IBMobile
Staff
Everything posted by IBMobile
  1. Just woke up at 3:45 an the mind kicked on full speed, It'll shut down when it's time to get up,
  2. I made my own. I measured the openings, then went to a fabric store to get the foam. The store I went to sold 3 different densities of foam and cut it to size with a hot wire cutter. I used the medium density foam, didn't cover them and did not have to cut a hole in them for the crank handle. They're still in great shape 14 years later.
  3. From the FSM, how to check turbo charger shaft for play.. (3) Visually inspect the turbocharger compressor housing for an impeller rubbing condition (Fig. 25). Replace the turbocharger if the condition exists. (4) Measure the turbocharger axial end play: (a) Install a dial indicator as shown in (Fig. 26). Zero the indicator at one end of travel. (b) Move the impeller shaft fore and aft and record the measurement. Allowable end play is 0.038 mm (0.0015 in.) MIN. and 0.089 mm (0.0035 in.) MAX. If the recorded measurement falls outside these parameters, replace the turbocharger assembly. (5) Measure the turbocharger bearing radial clearance: (a) Insert a narrow blade or wire style feeler gauge between the compressor wheel and the housing (Fig. 27). (b) Gently push the compresser wheel toward the housing and record the clearance. (c) With the feeler gauge in the same location, gently push the compressor wheel away from the housing and again record the clearance. (d) Subtract the smaller clearance from the larger clearance. This is the radial bearing clearance. (e) Allowable radial bearing clearance is 0.326 mm (0.0128 in.) MIN. and 0.496 mm (0.0195 in.) MAX. If the recorded measurement falls outside these specifications, replace the turbocharger assy.
  4. If you want any more coking from her LET IT BE. She must have gone to the same cooking school as my wife. If it isn't over cooked it isn't done.
  5. Grid Heater Bypass Simplified The method described below is a simplified way of turning the grid heaters on and off when starting the engine and reducing the electrical load on the alternator without setting a P0380/P0382 code. The bypass solenoid is a 300amp rated Ford type starter solenoid. When both grid heaters are on there is about 180amp draw and after start up the draw is reduced to 90 amps so the bypass relay has a 50% plus overload safety factor. Suggested Parts List 1 Standard Motor Parts starter solenoid SS-598 (bypass solenoid) 1 automotive on/off switch DC rated (your choice of style) 1 ATC fuse holder or fuse block (needed if not using fuse in PDC) 1 5amp fuse 13” 6AWG wire cable 5’ 18AWG wire red 5’ 18AWG wire blue 3’ 18AWG wire black 2 6AWG 5/16” copper wire ring terminal 3 22-18 AWG #10 ring terminal 2 #10X32X3/4” screw 2 #10X32 nut 4 #10 washer 4-5” of heat shrink (for the 8AWG cable terminals) 5’ ¼” plastic split wire loom 1 pack of 5-7” plastic ties 1 roll rosin core solder Putting It Together Disconnect both batteries; remove left (driver’s side) battery and battery tray. On the side of the battery tray fit the bypass solenoid and mark holes to be drilled; you may have to grind one side of the bypass solenoid mounting bracket to have it fit flush on the side of the battery tray. Drill 2 holes, 13/64”-7/32”, where marked on battery tray and mount the bypass solenoid with the #10 screws and nuts as shown below. Note: the bypass solenoid is grounded through its body so a black ground wire, with a #10 ring terminal at each end, is attached to one of the mounting screws and the other end grounded to the body. Reinstall the battery tray. Left battery tray with solenoid attached. Find a place in the cab where the switch type you chose will fit and be readily accessible. We used a rocker switch mounted in the kick panel below the steering column. For power you can tap into the fuse box on the left side of the dash. Find a terminal that has power only when the ignition key is in the on position. This is where you can add an ATC fuse holder with a 5amp fuse. Connect one end of the red wire to the fuse holder and the other end to the switch. Connect the blue wire to the other switch terminal and run it through the rubber grommet in the fire wall and with a #10 ring terminal connect it to the bypass solenoid terminal marked S; cover with ¼ “ split wire loom. Make up the 6AWG cable (an 8AWG cable will work also) with the 5/16” copper ring terminals and heat shrink. I solder my cable ends on using a small butane torch but you can use a large cable end crimper. Be sure to index the orientation of the cable ends to the cable before attaching them so the ring terminals fit squarely on to the battery and solenoid. The cables for the grid heat solenoid and battery power can now be attached to the bypass solenoid; the battery power cable to the firewall side of the bypass relay and the cables for the heater solenoid to the other side; reinstall the battery, connect all the terminals and reset the apps. Left battery tray installed with bypass solenoid. Notice position of the cables. Note: I have experienced a P1291” No temperature rise seen from intake heaters” when the temperature is below 35°F and the heaters are turned off right after starting the engine. I suggest leaving them on when first starting in cold weather for a minute or two. Note: It was first suggested to use an SS-581 starter solenoid, this solenoid does not have a protective diode in it and may cause a voltage spike that could damage sensitive electronic components. A SS-598 solenoid should be used in its place. This was installed with the help of JAG1 on his 2001 Ram 2500 diesel utility box work truck. Written by: J. Daniel Martin AKA IBMobile 7/6/2019 View full Cummins article
  6. IBMobile posted an Cummins article in Electrical
  7. I finished the article "Grid Heater Bypass Simplified" last night and will post it later today after my wife proofs it.
  8. Rear main seal housing, then oil pan, then the seal. The pan gasket will come up to meet the seal housing. Also, if any of the seal housing gasket is hanging below the housing after the housing is mounted to the block you can trim it before putting on the oil pan.. The other way is you have the seal housing sliding over the pan gasket.
  9. Check the recycler yard for 1996-1998 Volvo 850 and 1999-2000 s70-v70 modules. They have that purge valve located on the radiator fan shroud top left. They can be either round, early type, or rectangle. Test both ports with vacuum hand pump to hold vacuum when closed If found get the wire connector and 10cm of wire with it.
  10. Since you are in Minnesota try this link for used parts in your area. http://autorecyclersmn.net/recyclingProcess.html
  11. I agree with Mike to check the A/C system for proper operation. If you want to add baffles to direct the air flow try some foam insulation tape. You can get it in any width and thickness you want. Distance between stock radiator and intercooler 1 1/4" Distance between stock intercooler and A/C condenser 3/8"
  12. Here is the pressure relief valve with the screen.
  13. The old Volvo used this type of pump up to 1984 and the rear mounting bracket used those bolt holes. I've had to reseal the pump reservoir due to leaks there. There are O-rings that go between the pump and the reservoir housing that need to be replaced. it's a very easy job to due once the pump is off the vehicle. another time I had a pump leak because of a short hairline crack in the reservoir sheet metal at one of the bolt holes. I think, it was about thirty years ago, I brazed that crack closed. The kit is cheap, $9-$14, an can be found at most parts suppliers.
  14. Mine tops out at 30psi with the manual boost controller and spools fine for towing. It us to have a boost elbow but that limited the boost, at most, to 25psi
  15. Is the white smoke definitely unburned diesel fuel or could it be coolant? Can you isolate which cylinder it is by cracking open an injector line one at a time and see which cylinder has no idle change? I feel your pain. I've had an injector pump go out on one trip, a crankshaft position sensor go out on another, and the last trip my transmission wouldn't shift up to 2ed or 3ed at times; almost makes you want to stay home.
  16. Is this, may be, fluid from the shock due to a bad seal and it gets pumped with the up and down action of the front suspension?
  17. take it one wire at a time, Pick a wire, follow it, see what it powers. If you don't need or use it remove it. If needed rout the wire next to existing wire harness and cover them with a split wire loom for a clean install and terminate them in the PDC or add an auxiliary fuse box.like the one shown below.
  18. That's exactly what happened. Truck was towing and going to slow for a 2-3 shift up; torque convertor working like there's no tomorrow for 20 minuets; trans fluid temp went over 250°F (121°C)..
  19. I know the angst you had. After following Jag1 up and down the cow paths of Oregon my trans fluid was dark in color and it was only a couple of thousand miles old. I use Valvoline synthetic. @wil440 if you keep using your old transmission pan put a drain in it. It makes changing the fluid and dropping the pan a lot easier and cleaner. You can drill a 13mm hole in the front left corner of the pan then tack weld a 12mmX1.25 nut on the inside and don't weld all the way around the nut; it's thin sheet metal. Install an engine drain plug with plastic, fiber, or rubber washer. I tighten to 25 Nm.
  20. Do the wires connect to the back of the alternator like this pictured below? If so, cut the charging cable end (the cable that goes from the B+ alternator terminal to the battery) off and on the other side the rest of the cable that goes to the 140 amp fuse in the PDC. That cable can be verified using an ohm meter testing from the 140 amp fuse to the alternator. leave the rest of the wires connected to the alternator. Now you can run the new cable from the B+ terminal to a fuse or circuit breaker then to the right battery positive terminal.
  21. If your from another state and just passing through NJ they can pull you over for a smoke test? That doesn't seam right that they can impose there state regulations on an out of state vehicle. What happened to interstate transportation with reciprocity. .
  22. There's one right up the road from you in the Mopar1973Man's store.
  23. It was when the temp went over 250°F I have the temp sender on the out flow line from the transmission to the trans cooler. The trans temp will normally very from 155° cruising down the freeway to 210° in stop and go traffic when towing. The fluid heat up quickly when under load but is slow to cool after.
  24. Lots of pulling power but the trade off is higher RPMs when cruising at highway speeds; about 1800 RPMs at 60.MPH. You won't need a mystery switch. the switch is for automatic transmissions. It locks up the torque convertor for direct drive from engine to transmission, something like a clutch disk on your stick shift.
