Odd injector misfire
I've got a intake manifold gasket set coming to the shop. Mostly likely get it when I get home.
Fass or Not
If my AirDog 150 dies I'm going for a full FASS 150. But I'll call Eric at Vulcan Performance then order me a full fitting and hose kit for remote mounting the pump. I will install the FASS in the bed wall. This will allow for guarding the filters, keep the filters out of the direct cold wind and keeping the pump close to the fuel tank.
what are the proper step by step to increase Hp
235's or 265's work really good with 3.55 gears. As for Craigslist you get what you pay for. I would always opt for a vendor over EBay or Craigslist because if there is any problems with your purchase then at least you get support. With Ebay or Craigslist you on your own and might not be able to use what you purchase.
Loss of power... Out of ideas need help.
That's what powers the computers here. (Green powered network here!)
Cross over tubes done today. Sounds different I didn't notice any misfire on the way home.
No. Just the one near the thermostat. The 12V had the temperature sensor towards the rear of thee head.
Here is my youtube of injectors cleaning... While the injectors are out you could pull the cross over tubes and verify they are not plugged up too.
Other Generations of Dodge with loose - goose steering?
Even my old 1972 Dodge Power Wagon has excellent steering. But I've always been picky about my vehicles. I drove a old 1971 Ford Pickup for a glass company that was so washed out that it was like 90* of steering wheel to change. Talk about swinging the wheel back in forth. It was so bad that I nearly cause a accident on the 405 freeway heading to a job site. I told my boss I would never drive that truck again.
Error codes? Is there any current codes? The check engine light doesn't have to be on to have codes. How old and how many miles on the injection pump? Is it still under warranty? I want to see if the option of replacement is still open if there is damage.
Dash cam
I'll run him over. Then I got a trophy. Heck with the camera I want the really deal. Even if the truck takes a beatin'
He351ve stand alone Arduino controller code for 2nd Gen Cummins
I found out that accurately the number is lost after about 35 PSI or so. Changes from sensor to sensor. You might want to compare a stock sensor to a mechanical gauge and just for fun.
Need some help please!
Did you assemble it the proper order? Lot of people get too quick to torque the injector down before allowing the crossover tube to be seated properly. It might be weeping pressure inside the return rail where you can't see.
Dyno!
Call Eric directly and ask him.
Dyno!
All I can say is the Smarty I got from Bob Wagner was back in 2006 when I borrowed it. It was great on the low end but got very flat on the upper end with or without my Edge Comp. Then I remember all the dyno runs and people stacking Smarty with other modules and always complaining about Smarty being flat on top. So the only thing I can say is something has changed. I'm not sure what but its change in the software. I really wish that Smarty UDC would happen for the 24V's then I would be all over it. Because then I could build a good base software for the Edge Comp to ride on.
Waiting for the Blizzard...
Heck by this coming weekend we should be in the 55-60*F temperatures. I'm gearing up to have the RV ready by this weekend and "hopefully" be able to take off for a weekend.
High idle kit problems
Diagnostic... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/64-mopar1973man-com-high-idle-kit/53-high-idle-mod-diagnostic
Dyno!
You can't have mine... Talk to Eric at Vulcan Performance! Comes with o-rings!
EGT Gauge Help
Toss them on the classified ads. I'm sure they will go quick.
Harbor Freight Solar Panel Kit
Heck that picture I would lay in my chair watching TV and every time I seen the battery volts dip below 13 I could tell the shadow was being cast on the panels so I would just pick them up and place them back in the sun. Nothing hard or crazy.
Afternoon ride
Ummm... I haven't been fishing since 2004 don't have time for it. Heck this is the first ride on the ATV outside the yard in over a year. I don't have time usually. Make you think more the oil change light on the ATV automatic comes on every 600 miles. It's been over 2 years since I last seen the light.
Dash cam
Impressive little camera. I can see how a camera like that would help in insurance claims for you in a large city. Me personally the only thing you see is lots of highway and no action.
Afternoon ride
I tend to agree but that gives the USFS a reason to use the "Smoke Jumpers" which cost big money. I personally think is a lame idea being they are jumping in with limited supplies. Wilderness Area is the Land of No Use.
I found that proper tire pressure makes a difference in steering. Like I've been calculating by weight. Now knocking -5 from my calculated pressures made it bit more stable tracking. Some others like the heavy camber IIRC. Some truly have broken or wore out steering parts.
Spuratic fuel pressure
Check your voltage supplying the pump make sure its stable. Then check the pressure regulator make sure its not hanging up or the check ball jamming into the spring. (If that what you got).
Problem is I park the RV in the shade to promote cooler interior temperatures. Then I place the solar panels out in the sun to charge the batteries. That way I can have a cooler living space and power to enjoy nice things. But if the panels on the roof then, the RV is roasting hot and you've got power but too bad it's only 90-100*F inside the RV and no Air Conditioning. Yes I've seen that happen with my RV after travelling most of the day in the sun the living quarters is 90-100*F inside. Not a good example but you get the idea. My panels are small enough to fit under the bed.
