Dumped on
I'm counting my blessing being I'm still doing the 250-mile round trip every Tuesday, Thursday, and Saturday for @MoparMom dialysis treatments in Ontario, OR. I'm not complaining one bit that there is a lack of snow. Like last night coming home, its was hit miss with rain and snow showers at 10pm at night. Get up this morning to a yard full of half melted snow and froze back up early this morning so it super slick to even walk on. PS: I love the wide angle view of my cellphone...
Dumped on
Man, I'm glad I've got my 4k Inverter and batteries. The only thing I can't power is oven, dryer, stove, and the heat pump system. After being 21 days without power during the 96-97 flood I'm ready for any type of failure nature can throw.
HE351 swap
Basically the same as my Hx35/40 hybrid. 60/60/12 my exhaust housing is larger.
Finally install airbags.
Mostly likely won't work. 1/2 ton springs will most likely be too soft and have a constant squat. I would do a 3/4 ton spring without overloads. I'll grab picture of 1/2 ton springs.
Door wiring for lighted mirrors
He's got to run a full lead from the marker light lead back through the door. The only thing I can think of is tapping in at the steering column. This would give both parking light and turn signal function. If it just marker light then you want to tap in at the trailer relay which is easy.
HE351 swap
Curious what the measurements of a HE351 wheel wise?
Qaudzilla questions
App just constantly runs and device never shuts down.
Thanks for the kind comments... I suggest you break down tasks into different topics and we'll all help you achieve your destination... Just like the tag line.
Article database... https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/
Basically in a nutshell, if you had all your OEM hardware you most likely wouldn't need airbags.
As far as I know, there is no lighted function for our trucks for mirrors.
Missing a lot of hardware from the stock spring pack. There is a top cover plate missing, overload springs are missing, bottom thick / flat spring is missing. Then even looking at this photo the spring is deformed past the left hand clamp of the airbag.
Source for a Fuel Module Bulkhead Fitting and Flex Tubing please.
Might go to his forum and post your comments there. https://mopar1973man.com/forum/151-vulcan-performance/
buffed my old headligts
Make sure to spray a clear coat of lacquer. This will prevent the lens from yellowing again.
Talk to Eric at Vulcan Performance. he would know. http://www.vulcanperformance.com/
HVAC Question (Heater Core replacement)
On a previous job, I used the same weather stripping tape just wrapped around the tubes to fill the void. Something that is wide but not overly thick.
Try Home Depot... Weather stripping foam. Go to NAPA and get 1/8" air brake line. It meets the requirements for that. Just use a small piece of rubber vacuum hose to piece together.
I just push the release tool in twist the two lines and give a light pull. The o ring might be dry and sticky.
About had it with the Quad already
Today every thing is slick in Ontario but Tuesday and back was good. Frosty in the late evening and early morning for my travels.
ABS light on. no interior functions
Works good in locks assemblies and doesn't dry out. Then exterior locks it keeps them from freezing in the cold winters. Even my gate lock get a shot of this because last week the ice froze in it and wouldn't open at all. Now no problems. Like I said...
Quadzilla V2 Custom Tunes
Arrrghhh! I've been running VirtualBox of Windows 7 for a long time but as of this morning, Microsoft detected a hardware change and locked my copy of Windows 7. SOB! Crappy MicroJunk software. I hate this about Microsoft product stupid activation locks that lock you out when you need to use your machine. At least Linux doesn't do this. Then Windows Crashed... Just flipping great... At least the Linux machine is still going. Now I've got to tear down the entire Virtual Machine start over and reinstall Windows, all the drivers, reactivate, reinstall all the software again. Big PITA for me. This one of the huge reason I walked away from Microsoft World back in 2012. Still, I would have to buy a copy of Microsoft Office Excel for one tiny tuning table... Rather expensive. Why not convert to Open Office or Libre Office which are free versions.
Found source for VP44 connector
I think so... I've not read the page yet. It would be helpful to have the tool for diagnostics.
Custom Quadzilla Tuning R & D Thread
Maybe I should get in on the re-popping too? Seriously if it was summer time I would I could down the Cummins and then driver the 1996 Dodge Ram 1500 for a week or so why the injectors are re-popped.
Not everyone has a dedicated device for this purpose.
Take some spray slicone lube with a straw and shot a good amount in the lock assembly. This should help a bunch.
