  1. I've always done my own clutch installs. I'm very critical about the torquing of the bolts, alignment, and even the installing of the transmission again. Alot of little spots where things can go wrong because of a poor installed clutch. For example I've seen shops force a transmission back in using the bolts. Not good.
  2. So far I'm happy with the iQuad v2 software. Been working on the cruise timing functions with @Me78569 and aiming for better economy on the highway.
  3. I'm still running stock 3 inch exhaust with a flow through muffler. No EGTs issues and good power. 4 inch would be good upgrade for 500 hp and higher. Being i dont produce high boost with normal driving or towing there is no reason for 5 inch exhaust at all.
  4. Marginal... Is it New or reman'ed? I always test my alternator before I leave the store.
  5. Single South Bend Clutch Con OFE Yes. No. Not required for the South Bend Clutch. I tow upwards of 10,000 pounds at times. Typically right around 8,000 pounds of RV. We are very close in modifications it should work just fine. That is 5 one-ton hay bails.
  6. Very bad... Normally good alternator is 0.01 to 0.03 AC volts. Diodes are cooked and the alternator is junk.
  7. Rare but I've seen things sold on the market with the wrong size o-ring cross section wise was large enough.
  8. Always dampen my seals with a bit of diesel fuel before even installing on the the lid. Previous filter change after 52k miles or so. Stock 10 micron on the left and the 3 micron Fleetguard filter on the right.
  9. Electrolyte will only freeze if the battery is dead. As long as the battery is charged up the electrolyte can't freeze.
  10. While the fuse is out and field leads are unhooked you need to measure the AC noise and try to isolate the device creating the noise. This is true. But these were all gasoline engines. Now diesel is way different where the TQ comes on very low in the RPM span and pump pressure of the transmission are very low. Where gasoline engine never made torque till high RPM's. Lockup was to reduce heat created by the shearing of the ATF in the torque converter since its locked its just a solid shaft so no heat produced. Just my 1996 Dodge 1500 5.9L V8 with 46RE if I keep it out of lock up it will jump right up to 200*F in no time at all. Once it does hit lock up the trans temp falls like a rock. I've got a few grades I've gotta watch to be sure it locks up in 3rd. This is only 5,500 pound truck not towing either. https://mopar1973man.com/garage/vehicle/102-1996-dodge-ram-1500/ https://mopar1973man.com/garage/modification/232-46re-transmission-rebuilt/
  11. Like I just bought another bug forward for fly by wire cruise control folks. I found that cruise timing is flat as a rock and doesn't vary at all. So at 40 MPH or so it kicks into cruise timing and holds the exact same timing all the way to 80 MPH like an old P7100 pump. This doesn't work for the economy purpose at all. Part of this problem is the TPS signal is ZERO during cruise control so the Quadzilla just holds cruise timing all the time even if the truck starts climbing a 6-7% grade. I think there should be a certain amount of retard vs boost too so as the load comes on, boost rises the timing should start to retard some too hopefully to keep the efficiency up.
  12. You might have done damage to the PCM. Never short these leads together. Did you leave the field lead unhooked and the alternator fuse removed during your test drive? Good way to burn up the torque converter and transmission. Still you need to find the source of the AC noise. These kinds of band-aids is what kill the ECM, PCM and VP44 because the ultimate source of the AC noise was never found so these computer get damaged.
  13. I'm running a straight flow through 3" muffler. It really can't be heard in the cab. Outside its very mellow sounding. I ran straight pipe 3" for a very long time but wen I started towing long distance the drone was a new problem. Now just adding the flow through 3" muffler the drone issue is gone. Still zero restriction like a straight pipe but without the noise. https://mopar1973man.com/garage/modification/229-straight-pipe-exhaust-with-muffler/
  14. Currently, my AirDog 150 is the 3-micron filter. I'm going to change it to 10-micron filter then it's filtered again on the stock filter which is again a 10-micron filter as well. So I'm double stacked. Filtered the first time at the AirDog and second time at the engine on the stock filter housing. I don't even worry about it. I've already researched all my local fuel suppliers know what their pour points typically are. They are typically much lower than what going to have for weather. In 15 years of driving this Cummins I've NEVER gelled once. I don't use any pour point depressant additives (anti-gel) or cetane boosters. My coldest day so far has been -31*F and no issues.
  15. Like even with my Donaldson filters I'm running that are listed at 3 micron are a filtering in the cold it pulls the fuel pressure down due to a restriction of the filter media itself. Once the fuel temperature warms up to about 50*F the pressures are basically back to normal. At 3 microns I'm filtering out red blood cells and white blood cells. So any wax starts to form its takes very little to start plugging up the filters. Like myself I'm thinking of returning back to 10 micron filters and just run double stacked like I am right now. This is my last 3 micron filter at the moment so when I re-order I'll go back to 10 micron. 10 micron = 0.000393701 Inch 3 Micron = 0.00011811 Inch That's a difference of... 0.000275591 (or 2 tenths of a thousandths)
  16. Look under the carpet for the plug for the power seat see if its even there. If not you'll have to change out the cab harness to add the feature. I know the fuse panel in the dash would require a circuit breaker for the power seats. Personally I would avoid the power seat function. So far every vehicle I've owned has had the power seat motors fail at one point or another and very expensive to get replacement motors. Even all the trucks I've worked on about 75-85% of the power seat truck have failed motors most like the forward to backwards. Even my current 1996 Dodge Ram has a failed motor in the power seats (gear broke).
  17. Some folks have lost the size comparison to microns. So as a refresher...
  18. Read up on this... Monitor & Set Conditions Vehicle Speed Sensor (VSS) signal is monitored when no VSS DTCs or Chrysler Collision Detection (CCD) errors are set. DTC may be stored when CCD vehicle speed indicates greater than 20 MPH for 2 seconds, ECM vehicle speed indicates less than 10 MPH and PCM does not receive a VSSsignal from Controller Anti-Lock Brake (CAB) module. My first though is to check for excessive AC voltage from the alternator. If there is excessive AC noise it could be fouling the CCD network and the computers are not seeing the speed signal correctly.
  19. I'm still using a older Fluke 75 with no issues other than my probes are getting rather wore out.
  20. Some say the Cummins water pump is the best. I'm still on the OEM water pump and closing in on 283k miles and ticking with it. No issues. The magic bullet that I know of is going to make sure the cooling system is completely flushed out and clean, and new coolant is used. If you just reusing old coolant it might have enough debris in the block killing the seals and bearings in the water pump.
  21. OMG... Man I remember that name well. One person I never got along with.
  22. Remove the alternator fuse and disconnect the field lead go for drive. If the problem is gone the the alternator is bad. If it still there the a.c. noise is coming from another device.
  23. Some say only automatics. I personally say it can include manuals.
  24. Edge tuners have boost fooling even turned off. Remember it just stock fuel map at that point so fuel is going to limit out on the top end anyways with the tuner turned off. Unhooked then is different story it Will be without boost fooling.
  25. A/C will not have an impact on AC Noise from the alternator.
