Quadzilla Adrenaline V2 Testing
yes, but with me it just happened out of blue, it was at 0 I could of swore and then I got on it a few times and noticed that it would stay at 2psi even with the truck off.
Just flushed new tune on and still 2 psi, but sounds like I'm not the only one. Another thing is i wanted to reflash it again and it can't find module now. Tried restarting everything and no luck, keeps saying can't find module.
Is this flash updated with your new wire tap update? this 2psi thing started after some hard driving with new v2 flash (your first v2 flash available to public), I thought boost sensor was old and something happened to it. I'll try this new update and see. Thanks.
Ok got my adapter from genos the other day, changed my map/boost sensor and quad still says I'm at 2psi, what else can cause this.
Rear view camera and head unit options
Sorry not sure what happen there they worked earlier, here is another one https://www.amazon.com/Rear-View-Safety-Display-RVS-770613/dp/B002GM5GKO
Steering Gear Box 2nd Gen
If it just started leaking you can add some fluid and get parts needed in mean time. when you have all of the pars you can plan some time to do the job. you can ether rebuild it or replace it depends on how good you are with skills. there are some threads here on ether or, someone else more than likely will provide them. I also had good luck with Lucas stop leak, but will only work on small leaks and I don't recommend leaving it in system for too long. when you fix your problem flush steering system out. good luck.
I like this one http://m.costco.com/1-Backup-Camera-System-with-7"-LCD-Screen-by-Rear-View-Safety.product.11526596.html as it looks like quality buit, this will definitely be considered, thanks. the ones I looked at were cheap on Amazon and people having problems whith. Just ordered this one https://www.amazon.com/gp/aw/c/ref=navm_hdr_cart We'll see how it goes, now just thinking on camera place, on topper or under bumper. and screen place, I think down low by 4x4 shifter, and have it on tugle switch .
The time has come to produce the Mopar1973Man High Idle & MPG fooler switches again.
My guess is coolant temperature sensor or maybe just programmed into ecm
Looking for options on the rear view camera to help with trailer hookup and general use, please share your thoughts. Some options may include: navigation, Bluetooth, etc. Looking at multiple options as I need a new stereo also, that has usb port for music and Bluetooth for phone. 1. single din flip up screen. Not too many choices for quality, mixed reviews, screeks break. 2. double din. More to chose from, even android auto for qwadzilla tuning, but lots of work on dash. will kill many birds with one stone. 3. rear view mirror replacement with another one that has a built-in monitor, and get a regular cd player that has usb and Bluetooth. 4. separate monitor and camera set up and get a regular cd player with usb and BT There might be other ways, if you have something already please share. and also if anyone is using regular cd player with usb and BT for phone, what model#etc and how you like it. Thank you all.
My local Cummins dealer is useless, most of time I tell them what I found out and then they can help. When i got my sensor few months back that's all they gave me, never even mentioned this adapter. No I called them and said I need an adapter, they had no clue, I told them what I knew and the guy called me back and said yeap found what you need. End of conversation. Then it was basicly you want it or not, can have it next day for only $30 in freight, or wait till cows come home, and we'll call you. So Genos it was.
Running out of fuel and 1/4 tank issues on hill
In my opinion its best to modify your fuel basket or just buy one that's already done from vulcan (costed me about $70 to do it myself, buy a draw straw 5 from vulcan and make all of the mods to basket your self(it also depend on stile of your basket, it may not work and you need to buy one)). Reason I like mine is if snow bank or whatever hits bottom of the tank,1 I'm not losing sump and all of fuel,2 if tank gets pushed inwards basket is spring loaded,3 fuel gets returned to basket so you always have some in there, I know that it doesn't help heat issues to recycle fuel out basket but if for the most time you keep it a half or better, I don't think heat is an issue. But the time you do run low on fuel it's there.
Just found the boost/map sensor adapter for 2002 model. cummins #3104228 got it from genos for $26 shipped. local cummins can get it for $19 plus tax but wanted $30 for freight or 10 days no freight.
One thing I forgot to mention is I also have a Turbo symbol above a needle and it's yellow what does that mean, is that a part of having a faulty map sensor
ATF in fuel
Reality is not what it seems ether if you dig deep enough.
I take it that the one i got is 01? Where do I get an adapter,
Man you guys are .... funny least to say, I take it I need a new sensor then, luckily I bought one so I have it but not so lucky it's a wrong one, got it from cummins, gave them engine # and paid like 90 buck I think, so hoping they will exchange it for a right one. it's been few months now. The one I got is 4921505
Thinking seriously about twins
I was just going to say, you have to get her in the right position and then you never know.
Did some harsh testing this weekend , still have the engine intact , but my boost sensor is reading 2psi minimum. is it just time for one ? or how can it go bad with you guys running 60psi or better, I hit 45-47 max which is a bit much for a stocker. I cleaned it but it doesn't change still reads 2psi, from there on it matches my mechanical guage.
Squeaky Clutch Pedal
I quit using wd40 once I discovered PBblaster, never looked back.
Birthday present came...
Love the surroundings
Does it have to be android auto
Yeah 3rd Gen have a lot more room, I'm debating if I want a flip up as it fits fine or make a bigger hole to fit the newer stile one's So did you download quad app directly to stereo or is it conected through phone through Bluetooth
Anyone ever put flip up screen car stereos in their truck, I'm looking at on at Walmart for 150$ it's a toch screen and has Bluetooth an option for back up camera that I always wanted for hooking trailers, hands free calling etc. I'm guessing the app for quad on my phone will appear on screen? not that bright on stereos, any input will help. Thank you.
Killer dowel pin and type of blocks
Here we Call it Mikes vent mod, there is a thread here somewhere, basically it's a 3/4" pvc pipe that goes over engine and dumps someplace behind starter, especially important when going down steep grades, as oil can dump out of factory design.
