dodge and the wider tire tend to make it float on top of the slush and snow. The cruise RPM on that truck is too low and it struggles to pull in 4th gear.
  6. I just got a pair of used 245/75 R16 tires from a friend. So I mounted them up on my old aluminum mags and mount the 245's on rear axle of the truck. They are a bit shorter in height. The gains are great! Engine load is reduced by 5% to 10% roughly. EGT's are about 50*F lower. Acceleration is way better and faster. Cruising RPM's are right about 1,960 RPM at 65 MPH. I've got to reset my cruise timing limit on the Quadzilla I need to drop from my current 25% to 20% it was holding cruise timing climbing about 2-3% grade. I'm going to document MPG usage as well in the coming days.
  7. I had mine rebuilt by Module Master in Moscow, Idaho. Done right and not cut through the cover.
  8. I done the best thing... ISSPro EV2 gauge with programmable warning lights. My fuel pressure gauge warning light comes on at 13 PSI.
  9. That was a mistake. You want traction you want a smaller footprint. The smaller the footprint the more pounds per square inch you'll get for traction. So with the 285's you made it more to float now. Basically look at it this way if I was to walk out the deep snow I would sink. No put on snowshoes I can walk on top of the snow without sinking in. This way I've been keeping the 235's on my truck. Way better traction on most road conditions. Now with the 285's you going to have watch your tire pressures more.
  10. Typically I do 120 foot pounds. Most tire shops are the same way using 120 foot pounds.
  11. The only code that it would be is MAP sensor. That is the only sensor it bypasses. Most likely a bad boost fooler.
  12. No, it won't. It about restriction the HY35W turbo is a 9cm2 exhaust housing max boost of 30-32 PSI where the HX35W is a 12cm2 exhaust housing and max boost of 35 PSI. Since the HY35W is more choked in the turbine housing its more prone to EGT issues regardless of the exhaust pipe size. Exhaust after that point has zero bearing being I ran 3-inch exhaust for over 12 years on HX35W turbo. Even upgrading to 4inch exhaust there was no EGT's change at all really. The biggest thing to lose EGT's is being able to advance timing with Quadzilla. Running about 19-21* worth of cruise timing I can cruise at 55 MPH at as low as 450*F EGT's and 65 MPH at about 550*F EGT's. Still in all 3 or 4 inch exhaust nets the same EGT's values and there is no real gain to 5 inch till you over 600 HP. Like I've got two turbos The stock HX35W (54/60/12) which stands for 54mm compressor wheel, 60 mm turbine wheel and 12cm2 housing. Then I've got the Hybrid 35/40 (60/60/12) which is close to most people favorites like a (62/68/12). As you can see they all are 12cm2 exhaust housing but flow rates are greatly improved. As for rebuild kits you can get them for good price from DAP. (DieselAutoPower.com) .
  13. I think that is the limit right about there at about 10k...
  14. I find that using the calculated method you can tweak the pressures and get more from your tires. Like my calculated front axle is 58 PSI and rear 37 PSI. For more traction, you reduce both pressures by 5 PSI. So now the front is 53 PSI and rear is 32 PSI. Another example on the scales with the RV.
  15. The timing values should be a spread of +3 per band starting at 16 is a good place. Something to be aware of as IAT Temperatures rise you need to retard timing. As IAT falls then you can advance timing. The only time this rule change is with the cetane rating of the fuel if cetane is high then you need to retard some regardless of the IAT. Because high cetane fuel ignites easy and quick so heavy advancement with high cetane is counterproductive.
  16. Tire pressures? Very common for people to overinflated their tires. I'm betting that you have your rear axle overinflated. Softer tires gain traction much better. You might want to check out this article.
  17. Bearing failed for the pulley. Low on oil that's for sure. Should of been about 5 to 6 ounces come out of the compressor. Just like @JAG1 he's got to recharge his A/C on his one truck the compressor is cycling way too much.
  18. Expansion of the fluid. Might want to pull the plug and check your fluid level and fluid color. It could be foaming up on you too.
  19. Stump on the red fir was not my cut it was already down. Now as for the area we scan the area and found a widowmaker hung up in another tree making the area unsafe for work. Being the last time I was out wood cutting was like 3 years ago. My buddy girl friend her Dad is logger as well she like just fall the Pondera Pine into the widowmaker and your area is safe. My cut wasn't the greatest but I managed to smack the widowmaker square on and put it on the ground. Made our work area safe but gave us more wood to play with next time. Sorry no photo of that...
  20. I know I've got to redo my set up. I've got to pull my bumper soon to re-work the plastics and then I'm going to pull the two pieces out of the bumper holes. Create a bracket extension and tuck my PIAA's back in deeper. The plastic trim in the bumper holes in just a PITA for making anything aftermarket to fit.
  21. Nice batch of red fir out of the black forest. We've even got our eyes on a few pines for next time. Looks like a short load but since Kelly mounded the pile tall in the front it's actually a solid 2 cord load really. Sad part is the soot and carbon dust is nasty.
  22. Timing for sure. You need to pull back some timing in that RPM range that it popping.
  23. That's even worse. I would just ditch them. The PIAA's I've got are damn bright for 18w worth of LED light.
