The crf450ish random question thread.
Like myself I'm upside down. Obdlink thinks I'm consuming more than actual.
Dumped on
My system is similar but key feature is that power transfer happens at about 10 to 20ms from City to inverter. Also can run all key features of the house but using only 120VAC power and step up transformer. I might add the auto start to my generator allowing the inverter to stop and start the generator as needed.
Back up light mod (relay)
I'll never hang lights on the rear bumper. I've crush 3 sets off lights on the bumper. That's why mine hang on the rear diff. https://mopar1973man.com/garage/vehicle/101-2002-dodge-ram-2500/?show=mods&page=3
No Airflow from Dash Vents
Not in Idaho... Last time I stopped at salvage yard people were buying entire trucks before they hit the dirt. I highly suggest calling first and checking.
Cold... Very cold
Living room is above the garage. Wood stove just inside the man door of the basement. So your always getting wood for the stove out of garage leaving to door open and allow some heat out there.
Cold... Very cold
My problem is I keep my truck in a unheated garage and typically in the 40 degree range. Plugging in isn't need nor is grid heaters. Now no matter where I go no like right now I'm at Weiser, ID get breakfast and it's barely 13F outside. No where to plugin if I wanted. I'll get to my buddy place in Parma, ID and park the truck for 4 hours. I'm not going to string out a cord and us my friends power. Not fair or right.
Quadzilla V2 Custom Tunes
Actually I moved back to a linear step. Set you start and then step up plus amount. As for the exponential set you start point then percentage gain. Now step up one at a time it will calculate for each boost pressure position.
About had it with the Quad already
I'll take the blame. The whole idea of bridging the site store with another vendor was totally experimental and I was expecting weird issues. Like in your case the Quadzilla software was specified. I'm working with unknown territory so... I'm sorry it didn't work for you. Not to mention now that I tried to run VirtualBox on the laptop to fire up Windows 7 on it. It failed to start because the AMD-v is disabled by the BIOS and there is no way to enable it. So I wouldn't of been able to fix that problem with reflashing. Now if you already have a Windows computer you could of downloaded the flash here. https://mopar1973man.com/files/category/14-quadzilla-adrenaline-v2-flash-files/ Then picked up a Mini USB cable for less than $5 bucks off Amazon. https://www.amazon.com/UGREEN-Controller-Players-Digital-Receiver/dp/B00P0GI68M/ref=sr_1_1_sspa?ie=UTF8&qid=1514304541&sr=8-1-spons&keywords=usb+mini+cable&psc=1 Then @Me78569 has the full write up on how to flash your Quadzilla. This is now my 3rd Winter on the Quadzilla and now that I'm finally getting it all figured out it way better than the Edge Comp was. Better fuel control and now understanding how to do timing I can get back to my high marks this coming summer. Another 250 mile round trip for @MoparMom dialysis in Ontario, OR. I should have fun today... Quadzilla still set for level 3.
Cold... Very cold
Right out of the dodge FSM... To prevent engine from starting, remove fuel system relay (fuel injection pump relay). Relay is located in Power Distribution Center (PDC). Refer to label under PDC cover for relay location. Using key, crank engine over while observing gauge. Pressure should be 5–7 psi. Re-install fuel system relay to PDC. Start engine and record fuel pressure. Pressure should be a minimum of 69 kPa (10 psi) at idle speed. We all know that 10 PSI isn't enough at idle. I know the cranking pressure spec listed is actually a minimum of 7 PSI.
Cold... Very cold
Thermostat
After seeing that video I can for sure tell you that NAPA thermostats are NOT a fail-safe design that lock open.
Cold... Very cold
During... Here is a video showing the pulse on / off.. You will see the needle pulse with the on/off. Then when I let off the key the needle snaps to full 15 PSI which is full power.
Cold... Very cold
Exactly. 50/50 on and off. It's still 12 volt signal just turned off briefly.
Aluminum Transmission Pan Install
Good ol' Chevy trucks... You still have to love that old design.
Lost mpg
There isn't very much I would buy off of EBay... I've seen way too many people cheated there.
Cold... Very cold
No, there is just a modulated 50% duty cycle during cranking to reduce the lift pump pressure to prevent over advancement. Minimum cranking pressure is 7 PSI. Maximum cranking pressure is maybe 14-15 PSI. I know 12 PSI is safe. Wasn't sure what cranking speed was... but thanks... Might be interesting...
Dumped on
I got a white Christmas... As for the power side of things, I'm still slowly converting over to LED lighting. I just changed over the guest house porch light to LED 120w (24w LED) flood lights. Turned up the gain on the motion sensor and aimed the lights out more and increased the time on from 1 minute to 10 minutes being the power is fractional compared to the two 120w bulbs previously.
Cold... Very cold
Guessing? How fast would you say maybe 100-150 RPM cranking speed? Then you are attempting to compress cold air heated by the grid heaters. Then fire a shot of diesel fuel at 340-360 bar which will come later (how much later? unknown.) I know cold start wise the ECM wants to crank up timing but the modulated lift pump pressure keeps that from happening. Now that brings up a question? What is all your cranking fuel pressures? Might be pushing the timing up too much? Educated guess or trying to think outside the box.
Cold... Very cold
With the higher pop pressure I'm sure its retarding the timing more because takes longer to reach pop pressure now.
Cold... Very cold
Shower head injectors don't atomize very well cold.
Cold... Very cold
Yes, for the most part, the colder the detected temperature the longer it will hold the grid heaters. Very rarely do I cycle 2 times. I don't want to waste too much power heating the grid heaters. 195 Amps (both elements) for ~15 to 20 seconds is quite a lot power usage. Like I point out above. Ice is a bigger issue if there is lot of it. The only way to get around that is have the truck towed to a heated shop to thaw out and then have the fuel drained out and replaced with dry fuel. Antigel is another weird one too. For people in Biofuel states still have issues with biofuel separating and then solidifying in the bottom. To my knowledge, there isn't any product for that issues either.
Cold... Very cold
Simple question do you see fuel pressure? If not then the system is gelled or frozen.
Cold... Very cold
I know last winter I remember seeing temperatures down to -35*F in New Meadows, ID. Never had any issues with fuel or starting one bit. This year I've seen as low as -10*F already and expecting colder to come soon. Typically I don't use my block heater at all. Most of the places where I go don't have power for a block heater. This has never stopped my truck from starting even after parked in a field for over 8 hours at -30*F. The biggest thing is to have good strong batteries, good main cables and terminals and always parked the truck with charged batteries. Way too many go after buying huge 1,000 CCA batteries but have crappy terminals and main cable are rotten to the core. So its just as important to ensure the cable and terminals are in good shape. Just for information purpose, I'm only running 850 CCA Walmart batteries. Now like last winter I was helping a friend in New Meadows which is not exactly the brightest crayon in the box. He was all on top of making sure all the diesel vehicles had 911 Power Service and Cetane booster. The only problem is there is no product that I know of that will deal with large amount of water or in this case ICE. Yeap his 2001 Dodge Ram blew the FASS fuel pump fuse. Why? The pump was full of ice and locked the pump motor. His small tractor would not start? Why? The fuel filter was a block of ICE and so was the bottom inch of the tank. No fuel would flow. So as long as you don't have water or ice issues you should be good.
Lost mpg
Not sure but there is a few here with pop testers hopefully they speak up and where they bought the pop tester and adapter collar.
Lost mpg
Pop pressure tester can be bought just about anywhere. It the adapter collar for the 24V injectors that is a bit tough to get.
