mopartechnician
Everything posted by mopartechnician
  1. Its deleted so he isnt going to regret that. I would be asking questions on why he wants an older vehicle. Who knows, he might like that body style
  2. Deletes are night and day difference. Every one i have done the customers all had smiles on their faces
  3. I always did 12. Never had one single problem. 3 gals is way easier than to have qts laying around
  4. Every cummins in dodges are 12qts
  5. Ive bought a couple pdf files for misc chrysler vehicles off ebay and they are exactly like the factory manuals
  6. Im not a fan of edge but those cts' are awesome
  7. Still going good. Gotta put a timbo on it this week so im gonna test fuel pressure drop. When i was checking codes you could still barely hear it run
  8. You can try soldering them but they arent replaceable (ask me how i know)
  9. Uh smarty on a 3rd gen is insane. You have over 200hp more than a 2nd gen even with comp. I dont know whats wrong but it should be night and day difference. There are two "programmers" that are king on 3rd gens, smarty and efi, this includes any chip. I had a customer with a bully dog go to a smarty and he had a huge smile on his face on even the lower settings
  10. I found one for 700. Its called a torque convertor cooler
  11. I would keep it. A 1000 dollar heat exchanger is cheaper than a 4k trans. I cant believe that its that much
  12. Filter should be changed anytime oil is changed and is cheap enough that any time pan is dropped. The drain plug is for easier drains
  13. Yep those are the ones I use I think the "spin on" thing has been brought up many times. I cant remember why it always gets turned down.
  14. Drain plugs are easy to install and pans are easy to drop
  15. Nothing wrong with the stock filter. Propper oil changes, band adjustments, and keep the tans cool are key
  16. Sweet. I had my filter guy price me a donaldson and he was told that donaldson is having big issues with warranties right now. Cant remember what it was exactly but something along with issues with people running extended mileage on filters or something What method are you using to get your samples? I get sample kits cheap so i might sample every filter change and obviously every oil change
  17. Not to side track, but do you guys like your frantz bypass? Im thinking about getting one but heard its hard to find the right rolls now.
  18. From what I read, the lf9028 is like having a by-pass system in one filter, correct? Ive been running the stratapore but might switch to this and see how far I can run dyno oil
  19. Clean the plug and the pan around the plug with a regular paper towel. Dont use any cleaners. Drop the plug then get three different samples of the draining oil into your sample bottle
  20. Browns diesel builds goerend trans for dave
  21. Best tips of all, dont idle, if you have to idle turn on the high idle function and always run exhaust brake even if not pulling. Also if you can delete than do it asap.
  22. No gains at all. Dodge wanted it added to stop any customer complaints for turbo whistle
  23. Ok maybe this is different than the one i was talking about
  24. http://en.m.wikipedia.org/wiki/Technical_Service_Bulletin
