Everything posted by IBMobile
Need help with ecm reflashing.
Here is how to change the diodes and brushes on a Denso alternator. This is how to do a grid heater bypass that won't turn on the check engine light.
Want to drop an inch off my 2 in. level kit.....
If you need more work on the front end you can wait till April when I get there. I'll watch and drink coffee.
struggling to build boost
They are the next size up from stock. I'm using RV275 and Edge EZ with no smoke or haze. Also there is an adjustable boost valve in the system set at 30PSI.
Your best/worst camp grounds
It made a bad situation better.
No, I was waiting for MoparMan to bring a VP44. I was towed into that campground on @Mopar1973Man recommendation. When I got there and told Doug Crump that Mike sent me he said no problem. You mean this deer eating the peaches.
Hard starting, no starting
Great... Let us know how it works out and how customer serviced is from Flafship One. Below is a list of ECM repair shops and how they rate here thanks to @pepsi71ocean
DO EXHAUST RESONATORS ROB HORSEPOWER??
Another thing to think about is the further down stream from the engine the cooler the exhaust gas and it's volume is reduced negating the need for large pipes to maintain the same flow rate.
Well, I'll be... for sure thought it was in the PCM. So you'll be doing the W-T mod and sending the ECM out for repair?
In my dreams! The lowest I can find around here is $3.70 at an ARCO.
Now that's nothing to cluck about.
Recommendation on Trailer Tires
I think you may have to go to a 14" tire to get that D rating. I like Maxxis trailer tires and a 185/75-13 tire is rated at max weight of 1480(C) @ 50psi.
Nation 180A
Yes, to protect the electronics in the PCM, ECM, VP44 from AC voltage and short circuiting in the charging system.
Right down the road from @Mopar1973Man forest campground is the Riverside RV Park on the Little Salmon River in Riggins, Idaho. I've been there twice and both times we found it clean, quite, and the owner, Doug Crump, is a nice, friendly guy. This was the view from our 5th wheel.
Nation 180A
Have you done the W-T modification and installed a fuse in the blue wire from alternator to the PCM?
Guages?!
Four Isspro on the A post. From top down: exhaust temp, trans temp, fuel pressure, manifold pressure. I've had them since June of 2004 with no problems.
Green Bean Thinkin'.........
In your back pocket.
Just another way, out of thin air, for the government to confiscate money; of course that tax is past on to the consumer. So, it is just another hidden tax on the proletariat.
Please prayer for MoparMom
Mike, Dan just shared with me about Rosalie. Although we knew this day would come, it is still so very sad; a terrible loss of an incredibly wonderful, God-fearing woman, Mom, and friend. I loved her from the first "Hello" back in August 2017! Her positive energy, joy, zest for life and her love for Jesus made an imprint on my heart!! She so loved her home and property there in New Meadows; a place God directed her to so many years ago. Well, once again God is directing Rosalie to a new home He has prepared for her where she will live eternally without pain, in a new body and in the glorious presence of our Lord Jesus Christ. I pray that Rosalie's passing with be peaceful; and, that even tonight she is seeing glimpses of Jesus and the glory of heaven. I pray God will comfort Rosalie with His peace assuring her that you, Mike, are in the palm of His hand as His plans for your life will prevail. Mike, I pray God's peace flood through you as you trust the promptings of the Holy Spirit as you make these difficult decisions on behalf of your Mom. May God's grace fill you with the perfect words as you spend your last hours together; do not rush. Rest in God. "Be still and know that I am God." The Hebrew root of 'be still' doesn't mean 'be quiet', it means "let go." Let go of what you cannot control - and rest in the knowledge that God is in control. I am grateful that God has brought Eileen into your life this past year for such a time as this; I am glad Eileen has had the pleasure of getting to know your Mom and will be with you during these next days and months of transition. The grief in the loss of your Mom's presence with you will be deep; but, I trust the years of loving memories together will fill that void in and warm your heart. Please know that Dan and I are here for you anytime during this transition season. With all our heartfelt thoughts and prayers …………… Jennifer and Dan
Productive day
I would have them powder coated; they would stand up to the weather better. What size air compressor are you using for the sandblaster?
Seat covers
dripley had his seat covers embossed with his personal logo.
Seat covers
They look good. I always have problems with the seat bottom cover staying in place. How do these workout?
over 2000 rpms sometimes lose of power , no pedal response
What @dripley and @JAG1 said. Here is the W-T modification.
That's a good point and it should be addressed and corrected as soon as you can because it can led to other problems but I don't think it is causing this no start situation.
Fuel sending unit
NO, @dripley just hunts and pecks at the keyboard.
So, it's an intermittent problem. Next time it happens try starting it with just the right connector at the PCM disconnected. If it still doesn't start disconnect the left connector. The PCM grounds at the passenger side battery. The center connector is for the transmission sensor and solenoid control. Be sure all the connections, battery terminals, and grounds are clean and tight.
