IBMobile
Staff
Everything posted by IBMobile
  1. Check the transmission relay that it's sending power to the trans. If that's OK then the governor pressure solenoid or transducer may not be working.
  2. Review Monitor Cab Monitor and Rear Trailer Camera Parts list: 50’ roll outdoor Cat-5/Cat-6 cable (Home Depot) 10’ red 18awg 1’ black 18awg 10 ‘split wire loam tubing ¼ diam. 5” color monitor (5” E-KLIN 12-24V car monitor, Amazon) Color camera (E SKY EC170-11, Amazon) 4 pin round trailer wire connector ON/OFF switch, SPST, push or toggle 2 amp fuse Fuse holder Rosin core solder Electrical tape Heat shrink tubing Coaxial cable staples Zip ties 2”x4”x ½”- ¾” plywood or board Flat black spray paint Double sided tape or 3M auto molding tape Clear silicone adhesive 3 #6x ½” screw 1 #8 ring terminal 22-18awg Tools: Wire cutter Wire stripper Pliers Solder gun Small blade screwdriver Phillips screwdriver Drill motor Drill bits ⅛ - ⅜” Hole saw 1⅜” Hammer This system was put together in the spring of 2017 and has been used for over 20,000 miles with no problems. It cost about $80 for the cable, monitor, switch, round 4 pin trailer connector, and camera. The rest of the parts and materials I had on hand. I put in the ON/OFF switch so the monitor can be turned off for night driving. Note: Cameras with inferred night vision may not work well at night if the camera is placed inside the trailer and viewing through glass without outside lighting. Installing Camera and Trailer Wiring First, locate a suitable mounting position for the camera. A rear facing window is ideal and if there is a cabinet next to it the wire connections can be hidden in it. If a rear window is not available a hole drilled through the rear wall next to where the camera will be mounted or the cable run under the trailer and up the outside of the rear wall is an option. Camera mounted in rear trailer window. Run the Cat-5 cable through the trailer from next to the trailer’s seven pin connector, in front, to where the camera’s mounting position will be, leaving 6”-12” of extra cable at the ends, If you have 20’ of cable left you can use it for the truck installation otherwise you will need to buy more. You can drill holes, just big enough, in the walls and floor to pass the cable through. When drilling through the floor be careful not to drill into a holding tank, waterline, or anything else; drilling into an empty storage compartment is best. The Cat-5 cable can be held in place with coaxial cable staples for the walls and zip ties elsewhere. The Cat-5 cable has four sets of 2-24awg: orange, green, blue, and brown. I used the orange set for 12volt feed, the green for the ground, the blue for video signal, and connected the shielding wires from the camera and monitor to the brown. Spray paint the wood black and let dry, attach the camera to the wood with the 2 #6x ½” screws. Solder camera’s: power wire to the Cat-5 orange wires, ground wire to the Cat-5 green wires, video to the Cat-5 blue wires and shielding to the Cat-5 brown pair; sealing each solder joint with heat shrink then wrap cable junction with electrical tape. If the camera is next to a cabinet you can run the wires through a hole drilled in its bottom or side and place connection in the cabinet for concealment. Now, place the two sided tape on the wood and carefully affix it to the window with the camera facing out. Camera view adjustment will be done after the monitor is functional. Installing Monitor and Cab Wiring In the truck cab remove the overhead light counsel and drill two holes in it, see picture; one for the monitor power cable and one for the monitor video cable. Do not remove the cover for the garage door remote pocket, just open it up and remove the square button; you will be passing the cable from the monitor though here. You can install the ON/OFF switch in this area at this time or locate a place that is to your liking. Find the roof bracing and drill a small hole for a short screw that the systems ground wire will be attached to. DO NOT drill through the roof. Find a wire that has switched power to splice into for the systems power. Power draw is about 1amp. Add a 2amp fuse to the red wire and spliced it to the tan wire at the large connector under the left side of the dash between he park brake pedal and the firewall. This tan wire is rated 20amps and is used for the power windows. Picture by Leaky88 You will need to remove the trim cover for the left A-post and drop the left sun visor. The red wire with the Cat-5 cable is run up the left side of the dash, A-post, and between the head liner and roof to the center counsel area. The switch can now be attached to the fused red 18awg wire. On the other side of the switch attach another red wire and solder the free end to the orange Cat-5 wires and the monitor’s power wire. Using the 12” piece of black wire, solder the green Cat-5 wires and monitor’s ground wire to it; attach the other end of the wire to the roof brace with a ring terminal and screw. The video monitor signal cable is solder to the Cat-5 blue pair with the shielding soldered to the Cat-5 brown pair. Heat shrink is used to insulate connections. Install the modified overhead center counsel, sun visor, and A-post cover. Using the suction cup mount attach the monitor to the rear view mirror and run the monitor cables into the center counsel through the square hole that was used for the garage door remote and connect to the system cables. Route the rest of the Cat-5 cable through the left side of the fire wall via the wire grommet, down the left outside fire wall and along the inside of the left frame rail attaching it to the wire harness with zip ties. Find where the round 4 pin plug would work best for your set up. On my truck it was next to the 7 pin trailer connector in the bed side wall. 4 pin round video connector next to 7 pin trailer connector. Drill a hole using a 1⅜” hole saw, that is just a little bigger than the 4 pin round connector, check the size of your connector before drilling; run the Cat-5 cable from under the truck bed through the hole. Attach the cable wires to the male 4 pin round connector but DO NOT screw the male plug to the truck until testing is completed. With the Cat-5 cable running alongside the 7 wire trailer cable attach the female side of the 4 pin round connector to the trailer’s Cat-5 cable leaving the cable a few inches longer than the 7 wire trailer cable. Be sure the wires going to the 4 pins of both ends match up color to color. Rear view monitor with forward view dash cam. Plug the two ends together and turn the power on. The monitor will illuminate and show the view out the back of the trailer but the camera will need to be adjusted horizontal and vertical. Horizontal adjustment is done by loosening the front of the camera by turning its outer cover counterclockwise; this allows the camera to be rotated to get a level view. Vertical adjustment is done by bending the bracket slightly up or down. Two people with radios make this easy. When testing is finished seal the back of the 4 pin connectors with a dab of clear silicon sealer and slide the male connector into the hole and secure with 2 sheet metal screws ¼” x 1”. The exposed Cat-5 cable coming from the trailer can be covered with ¼” split wire loam tubing and secured to the larger trailer cable with zip ties. If you have a bumper pull trailer a bracket can be made out of sheet metal or angle iron and attached to the trailer hitch. When the monitor is not being used it is cover with the bag it came in, placed back in its’ box, and store in the center arm rest. Read through this a few times and have all materials and tools before starting. There are no guaranties implied or expressed. Written by: J. Daniel Martin AKA IBMobile 11/29/2019 View full Cummins article
  3. IBMobile posted an Cummins article in Cab Interior
  4. I found the Hobbs switch to be a PIA to set when the fuel pressures between the two pump is close. The power to the electric pump has been turned off by removing the fuse and is only used to bleed the system after a fuel component has been changed. The engine starts fine with only the Fuel Boss.
  5. Do a cooling system pressure test like @Tractorman recommended. You can have the use of a cooling system pressure tester from O'Reilly tool loaner service for free. You needed to put a deposit down but you will get it back when you return the tool. https://www.oreillyauto.com/detail/b/evertough-4771/tools---equipment-16488/tools-23747/rental-tools-16837/rental-tools--air-conditioning---cooling-19163/26fcb01856e7/rental-tools-evertough-radiator-cap-test-kit/67085/4700282 For the harder to see areas behind the head you can use a small mirror and flash light. https://www.harborfreight.com/search?q=inspection mirror
  6. Yes, that will work but you want to use a 12 volt single poll double through switch (SPST) also called an ON/OFF/ON switch. If you can't find a SPST switch a double poll double through (DPDT) switch will due.
  7. new
    IBMobile replied to Wet Vette's topic in Introductions
    Welcome to the forum family. Mike has a big heart and always ready to help. Mike rescued my wife and me a few years ago when we broke down in Riggins. Good luck with the job hunt.
  8. That what gives the paint the shine and wet look. It's that environmentally friendly waster base auto paint. When you were in school, there were no radial tires, TV was still black and white, and the phone was a party land line rotary dial up stuck to the wall with a wire.
  9. I don't think so. The pump sits just below the front of the oil pan and no one has ever posted a problem with it.
  10. I have a Fuel Boss as do most of the other people on this forum that have a mechanical pump. I installed it years ago with one problem that is common, small pieces of rubber from installation causing the pressure regulator to stick open. This problem is easily remedied by opening up the relief valve and blowing out the debris. When I first installed it I had some questions which were gladly answered by the staff of GDP. You can use this pump with or without the electric pump they say to install. I have a cheap eclectic pump installed for priming the system (when changing fuel filter, injection pump, or injectors) but keep it turned off the rest of the time by removing it's fuse..
  11. I had a car with an ABS code for the left rear wheel sensor. I found where a rat had chewed through the wires at that sensor. I repaired the wires and retested. The code for the left front sensor came on, those sensor wires had been chewed through also. My scanner was picking up only 1 code at a time for the ABS system unlike multiple codes at a time for the powertrain (P codes).
  12. What is this "Bone chill cold" you speak of? That is a foreign term to us in the San Diego area. My block heater has never been used. I only turn my grid heaters on when camping in the fall at the Sierra Nevada Mountains and I use my boat and RV year round.
  13. I've done that on the 2000 and older Volvo window switches. I used strips of 400 grit paper to clean the carbon off the contacts but the coating on them had gone bad so the switches would fail again in 6-12 months, depending on number of uses.
  14. I think you need a new switch, read this. OPERATION The power window switch for the driver side front door has an Auto label on it. This switch has a second detent position beyond the normal Down position that provides an automatic one-touch window down feature. This feature is controlled by an electronic circuit and a relay that are integral to the driver side front door power window and lock switch unit. The power window switches control the battery and ground feeds to the power window motors. The passenger side power window switch receives a ground feed through the driver side power window switch for operating the passenger side power window motor. The power window and lock switch and bezel unit cannot be repaired and, if faulty or damaged, the entire switch and bezel unit must be replaced.
  15. No, I was just letting you know what that fuse powers and what was effected by removing that fuse. I would still start with checking for power at fuse #9 with the key in the off position. There should be none.
  16. Fuse #3 in the PDC sends power to the ECM (red/white wire pins #48 and #50) and to terminal #30 of the Fuel pump relay in the PDC. This fuse has battery power all the time.
  17. Where is this fuse? In the PDC or the left side of the dash and what number is it?
  18. @Alexio Auditore You should have asked him to super size that fluid change. He might have understood that then asked if you wanted fries with it. I've worked in shops where they would hire a guys because they had some tools and were breathing, he would be gone in a month because of poor production and to many screw ups. You should talk to the owner/management about this guy. His work ethics don't sound like they are the best. He can cause thousands of dollars in property damage along with serious personal injury and even death.
  19. How do you get it to shut off? Check for power at fuse #9 on the left side of the dash. There should be no power at the fuse with ignition off. This fuse powers the PCM (pin#1) and the ECM (pin#5).
  20. But your the 'Good Troll of the North'.
  21. It's great that you posted your experience and are informing others of the danger. A year from now this thread will be 5 pages or more from the front and I don't think to many people will see the warning so I took your advice and edited the article changing the SS-581 to the SS-598 and adding a note about the SS-581. Thank you once again for sharing.
  22. Thank you for pointing out a possible problem with the SS-581 solenoids. When I was researching the solenoid I found that the later Fords used the EEC to trigger the solenoid and needed the diode where the early Fords that used the SS-581 had direct current from the ignition switch. If the SS-581 solenoid has a dedicated switching circuit, from battery to fuse to switch to solenoid, then if there is a spike it can not effect anything.
