Issues with Smarty s-03 Quadzilla stack
Right here in your settings... https://mopar1973man.com/settings/signature/
Stant or Gates Thermostat, any issues
Not that I know of.
NAPA thermostats all the way in my truck ZERO issues to date.
Where to find a Borg rebuild kit?
Return line gasket?
Front wheel cover/simulator/skin/hubcap for my dually
After losing 3 of the 4 wheels on my truck to cracking I sold the hub caps a while back to a forum member. I'm now on factory steel chrome 16x7 wheels with hub caps again. One ton is a different animal like most have said they typically get toss to the way side.
Miss When Warmed Up
@ThunderThighs we are curious of your status on your truck.
Lost mpg
Personally, I like the double filter idea the AirDog gives. So I've got a 3 um filter on the AirDog and then the Fleetguard 10 um filter in the stock filter. The Airdog is returning more fuel that the engine could ever use so the AirDog is constantly polishing the fuel clean. So when I'm changing filters at 50-60k miles now even the 10 um stock filter is dirty. So double stacking filters is a good thing to do and will protect the injection pump way better than stock filter could.
Need some quadzilla direction.
You could start with my Edge Comp look alike tune it will be a good starting point.
New Issue P0230 - What should I do next?
I've still got my 12 year old AirDog 150 going yet. Still holding 15-17 PSI of fuel pressure.
Injectors
Midwest injection... Personally I would want a Industrial Injection.
Injectors
I float 18-20 MPG with an average cruise speed of 60 MPH.
Injectors
There not bad. Just a bit lower in MPG vs. my old +50 HP from Vulcan. Clean up very well with the Quadzilla tuning. I want to tap the wire but I'm holding off till spring and then my one-year warranty on my VP44 is over and it's my nickle.
Injectors
No problem... I just thought it sounded too good to be true. LOL.
Quick alternator question
You might wonder the site more we've added a bunch more. Classified Ads, The store got more products, and I'm in the process of cleaning up the site some more.
We got them here but not quite 43 dollars...
HE351 swap
I'm running 7x0.0085 +75HP injectors and starting the Quadzilla at 80 percent.
Injectors
Shouldn't make any difference boost scaling is a wire tap setting.
Injectors
I would skip Edge Products altogether. Quadzilla is the most versatile tuner for giving you the most control over timing and fuel. If you want to have the same as an Edge EZ either leave the wire untapped or tap the wire and use level 3. Either way your limit to the CANBus only fuel. RV275 injectors are not bad nice pickup of power. We are all experimenting with larger injectors and pop pressures and see how far we can go with a clean burning engine. I'm right at 327k today. I'm not scared of the power as long as you keep below 40 PSI of boost your not going to blow head gaskets. I'm running +75 HP (7x0.0085 DAP Injectors) and the Quadzilla (Untapped). I'm only producing 30 PSI boost with an HX35/40 turbo. Eventually, I'll tap the pump again and go back to full power which put me at a max boost of 40-43 PSI. These engines will take quite a bit. The weak spot is automatic transmissions and clutches on manuals. I've upgraded my clutch to South Bend Con OFE.
I would bench test the alternator first thing to see if it passes. Then Check the blue wire in reference to GROUND. Then check the green wire in reference to POSITIVE 12V. Ohms value will be meaningless being your measure a variable resistance.
Thre is only the blue and green wire on the back. The blue wire is a constant +12V source when the key is turned on. The PCM varies the ground on the green wire. So if the voltage is getting low the green wire gets more ground. If its getting over charged then the green wire gets less ground.
Dumped on
Here is a recent power usage capture by Idaho Power. We are burning firewood and also using the heat pump as well. I leave the heat pump set for 72*F on the upstair floors. The basement unit is turned off. @MoparMom is a bit thin skinned so she needs the heat kept up a bit more. As you'll see I can still keep nearly within my 4k limit of my inverter for the entire house. Not bad... Most of the appliances have been upgraded to energy efficient, nearly all lighting in the house is CFL or LED now. Water saver faucets and shower heads reduce the amount of time to reheat the water heater also reduces the amount of power needed to pump water.
Dumped on
I've got to ask how big of a generator are you using? Then consider I run my entire house on 4kw @ 120 VAC. I use a step up transformer to make 220V for the well pump. I've got a 6.5kw gasoline generator. I can run the entire house except for the big items like dryer, oven, stove, and heat pump. My inverter will run my modified water heater (1,100w @ 120 VAC). Being I've got mostly CFL or LED lighting there is little to no load on the inverter. Middle of the day in normal city mode but using my small amount of solar power generated. I've got a total load of 6-7 amp AC at 120 VAC which is roughly 840 Watts. For my daytime consumption. I'll wait till night time and post again with my total power usage again.
Finally install airbags.
@AH64ID 3rd Gen suspension is way different than 2nd Gen. Kind of an apple to orange problem. Here is stock 2nd gen 1500. Yes it would squat... Spring leaves are a bit thinner. Same 3 thick but 2500 appear just a bit thicker. The bottom leaf on the 1/2 ton is for sure thinner.
Dumped on
Too cold for the RV. I would only have power. Not to mention I've got to monitor the house back home to keep it from freezing. So I've got no choice to do the round trips.Again I'm not complaining about the lack of snow. I'm glad it nothing like last year. Ugh!
Dumped on
Hidden in the back corner. It's in the photo. Just put on your glasses and zoom in you'll see it.
