Dieselfuture
  1. I don't have any experience with compounds, other then if someone gave me a set I would definitely try it out I have a custom built hx35/40 to 62/67/12 and it does great with 7x10 and quad. Good luck on your setup.
  2. I got a 4" downpipe that starts as a 3 at turbo then 5" all the way back with a muffler I think, I don't want to chocke it if I don't have to ( no funny chicken jokes here ). If fte offer a 5" I might try it out. I think my truck been getting louder lately or I'm getting old like @Evan how does Donaldson compare to fte? Does it have performance in it's mind at all or just aimed at reducing noise? I usually don't but been driving so much lately, I just want to get where I'm going and don't really care about mpg and my brain, all though it be nice to get around 20 going 80 and not be brain dead by the time I get where I'm going, or I'll never know why I went there in the first place
  3. You guys are going to make me get a 5" x30" resonator and try it out. I can't hear myself think if I drive over 80
  4. https://www.google.com/search?client=ms-android-verizon&ei=BWZLXrmFMMqxggekoq_IBw&q=car+relay+with+diode+or+resistor&oq=car+relay+with+diode+or+resi&gs_l=mobile-gws-wiz-serp.1.0.33i160i395l2j33i299i395l2.43795.47627..49195...0.1..0.135.936.0j8....3..0....1.........0i71j0i22i30j33i22i29i30i395.zvEb0JFZk_I
  5. Coat hanger for shocks, not sure if you can rent a spring compressor at parts store.
  6. I know nothing about these stoves but the one you mention sounds simple. If it worked for him I'm sure it'll work for you. Give you a reason for a road trip.
  7. you reminded all of us why we try to do everything by our selves. After all them chicken jokes you better Something like that, I never had to disconnect my sway bar links, but I was only swapping to a stiffer spring not extending any higher. I did take shocks completely out as I changed then at that time to bilstein's.
  8. They do but they can be dangerous, I changed my springs to plow ones when I built my front bumper and they came out just fine by loosening the shocks and lifting up the body. Thinking of it, just put a heavy bumper on it and it will lower it an inch.
  9. Eat more chicken I would, they don't cost that much, be quicker than modifying.
  10. You're not stealing anything feel free, this thread is like 8 years old now. Which is crazy all on its own. You need a timbo apps, must have.
  11. You can still use that terminal at PDC for other devices, just use another fuse appropriate size to device or 140 may not pop but you wires will melt. I'm using it for few things, like fuel pump and some other things I have on truck, combined fuses amp I'm around 40. Don't mean to confuse you any further
  12. I'll disagree and say it happened of old age. Seems a lot of hg failures lately. All trucks are getting old. Jmo
  13. They sure do, I was just giving you crap.
  14. Walmart batteries work fine if you maintain them
  15. If someone didn't blow all the money on lights
  16. My gauges are like @dripley but I put them more in my face. Old pictures, still looks the same
  17. I would spend the money on studs and skip xh40, save more and get something like 62/68/12 or 14 s362 I believe. For now guessing you have xh35,?, 100hp injectors and qwadzila will be pretty fun too.
  18. Make sure you're buying a protective relay, with a resistor or a diode on coil side, it'll be in the diagram on top of relay. This way when it denergizes, current spike doesn't get backfead to ecm. You can slide pin connectors out of relay plug and see if they're corroded. I use dielectric grease on all connectors never had an issue in long run.
  19. Can't argue that, them po's I tell ya.
  20. https://www.amazon.com/Gasoila-Soft-Set-Thread-Sealant-Paste/dp/B00CRKWAXQ
  21. I had my hopes up, as mine is also a bit crunchy in 3rd. Been this way since I got the truck almost 10 years ago, some day I'll fix it, maybe, lots of maybes in my future.
  22. That's only to trigger the relay coil, I suppose if it was intermittent it could cook the coil. Have you taken a bad really apart to see what's cooked?
