Everything posted by dripley
Crankcase breather
Vacuum line for sure.
Quadzilla xzt
You would be surprised at what set of new RV275's would add. A little extra mpg over the oe injectors also. I good investment for the power.
Vacuum pump/Power steering question
I agree with @Dieselfuture. The pump is easy to reseal and clean up if necessary. The PS pump and vacuum pump are just bolted together. That little line on the passanger is the main feed for vacuum to the hvac system. Mine broke and I wish I had replaced it when i had the hvac box out. If it breaks again i will have to.I think the line gets brittle being close the turbo.
Codes and more codes
If you are hearing a relay click when you turn the keyyou already have a relay installed similar to the one in @IBMobile,s post. There is no oe relay on the truck. The lift pump, stock, was powered straight off of the ECM, no fuse no relay. Also if you are hearing click it has power to the relay. If you can locate the relay the oe harness from the ECM should be plugged into it. Thats where you should be checking for power from the ECM. If you have power there your problem will be after the oe harness.
The crf450ish random question thread.
I would agree. I checked them about 3 months and they were still tight and I have no vibration while driving.
Pilothouse/RAM3500 build
Still enjoying the story.
I am still on my oe drive shaft u joints. Non greasable and 433k miles. Swapped my front ones out about 30k ago. I have 3 old new stock non greasable for the drive shaft this summer. My non greasable oe tie rod ends on the front lasted 240k before replacement. I am non greasable all the way as long as i could be assured of the quality of what came on the truck. Not sure how to find that however.
Crappy Weekend
Something to be aware of if replacing any underground pipe with PVC is there are 2 different kinds. One is solid PVC and the other is Foam Core PVP. The foam core is good for sound reduction of the water passing thru from one floor,to another. Many home stores stock it and you have to look at it close to see it. It is labeled but look close when buying. The foam core only has two thin layers of PVC over a foam core and looks just like solid PVC from the outside. I don't think the foam core will hold up to aggressive drain snakes as the solid will and the cost difference is neglegiable. Also Mike very sorry to hear about your troubles. All my sewer problems seem to happen on Sunday as I am preparing to head back to work.
2002 Dodge cummins programmer
I had the in tank pump conversion from Dodge many years ago. In about a year I started having problems. Turns out the pump was only putting out 5psi at idle and near 0psi under load. Unless those pumps have greatly improved I would think twice about. Vulcan performance has a Jeep Liberty fuel module that I believe will do what you want for fuel pick up and the gauge. As far as a fuel pump goes if you remain stock a DDRP could work. If you are adding a programmer, go bigger. AD or FASS or one of the mechanical pumps out there. You will be sorry if you add power with out sufficient fuel delivery.
A/C leaking
I should have seen that one coming. I import my beer from NC to Maryland, to darn expensive up here. It is free at my house, tomorrow.
A/C leaking
Let me know the beer arrives, would ya please?
Oil pressure drops when temp gauge goes up
Same thing here. Just the way it works.
- Hello
- Hello
Extreme Miss/Nearly dies
The beauty of it is Alabama will warm back up just like here in NC. I work over a pretty wide area of the country and have never had the fuel gel either. I am usually buying fuel in the areas I work so I am sure I am getting some winterized fuel. The only thing I have ever added to my fuel is 2 stroke oil and did not start that until the truck had just over 200k on it.
High amp alternator
I was thinking of going the nation's route myself until reading all of this. It had me .
High amp alternator
Sounds good but I bet it is pricey.
Clutch and brake Pedal pads
Yes.
Rock Auto has them.
Light Bar Battery Source
Got a lot that stuff out my way. They pretreat the roads with it.
24v getting shitty fuel mileage!
Time for some injectors most likely. I swapped mine oe for RV275's and pickup about 1.5 mpg. I have 50's in now and did not see any drop. You have a lot choices with the quad and I defer to those smarter than I for advice on size. Your tire and wheel combination is not helping. They are taller and wider than the stock tires. The taller and heavier they are will detract a good bit from your MPG. I am running stock 265"s on alloy wheels and a Comp and getting 19.5 on the interstate.
Died after installing Edge
Details details details......
A couple of issues I had predated the wire cutting. I only cut the wires on the advice of Chip, against my better judgement, I sure felt like he knew what he was talking about. Some other issues seem to move around. Like wac-a-mole. But I'd agree with @mopoar1973man about cutting any wires. Don't unless there is no other choice.
Parking brake failure
One of my wife's girl friends was going to use my 69 chevy one week end. She came got the keys and started it up. She came back in the house tolet it warm up. I went a few minutes later and no truck. She did not set the brake and doown them drive way and into the valley. Can't believe it did not hit a tree, just parked itself.
Careful parking comes to mind.
