Bug screen behind grill/winter covers
I lived in Leadville, Colorado for 12 years - very much a winter climate as Leadville' elevation is over 10,000 ft. I made a daily roundtrip going over Fremont Pass (11,300 ft) twice a day in my '91 Ford F150 4x4 pickup powered by a Cummins 4BTA engine. I used a winter front with a zipper to control air flow. I always left it 1/3 open no matter how cold it got. I did this because I found that some air flow is always necessary so the thermostat on the viscous fan will sense the proper temperature. The small opening also maintains a more laminar air flow (much less turbulence) around the fan. On a below zero degree day I could ascend Fremont Pass with normal engine operating temperature and descend the other side with my heater still working at the bottom of the pass. The fact that they salt the roads heavily in your neck of the woods will make a difference on the material to select and the method of controlling the opening. - John
Not "did", it still does! If you decide to install a screen, I think that you will be happy with it. I have used a plastic screen, but I found the diameter of the wire in an aluminum screen was much smaller so my thoughts are that the aluminum screen would be less restrictive when comparing the same mesh size. - John
I have made and used a bug screen for the life of my truck - almost 19 years and 343,000 miles so far. I have found no ill side effects. I am still running the original condenser and charge air intercooler - the two components directly in the path of bugs and other debris. I use screen door material (aluminum). Most of the bugs just bounce off of the screen. The ones that stick to the screen just dry up and fall off or get cleaned off when I am driving in the rain. I rarely ever need to clean the screen. The photo below shows the typical condition of the screen. The screen has not been cleaned for well over a year. The photo below shows part of the condenser just behind the screen. Note that there is nothing lodged in the fins and that the fins are straight. The last photo below shows the charge air intercooler just behind the screen. Again, nothing lodged between the fins and the fins are straight. All the above photos were taken just a few minutes ago. You are probably wondering if I ever had any overheating problems because of the screen. The answer is no. I had about a two year period that I was experiencing the engine running hot while towing up long grades. I replaced the fan - still ran hot. I removed the screen - still ran hot. Eventually, after reading some posts regarding overheating, I removed the radiator and found the motor side of the radiator caked with grime caused by the crankcase breather. I cleaned it up and re-installed the screen and I have never had a heating problem since. I have had the truck twice in Death Valley, once with a camper (combined weight of 12,000 lbs). I pulled from the valley floor (minus 200 feet) to the pass at 5000 feet. The distance was 16.8 miles. It was late afternoon and the temperature at the start of the incline was 116 degrees and about 90 degrees at pass level. I had the air conditioner on for the whole climb. The engine did not overheat. I think that was a pretty fair test. I tow a fair amount at times - most of the time the combined weight is between 12,000 to 16,000 lbs. The screen does what I want it to do - it keeps debris from wedging between cooling fins. You will probably hear different opinions about using a screen, but for me it has proven to be worthy. - John
W-T ground mod
The battery temperature sensor has only one purpose. It is to sense the overall temperature of the battery under normal operating conditions. It does not monitor temperature to correct problems, nor does it fix anything. It is placed in the tray of one battery (does not matter which one) so that a stable temperature wil be recorded and be directed to the PCM. If the ambient air temperature is 100 degrees, the battery temperature will sense this and send a message to the PCM. The PCM will reduce the alternator output upper limit voltage to - say to 13.8 volts, just guessing - so that the batteries don't gas excessively and over heat. Just the opposite, if the ambient temperature was 10 degrees, then the battery temperature sensor will send a different message to the PCM. The PCM will increase the alternator output upper limit - say to 14.2 volts, again just guessing, to compensate for the cold temperature. The PCM is constantly monitoring the battery temperature sensor (and battery voltage) and continually tells the alternator what to do - so, the battery temperature sensor makes batteries last longer under all types of driving conditions and it is working all of the time. - John
Hard start when hot/sitting
A couple of things you could try... When parking the truck overnight, point the front end down hill. It will reduce the amount of fuel leaking back to the tank if that is the problem. It should start quickly in the morning. If most of your hard starts are after the engine has reached full operating temperature, then the pump control module on the VP44 may be on its way out. Some have tried pouring cold water on the module and if the hot module was the cause, the engine would start right up afterward. - John
Sport light conversion issue
I can't answer you question regarding your kit, but I have a sport headlight conversion. I made up the relay system myself. Here is the way the factory sport headlights work: The 9007 bulbs are the outer headlights. The 9004 bulbs are the inner headlights. The low beam filament on the 9004 bulb never gets used. Low Beam Function: 9007 bulb - low beam filament on, high beam filament off 9004 bulb - low beam filament off, high beam filament off High Beam Function: 9007 - low beam filament off, high beam filament on 9004 - low beam filament off, high beam filament on I set mine up this way and they work well. - John
Ground wire/ fuse box/ hot alternator
@Mopar1973Man, good article!
There is little value in using an ohmmeter to check for continuity on high amperage circuits. Even if only one strand of wire in the circuit makes a connection, the ohmmeter will read zero resistance, indicating the circuit is okay. The best method for testing high amperage circuits is to perform a voltage drop test on the circuit while the circuit is under a load. - John
Engine surging... at a loss here
I feel your pain. At this point I would rig up a fuel line and connect one end to the suction side of the lift pump. Connect the other end to a five gallon container of fresh diesel - and see what happens. It may be informative. If the engine runs fine and the fuel pressure is stable, then you likely have a severe restriction between the lift pump and the tank. If the symptoms don't change at all, then you could have a severe restriction between the lift pump and the gauge connection. You also mentioned a "a good sized tear in the sock". You could have large items lodged anywhere in the fuel line up to the lift pump. - John
150amp breaker tripped again
Always a possibility, but I think unlikely. Remember that no one seems to ever had a problem with the factory 140 amp fuse and that fuse has operated under all kinds of undesirable battery conditions. - John
Typically, the charging system has to work the hardest for a few minutes just after you start the truck. Even without grid heater operation, the starter draws a lot of power from your battery. Once you start driving, the alternator has to carry the electrical load, plus the make up load for the partly discharged batteries from starting the engine. I would check your 150 amp circuit breaker connections for building heat while the alternator is charging. A loose connection (if it is near the circuit breaker) will build heat quickly and that heat could transfer to the breaker causing it to trip. It is very easy to do a voltage drop test at those connections while the engine is running . It will clearly show whether or not the connection is good. If you need help with the voltage drop test, let me know. It could be that you just have a weak breaker. It might be worth installing another new breaker while you are diagnosing the problem. - John
Long Cranking Time
Glad to hear that the VP44 is fine. If you don't already know, there is an IOD fuse (ignition off draw) in the fuse panel that's visible when you open the driver's door. You can pull outward on the fuse (don't remove it) and it will disable the hood light, courtesy lights, glove box light, and parasitic draws from required computer memory for things like radio, key FOB system, central timer, etc. It would be a shame for the new batteries to have a short life because of being drained from not driving the truck. - John
Long Cranking Time
So, if I am understanding correctly, the VP44 is running fine? Engine always starts quickly and performs like it should in all driving conditions? Just wanting to clarify that the solution to your problem was just new batteries and a new starter. - John
@jimbochilds, I just edited my last response and replaced the photo with an electrical diagram showing the wire that you were working with (I think). - John
Blown Head Gasket...
@sooxies, one of your best indicators of cooling system problems can be observed by watching the coolant level in the overflow container. If it is checked first thing before you drive it for the day, it should be at its lowest level. If you check it after you just parked the truck, it should be at its highest level. If you check the level two days from now before you start the truck and it is 20 degrees colder outside, then the coolant level will be even lower than the two days previous. The point is, is that the coolant level will probably never be the same and that is normal. If the coolant level remains the same when checking the level under different conditions, that is a strong indicator there is a problem. So, the question always is - is the coolant level at the level it should be for the current conditions? You get the picture... I hope all is well. - John
Could be normal. The air that you pump in will rise in temperature slightly and cool off (contraction) while you wait - the laws of physics. How much did the needle drop? Were you doing this in the evening while the ambient air was cooling? Was the system already pressurized to 16 psi when you started the engine? You mentioned that it rose to 17 psi in about 90 seconds. I have never performed this particular test, but I would expect the pressure to continue to rise at a slow pace because the engine is generating heat. This test showed good results. Overall, there is not a red flag saying that your head gasket is leaking combustion gases into the coolant. For your peace of mind though, you could do the combustion gas test kit for your coolant as @wil440suggested. I have never used one, but idea is a good one. - John
While you are waiting for your pressure tester to arrive, go on-line and watch the 6 minute video below presented by Mityvac. The video shows you how to use the tester and to diagnose cooling system problems, particularly the potential head gasket problem. https://www.youtube.com/watch?v=cRoYbDDGHTk - John
Not necessarily. If you are driving an empty truck around, the engine won't generate nearly as much heat as a loaded truck or a truck towing. So in your case the hose would likely have a firmness to it. As @Haggarpoints out, firmness is very suggestive and can be different for everybody. I apologize for directing your focus on that point. So, I would focus of something less suggestive, like monitoring the coolant level in the radiator and the overflow container for a few days and see if you can be confident that everything is either okay or at least narrow down the possibilities of what is going on. One thing for sure - in a normally operating cooling system the radiator should always be full to the brim. The pressure relief and the check valve that allows return flow inside the radiator cap ensure that the radiator will always be full. There really is only one time that you can safely check the coolant level in the radiator and that is when the engine has been off for several hours. And, when I say full, I mean that when you slowly remove the radiator cap in the morning before starting the engine, the coolant should flow or be ready to flow out of the opening. If it is down a half inch or more, something is not right. The following are some possible causes: * There is a small leak in the cooling system. A small amount of coolant leaks out while the engine is running. When the engine is shut off and the engine begins cooling and the pressure falls below atmospheric pressure, it is easier to draw air through the leak rather than lifting the coolant from the overflow container. * The radiator cap is dirty, faulty, not sealing, or just plain worn out - again drawing air into the cooling system as the engine cools down. * The small hose leading to the overflow container is cracked or not sealing which again allows air to be drawn back into the radiator while engine is cooling (a fairly common, but unobserved problem). * There are combustion gases flowing into the coolant while the engine is running. This is the most serious situation. As the combustion gases enter the cooling system the pressure will rise faster than normal. The gases, being lighter than the coolant, will move to the top of the radiator. When the pressure overcomes the radiator cap relief valve setting, the gases enter the overflow container along with some coolant. Once the flow of the combustion gases entering the cooling system match the flow of gases entering the overflow container a balance will have been achieved. At this point the radiator cap is allowing a continuous flow of gases at relief pressure to enter the overflow container. The engine will run fine and will probably not overheat. After the engine is shut off and cools completely, coolant will NOT return to the radiator because at engine shut down the coolant pressure was at the cap relief setting and there are compressed gases in the uppermost part of the radiator. After complete engine cooling the gases will decompress, but will still remain above atmospheric pressure, so no coolant returns to the radiator. As you can see, there are a lot of possibilities. I recommend that you start with the simple stuff in a methodical manner. Don't jump to the worst case scenario. A radiator and cap pressure tester is a very useful tool for finding leaks and for checking the condition of your radiator cap. The tester can usually be loaned or rented from an auto parts store. Keep us posted... - John
Post coolant flush help
The primary reason a gas engine heats to operating temperature rather quickly while idling and a comparable displacement diesel engine has a tough time getting to operating temperature while idling is because of the different way the air flows through each engine. Gas engines have a throttle plate. Diesel engines of our era and older do not. A gas engine works like this: an air and fuel mixture at the proper ratio enters the cylinder at a very low pressure at idle. The engine actually has to work to draw the air-fuel mixture around a mostly closed throttle plate before the mixture enters the cylinder. This creates a very low pressure downstream of the throttle plate - a vacuum of about 18" HG. That air-fuel ratio is at such a low density that it does not carry much combustion heat out the exhaust. Most of the heat goes to the water jacket, so the coolant warms quickly. A diesel engine with no throttle plate allows a full charge of air to enter the cylinder at idle and then a small amount of fuel is injected. The air density entering the cylinder is slightly lower than the ambient air density so lots of heat from combustion can be carried out the exhaust and a lot less heat will go to the water jacket. Plus, the engine does not have to work as hard to get the air into the cylinder in the first place because there is no throttle plate. A fully engaged viscous fan doesn't help matters either - just what you need on a cold winter day - a fan blowing cold air over an engine that is struggling to warm up! - John
You may have a valid concern..., or not. You didn't mention what the conditions were when you noticed the radiator hose was firm. Normal cooling system operation with a 15 psi cap and an overflow container and an engine that has been shut off for at least overnight works like this: * Before engine is started the radiator will be 100% full and the overflow container will be less than half full (coolant will have be drawn into the radiator from the overflow container during the night from a cooling engine. A one-way check inside the radiator cap accomplishes this task.) * As soon as the engine is started, pressure will start building as the coolant temperature rises with a closed thermostat. It won't be long before the pressure reaches 15 psi and some coolant is transferred to the overflow container. If you checked the firmness of the radiator hose at this time, you will find it very firm. This would be normal. * As you start driving the truck, additional fueling generates more heat and more coolant is transferred to the overflow container. After driving a while, a balance will occur as the thermostat adjusts to the rate the engine is heating and the radiator is cooling. At this time coolant stops being transferred to the overflow container because the coolant pressure is no longer rising. * As soon as you reduce the engine load (such as pulling off of the freeway and parking the truck) the coolant pressure drops considerably - down to as low as 2 or 3 psi. At this time with the engine still running the radiator hose should not be firm. If it is very firm, I would be concerned. (In the old days when trucks had top tank radiators and no overflow containers, this was the time to check coolant level on a warm engine). The next morning before the engine is started, the radiator should be 100% full and the coolant level in the overflow container should have dropped some. So, I would start from scratch and the first thing I would do is make sure that the radiator is 100% full and the overflow container at least 1/3 full before starting the truck after it set overnight. Then I would drive the truck and work the engine a bit and bring it home and before shutting the engine off, I would check the over flow container and the firmness of the radiator hose. If the hose is very firm, that could indicate that combustion gases are entering and pressurizing the cooling system. After several hours and before starting the engine again, I would check the coolant level in the radiator. It should be filled to the brim. If it is not, then again, this could be caused by combustion gases entering the cooling system. I would repeat this procedure everyday for at three days or so to get rid of the possibility of trapped air in the cooling system. A radiator pressure tester would be useful to find leaks and also to prove the radiator cap is relieving at the proper pressure and the cap doesn't leak. - John
Fuel pressure 5psi. 0 at WOT
I made no mention of running a VP44 without a lift pump. But since you mentioned it, some VP44 engines will continue to run normally even if the lift pump fails. For that to happen, the lift pump must have a free flow check valve internally and the failure must not block any flow. If the conditions are right, the internal vane pump in the VP44 continues to draw fuel from the tank. If the failed lift pump does not have an internal free flow check valve or the failure blocks fuel flow or introduces air, the engine will likely stumble or not run at all. - John
The 14 psi overflow valve inside the VP44 provides the path for fuel return flow for cooling the VP44. There is a fixed displacement internal gear pump ( a vane pump) with a relief setting of over 100 psi that by design provides more flow than can be consumed by the injectors and operating parts inside the VP44 with plenty of fuel flow left over to operate the 14 psi overflow valve and return fuel to the tank under all operating conditions. The lift pump flows directly to the inlet of the fixed displacement internal vane pump. No lift pump can make the internal vane pump deliver more fuel. A high volume lift pump that flows more fuel than the internal vane pump can flow just raises the VP44 inlet pressure, but DOES NOT flow more fuel through the internal vane pump. It can't because the internal vane pump is fixed displacement. The concept of using a lift pump is to provide a positive pressure to the VP44 inlet. If an engine is at wide open throttle and the inlet pressure of the VP44 is only 3 psi, all is well. 3 psi means that the inlet of the VP44 is charged so the internal gear pump will take care of the rest. I am posting this information because I truly believe that there were so many problems with VP44 trucks when they first came out that it generated a paranoia that can't seemed to be dropped. The paranoia was centered around lift pump pressure early on. However, Bosch fixed a lot of those VP44 problems without fanfare and a quality rebuilt VP44 is now pretty reliable - regardless of lift pump pressure. My replacement remanufactured VP44 (timing piston failure on the original) and lift pump conversion to tank was performed under warranty at 87,000 miles in 2005. The original lift pump never missed a beat. The converted in-tank lift pump operated at 6 psi at idle and 3 psi at wide open throttle. I drove it that way for over 150,000 miles with a Smarty tuner added. I replaced the in-tank lift pump with a frame mounted used FASS pump (a low volume one) at 250,000 miles on the truck. I did this only because I wanted an easy roadside repair in case the lift pump failed. The FASS lift pump operates at 12 psi at idle and 5 psi wide open throttle. That lift pump has been operating for over 4 years and 90,000 miles. I now have over 250,000 miles logged on the rebuilt VP44. I expect that I can have a VP44 pump failure at any time now, but I will not complain about the service life and I will not blame it on the lift pump. - John
Fuel delivery problem etc
As hindsight, I think that you may have had a hydrostatic lock caused by a severely leaking #6 injector. While you were having trouble starting the engine, lots of fuel could have leaked from the injector and collected in #6 cylinder. Then, when cranking the engine over, the fuel wouldn't compress and caused a hydrostatic lock - consequently, the horrible sounds and the starter shaft breaking. By the time you replaced the starter, the fuel leaked out of the cylinder via the end gaps of the piston rings. It would also explain why the compression is higher in #6 cylinder than the rest of the cylinders - some residual fuel is hanging around the compressions rings. As others have pointed out, starter shafts just don't break... - John
Body Roll
@Alexio Auditore, your topic title suggests that when your truck goes into a curve you get a lot of body roll (a steady lean of the vehicle throughout the curve). This could be caused by worn out spring or deteriorated anti-sway bar bushings, but not by stiffer shocks. The above statement suggests that that you are talking about a stiff side to side rocking motion. That would probably be caused by the stiffer shocks that you installed. I installed the 4600's on my truck because I heard that the 5100's were a bit stiff. If I interpreted what you were saying incorrectly, then just disregard my comments. - John
