Everything posted by dripley
Ethanol Side Effects
How bad has it driven up feed costs? And how far has feed cost driven up the price of meat? Maybe you save on the cost of fuel a little, but spend any savings buying food. A vicious circle if you ask me, and not a real solution.
sigh... long start when hot again...
Maybe not the $5 repair, but close. I have the BC premium. It cost $17003 years ago when I bought it. Had a little more spare cash back then.
I believe you are going to need some green backs to go along with those pennies for that pump. Here's hoping for a 5 buck fix.
Click, click..
Sure sounds like it. Mine did the same when it went. I did not know about the contacts back then so I dont know where to buy them. I am sure someone else does.
Awapping VP44 & side cover gaskets
Hopefully I will be in there in the next couple months and see whats in there. My AD is on the frame rail so maybe none of that is in the way.
P-pumped 24v, now no cruise
Way to go 98, happy you got it working.
I will be doing this in the near future. Has any one tried adding a breather to the 24v tappet cover? Is it is a casting or just a stamped metal cover?
Hello from southwest idaho
Welcome to the family.
95 Honda accord
The rotor button was kind of strange. It looked 2 thin layers of metal with a synthetic layer sandwiched between them. The last rotor button I messed with was solid.
turn lights off
Id say it has something to do with low powered headlights. Enlighten us "Lightning".
what interval do you change oil/oil filter at?
:iagree::iagree:
Camper installed and heading out for some fun.
I would be interested in the answers to both of the above and what she weighs.And by the way, ENJOY!!!
turn lights off
My 02 does not have that feature. I never noticed any second gen coming at me with low power headlights burning.
Not making boost as of recently.
I am not the electronics wizard here by any means, but from the codes your alternator might be putting out to much juice. Thats where I would start checking. It could be creating enough havoc to cause the engine to defuel and that will lower boost. Go over to the articles section and look under 24v at the OBDII error codes. I cant seem to link anything anymore.
signs of a bad vp44 bad mpg?
18 around town in a 8K truck is asking alot. I just dont see it happening. 22 highway, maybe. I have seen almost 21 once, But i was keeping my speed 65 max. As far as Smarty settings, I know nothing about them.
95 Honda accord
Well, I made it home and it crapped out on him. I went over to his house and sure enough no spark. So we took the distributor cap off and The contacts the rotor button sends power to were all pitted up and the rotor button was pretty well gone also. Replaced both and it fired right off. Appreciate the help and all is well.
ECM Discussion....
As one of the ones who have had a bad experience with rebuilders and weeks waiting for a rebuild of the rebuild, I finally got one from Dodge. This happened 2 years ago and I was under the impression that remans were all you could get then. Could be wrong. Personally if mine were to go out again I would go with the Dodge, or Cummins, who ever had the best warranty and or price. I would agree with electrical spikes and heat would be just as bad for the ECM as any other electronic component. Would the wiring harness be long enough to allow you to move it very far with out having to modify it? Does anyone know how hot it gets on that side of the engine?
What kind of mileage do you think you ought to be getting?
Rough Day Yesterday
Ouch!! Also sorry to here of your troubles. I have not experienced frost heaves, but have seen alot of heaves from heat over the past couple of years. It does the same thing, buckle the road up and the asphalt can launch your vehicle. You have our thoughts and prayers here for a safe journey and a special one that the kids think it is all an adventure. As a father of 3 and a gran daddy of nine, I can feel your pain.
Vacuum pump - Rebuild time!
I cant seem to find the time to fix mine. Hopefully that is coming real soon. I have been leaving my mark any where I park for the past year and a half. Tappet cover is leaking, I think the front main seal is leaking and the it appears the vacuum pump seal is going now. I have already had to add 2 quarts of oil and I am only 4k into this oil change. That is about double what I have been seeing of late. So the Valdez will have to cruise on a little while longer.
Your numbers are pretty close to what I get. 14 around town and about 19 highway. That is empty at about 7.3k#. I have personally never seen 18 mpg in town since mine was new. 9 psi of fuel pressure is to low. I am going to assume you do not have a FP gauge. Get one asap. Yes you may have damaged the VP from low pressure. But it sounds like it is still working fine for now. It might last 6 months or 6 years. Get the FP problem fixed sooner rather than later. Before i had a FP gauge I had problems and found my pressure to be close to non existent. I fixed the problem and the pump went 3+ more years before I replaced it There are many schools of thought on proper pressure. I personally run 19 at idle and 15.5 at WOT. Anything around 18 to 20 at idle and 15 to 17 at WOT is very acceptable. How old is your AD? .
Possible Dead ECM?
When mine went I had the revving you experienced. You could stand by the truck looking to see who was in the cab playing with the throttle. Mine never smoothed out though and was undriveable. My WTS functioned normally but nothing else did. I also had a long list of codes, mostly sensor high and low voltage warnings. The WTS malfunction is definitely ECM in nature, but I agree with Mike on checking more before throwing an $1800 part at a problem before you are pretty well sure thats whats wrong.
Thats all you are worried about? Like I said on the other day, mine is starting to look like the EXXON Valdez. I think my next job is near home so I can park the ole girl for a while and work on the to do list and fix those pesky leaks.
Install fuel pump in series with in tank pump
Actually neither one of mine were connected to thru the ecm. The intank pump was connected thru a relay Dodge installed with the in tank pump and power came right off the battery IIRC. The booster pump was connected to an oil pressure switch I installed on the driver side of the block with the power off of the battery. I never did figure out what fried my ECM. not that computer savy.
Just upgraded to hx35, not happy
Some of the HX's come with a v band to clamp the exhaust and others, like mine, bolt up. seems the v band is more prevalent I think. I have not seen that many to know, just basing this on what I have seen and read here.
