Vp44 would this issue guys
Definitely repair wiring as needed
Quadzilla Adrenaline V2 Testing
I have another question according to quadzilla level one was Max mileage and it was all done with timing I assume it Advanced timing now with fooling IAT to 143f it retards timing can someone explain that please. I now Drive about 180 miles a day for work I've been experimenting with different levels and miles per hour, I can tell the difference when I tugle between fooling IAT and using IAT, and using level 1 you can hear higher pitch coming from motor I'm guessing the cause is timing. I have comp 1000 tune which came when I bought the unit. Driving 55 on level 1 I got right at 20 mpg, driving on level 3 I'd Got 19.5. I am not trying level 1 without fooling IAT For more timing, 55mph is at 1500rpm,
Pictures will make more sense to everyone here.
I'm assuming psi is boost? And a general question, is new qwadzilla same as old from few years back before they went out of stores? Or does it have more abilities to tune?
MPG questions
Need to put this engine in a prius and see what kind of mileage we can get
1/4 inch airbrake line for fuel pressure gauge
You guys over thinking it, use a niddel valve and get your pulse frome vp to minimum and if you get a leak jump out and shut off the valve. I used 1/8" line and quick connect fittings, and ran the line through an old 1/2" fuel line through firewall and it fits perfect over quick connect that's on the guage, so if my fitting does leak all of the fuel will dump out 2" pass the firewall and dripping on the ground. Plus it's like a conduit for the tiny plastic line, less chances for it to get cut.
wipers don't park
Local Carquest has it for $70 lifetime warranty I'll give it a shot.
wipers don't park
Has any of you had this problem? My wipers don't park back to normal position after using washer fluid function, and also the intermittent selection malfunction sometime. I'll set it to low speed but it will almost be on high and sometimes ok. And for the wipers to be at park position, I have to catch them at that point and shut the switch off. I had similar problem happen on a different vehicle and after changing wiper control on steering wheel it didn't help and ended up being a wiper motor. Where should I look first? Thank you.
Goodbye Edge Comp, Hello Quadzilla Adrenaline
So how much is new quad different from old? All together or somewhat similar
Truck stolen
UN and nwo, that's their hope. Too bad it will never work for thsee bastards.
Truck stolen
This society is pretty screwed up, I keep want to take my truck to Canada to go fishing, but every time I chicken out. It would sit for a week all by itself in middle of sh.thole town where locals don't have much for jobs and all of their yards look like sh.t. full of junk. There are few of them known for stealing but other are scared of doing anything about it. So we end up taking suburban most of time. People I go with make fun of me for not taking truck but they have no clue and are not willing to think. They're fun fishing with thought.
Control arm bushings
So caster meaning you want to make lower control arms as long as possible? When you do this adjustment do you need to lossen all of the bolts on both control arms? So you don't have exes pressure on busings?
Truck stolen
I like your idea the only problem I see these days with cordless tools you can have that thing cut in half in 30 seconds
Truck stolen
Can you show which wire please, I think you have in a past.
Truck stolen
I thought it would still run even without the fuel pump, because vp has internal pump? Unless you're talking disabling vp. What about fuel shut off silinoid in line somewhere and a switch, then if they start it it will only run for a little and die and then you'd have to figure out why it died and bleed lines. Just a thought.
Truck stolen
I feel very angry and frustrated, I'm sorry Tyler.
Torque Converter Lock / Unlock Issues
for a truck that is very anal about battery cables and wires in general, your cable need some cleaning.
AC stuck on defrost
I had same thing happened with my ac drain, it came back in the cab, I put a clear hose on a drain nippel and zip tide it to some hoses or a brake lines by control arm, itso crazy home much water comes out of it.
2016 Silverado Mileage
Maybe that's why most cops won't even look at you going 5 over, and a lot of them only do something if you're 10 over. Maybe it's been in Cort before enough time.
Not to burst anyones bubble, but I heard some car manufacturers got cut lying about mpg, even though your hand calculating might be right on, what they did is messed with speedometer just enough to make it look like you were getting good mpgs. Plus waranty runs out quicker. Just a rumor that I heard, pretty sure they talked about it on tv a few years ago. Check it against a GPS on higher speeds, see how close it is and maybe with some one next to you going same speed that you know and compare. If it's of any interest that is.
A fruit of labor
Sad to say but more than likely your ground water comes from far away, it would take a combined effort of everyone to make a difference. It has become a problem where most farmers over do on chemical just to be safe or too lazy to do soil samples to see how much crap they really need. Whatever government is doing to dumb us down must be working, because people are getting dumber and dumber and very little common sense left and values. I'm truly scared for future of my kids, and what they will be dealing with.
Teardown and Rebuild
I had good luck using lime away to clean rims and caps,
You know what, I meant to say Taiwan not sure where Mexico came from, so this confirms what I thought, if they have indents in them then it's Taiwan otherwise USA. Taiwan from what I hear is better then China quality wise, at least for parts.
Fed up
Unfortunately votes don't count anymore and haven't for a while and presidents are selected and not elected.
Oil Filter
I think some guys in racing use these type of filters, but they change bearings and other things every so often, I wouldn't think it's a good idea for daily use.
