Poor gas mileage
Tires are too big. Plays a huge role in final ratio to the ground. With 35" inch tire your final gear ratio to the ground is 3.19 with 3.55 axle gears. This will make the truck struggle and create high engine load numbers. Engine load number is exactly how much fuel is being injected. The lower the engine load the better the MPG's. I typically cruise at 15% to 19% engine load. Like myself I've dropped from 265's to 235's to gain a small bit. Now going to be switch 245's which this changes my final gear ratio to the ground 3.69 with 3.55 axle gears. More said here... I'm aiming for the mid 20's again and close to getting there.
No traction on the boat ramp! What!?!
Now that I'm running a set of older 245's on the rear of my truck for testing. I've learned quite a bit. Final ratio is much lower it more like 3.73 to the ground now. This amplifies the torque produced considerably. I'm also guilty of the excessive tire pressure and the tires spin loose very easily. I need to sit down and do the math on the tire pressures. Tire Spec: 245/75 R16 - 3,042 pounds at 80 PSI Axle Weight: 2,860 pounds. 2,860 / 2 = 1,430 / 3,042 = 0.47 x 80 PSI = 37.6 PSI I'm currently inflated to 40 PSI and the tire is way too firm and slipping easily .I might drop as low as 30 PSI. I wouldn't suggest this with highway travel the lowest I might run with highway speed will be 35 PSI. As you can see my old aluminum mags on the back.
New Tire Size found 235's to 245's
You do notice that the nose feels high like the hood got a bit longer visually. Nothing super noticeable but still feels different.
The Future of Trucks
Record a MP3 of Cummins running and then burn it to a CD as a long single track. Then play it in your CD player on repeat... Cummins sound for a soundless vehicle...
Hello from the Gem State
I've done canopy camping and motorhome camping both. Both have a bad issue of once you get to your place you stuck and have no transportation being the truck bed is your living quarter or motorhome your living quarters and vehicle one on the same. This means if you want to travel and sightsee you have to pack up camp to even move. This is why I ditch my canopy and did a tonneau cover and sold my class C motorhome and bought a Jayco travel trailer.
HAPPY FIREWORKS
No, she'll be in bed by the time fireworks even start. Typically start between 9 and 10pm. She is in bed by 8pm.
Realizing that now. Still, in all, I love the final ratio it way better. This truck screams now. I had a 4th gen attempt overtake me on a merge and I outran him. No problem put a 4th gen truck in his place behind me. Acceleration is wicked fast now. Then caught up with a friend for lunch down in Payette and we left together I tried to power through a left turn from a light and the tires let go really easy. Sure is amazing how much more power can be put to the ground by ditching ONE INCH of tire height. I know why the traction sucks are actually two-fold. One is the tires are extremely old and the rubber is really hard. Then the other part is I did not do the math on axle weight to tire pressure so I'm most likely overinflated. Still sit here and wonder why the 35-inch and 37-inch tires are so popular. Steal the power, put more stress on driveline and transmissions. Etc.
I spend a lot of time running between Parma, ID - Ontario, OR and New Meadows, ID I'm sure at some point we'll cross paths. It can happen soon if you wish just call me and we'll make a time to meet. Typically the track bar and the tie rod ends are the biggest things. You can adjust the steering box to take out slack. Ask @Me78569 he's had one in his last truck. I'm going to follow your post on this being the highway salt usage is really high now in Idaho. You would want to talk to @cajflynn that covered 1.3 Million mile on a 53 block. @Dynamic is our site transmission guy that could give you an answer. Or @IBMobile for his lock up controller mod.
New Turbo Or Rebuild HY35
3rd Gen (2003 and above) just assume to have $4,000 every 100k mile miles to replace the injectors. So to make 1 million if it would make that far would cost $40,000... 2nd Gen (1998.5 to 2002) figure on having $1,100 every 200k miles for new injection pump and $400 every 100k miles for injectors. It been proven many times that our old 24V crossing 1 million miles so that would cost $9,500... Heck of a lot cheaper, in the long run, to keep your 24V then buying a CR engine.
HAPPY FIREWORKS
I'm supposed to haul up to McCall ID tonight to meet up with friends to watch the fireworks over Payette Lake.
Until I see an electric vehicle that is capable of covering several hundred miles on a charge on mountain roads without fuel... You could even throw the Toyota Prius on that 1/4 mile track. fine so the car can drive a quarter mile fast. So what? Will it drive 300 to 500 miles on an electric (no fuel) in a day on a single charge? I already know that this won't happen because of the federal fuel taxes. This is why the true hybrid are sold in EU and the wanna-be gas power hybrids are sold here USA.
Yeah, and it might be fouling my MPG numbers. Your comment stuck in my head and I happen to notice its leveled out. Lost the natural rake of the suspension.
ecm ground
Then W-T ground mod...
HAPPY FIREWORKS
M90 in the tail pipe. (Take Cover Smiley needed!)
More like 1 million miles if taken care properly. Like @cajflynn he the site million mile truck. 1.3 million be closer.
PCM Wire Tapped
P0234 is caused from a bad boost fooler. If the ECM sees boost over 20 PSI it starts refueling above 25 PSI the code is set.
Well just got full tank of fuel. Got to make it home yet. Then I've got 4th July party in McCall tomorrow. Then back to Ontario, OR on Saturday.
Talk about a huge difference 1 inch of tire makes. EGTs are lower. Engine load is lower. Transmission temp is lower. Exhaust brake performance is better. Brake performance is way better. Can hold 5th gear wider speed range. Acceleration is quicker. Less stress on the clutch during launch. Just in the 120 miles I'm loving 245's over my 235's. Very impressed with the changes. Now I'm having hard time understanding people with 35 or 37 inch tires with 3.55 gears. I'm going to start fuel logs on my next tank.
No. Experiemental testing.
PCM Wire Tapped
Suggest looking into the Quadzilla Adrenaline... Skip the Quad XZT. Way better tunning abilities and way better control of fuel, boost and timing. If the injectors have over 100k miles time to just replace them.
Like my new thread and the study of smaller tires. More to come... Like on the 2002 Dodge I'm pretty sure I'm going to change to the 245's vs 235's. On my 1996 Dodge I'm sure I'll jump for the 215/85 R16. Smaller the footprint the more pounds per square inch you get. So like on my truck front axle is 4,440 pounds so that's 2,220 pounds per tire. Then measure out the contact patch. Then you can figure out the pound per square inch of force down.
Not hard at all. I've run both the mechanical gauges which are just tubing for the boost and fuel pressure and then the electric gauges now. I prefer the electrics for the ease of install versus all the tubing worry about leaks and so people get carried away with stainless steel lines. I ran air brake lines for quite long time on my old mechanical gauges no issues. Now with my ISSPro EV2 electric gauges been troublefree. I like the idea of the programmable warning light and the programmable relay option. An example would be automatic transmission truck has the warning light set for 220*F and then the relay set for 190*F so it turns on a cooling fan up front. Like I've set up a remote sensor mount. This way if I'm questioning the pressure reading I can easily remove the sensor add a tee now stack in a mechanical gauge to verify the reading. This is much easier set up than the typical person that has the sensor in the intake manifold for boost and down at the VP44. The distance from the fuel source is a dampening effect and protects the sensor from damage. Even this setup is using 1/8" air brake line and PTC (Push To Connect) fittings with 5 feet of distance from the tap point.
How to test fan clutch?
Like me... Our fans normally don't lock up fully till about 205 to 208*F coolant temperature. The has to sustained temperature to get enough heat on the thermostatic coil to pull the fan to lock up fully.
What is the "BEST" engine oil & filter to use and why?
When I fire up I'm running 6 hours. I travel 250 to 300 mile in a day for the last nearly 2 years. Even in the past my average distance per run day was at least 100 miles.
2010 6.7 Running Hot
You might switch up and watch Pyro 1. Lets check and see if the large tires are not building more heat. Like myself I'm studying the effect of using smaller tires. IBMobile is right check for debris.the common spots is the bottom half typically can get block and you can't see it.
