Everything posted by IBMobile
Oregon cooling.....
Don't get me started about the apostolate of the new religion of the left. Does it look like this? I've seen you do it that's why I have to hide them when you come over for coffee at camp.
Yachts have bottom paint, Now Flip Over and talk about RV Roof coatings.
There are 2 or 3 roofing supply companies here in San Marcos I'll be going to check on this type of product. I still haven't reroofed my 5er do to not having the time and the temps here being in the 90s just about every day. If it looks doable I might put it on and try it out. If it doesn't work I'll replace the roof like I was going to do in the first place.
Dripley...
That's way I haven't retired yet, it helps keep the prices low.
Is this the type of polyurethane you're talking about? https://lexiscoatings.com/polyurethane
Ugh, 47re service
That sucks!!! Was it a bad gauge or to much pressure.
What was the "stuff"?
Second best option for headlights
OPFTL.....Old People Follow Tail Lights is my motto. When I do venture out after sunset I use my 9104 light blubs with stock head lamp assemblies and wiring. The low beams (80 watts) with the stock driving lights are good enough for me..
Heater on all time
I thought that the ohm resistance would change also. Does the voltage change on the YL/OR wire when the temp selector is powered up and the knob moved.
Heater on all time
The A/C heater temperature control is nothing more than a potentiometer so if you're not seeing a variable voltage on the YL/OR wire with an open circuit between pin #3 and #4 then the temperature control is bad.
Heater on all time
Here is the FSM diagram for the blend door. Dark blue (DB) wire is battery voltage, yellow/orange (YL/OR) wire is a variable voltage signal from the temp selector and the black/light green (BK/LG) wire is the ground. I don't think a 9 volt battery is going to power a 12 volt system. It would be best to see if you have truck battery voltage at the DB wire, changing voltage at the YL/OR wire and ohm test the BK/LG wire for continuity to ground.
W-T ground mod
No, it wasn't in the article but in the middle of page 2 of the original thread. All of those pictures are missing also.
W-T ground mod
I was able to insert the pictures from the Word document into both the article and forum where @W-T writeup is posted. I was unable to remove the grayed out areas where the original pictures were. Thank you @015point9 for the Word doc.
Weird idle, now two codes.
You may need a new APPS. Here is how to test it. If you need a new one get a Timbo; they are for sale in the Mopar1973Man store.
W-T ground mod
That data is still there. It's the pictures that are missing.
Which Torque Convertor To Get
This is why I'm doing it. 1000 mile trip is a short one for me towing my 5er. This spring was a 3000 mile trip and the past 2 years I did a couple of 7,000 mile trips. I don't need any problems with the trans like I had with the VP44 in Riggins ID.
Heater on all time
I think you might have a blend door problem.
Ac help
If the compressor is cycling then you might still be low on the 134A. How much have you put in? From the 2ed generation cab interior article "Basic Air Condition Repair" The A/C system requires 32oz of 134A for a full charge. When using a single use 12oz can you’ll need 3 cans. After adding 2 cans (which is 24oz) weigh the third can on the kitchen scale and make note of the weight. When adding the remaining 8oz (2/3 of the can) check the weight of the can occasionally. When the can is 8oz lighter you’re done.
Finned deep aluminum pan.
You can count on it.
I've had problems on and off with this transmission for the past year. First it would either have a delayed or no 1-2, 2-3 shift which was fixed with a new governor solenoid and pressure transducer. Now the torque convertor lock up won't work due to a bad convertor clutch. If I replace just the torque convertor I still have a valve body that has insufficient stock line pressure along with it's other drawbacks and a transmission that has been overheated. I call John @Dynamic transmissions and ordered a "Stage 2" transmission with a low stall speed Georend torque convertor. I hope to have it in a week or two. I've got another 1000 mile camping trip planed for October 2ed which will give it a good test drive..
another problem with the truck
Check the automatic shutdown relay; it may be going bad. You can also give the wire harness the old tug and shake test with the engine running.
Northwest Bombers
I'd work for good strong coffee
PATC transmission torqueconverters
- Gauges and big line kit
Why not just one T off the 1/2" line for the fuel pressure gauge then tap that smaller line with a T for the Quadzilla. This way you only need one snubber and needle valve to eliminate the hammer effect on the down stream gauges.- Old New Guy
Welcome to the forum. You can get advice for all the trucks needs right here. A lot of people on this forum with a wide range of knowledge and are willing to share it. - Gauges and big line kit
