- Replies 36
- Views 6.3k
Unless your power demands it go with the 100. The 150 can easily outflow your filters, which isn’t worth it IMHO.
I have a DTT Assassin mechanical pump from DAP, it will suck a football down a garden hose, I use a Cat filter head and Cat 2 micron fuel filters, I do have a FP gauge but never look at it now, highe
I wonder if they found a problem with their pumps and are thinking not to open up over the replacement cost potential. I had a Raptor 100. After about 60,000 it was showing signs of weakne
Looking for input, I'm pretty much stock, but hoping to add Quad Adrenaline this winter. I do have RV275's. I won't use wire tap, just Can tuning (or so I think) . The price difference is about $40 dollars, but Airdog states that the difference between the 2 pumps is the rpm of the motor (2000 for 100, 3000 for 150). Will I see any benefit of running the 150 over the 100 with the mild mods I plan. I was thinking the lower RPM 100 might last longer than the higher rpm 150, but I know that engine longevity thinking may not apply to electric motor longevity reality.
