recentering steering wheel?
Power Steering fluid should be changed every 30K miles or every 36 months. Dark brown is a bad sign that the fluid was totally burnt and the lubricity was gone this most likely part of your failure not to mention the oversize tires leveraging against it. Remember P/S system has no filters so once debris starts floating through the system it gets worse exponentially till something fails. Still got tight steering here with all factory equpiment. The only thing changed was ball joints, wheel bearings, and track bar. I have no idea what its like to have sloppy loose steering and have to modify so much to get back to tight steering...
Tow or haul ?
Even both of my trailers the old homemade and the new BigTex TV70 both pull me down to about 16 MPG empty from a normal 21-22 MPG without a trailer. I would tie to the stake pockets with ratchet straps as well as to the tailgate tie rings.
Biofuel or what
Basically selling B5 bio-diesel at that pump. Nothing different than the ethanol they sell in the gasoline. It may contain up xx% ethanol.
Voltage from brake controller
Kind of like my new Big Tex trailer. I turn the gain all the way up to MAX and worked the brakes off the mountain to seat the new brake shoes to the drums. Because at first brakes did nothing now you can fill light drag from the back of the truck with gain set at 8-9 Volts. I have a Tekonsha Prodigy 2 (P2) controller.
From the Northwoods
You'll be surprised of what some people here might have laying around in there shop or parked out back. You might ask around someone might have or know of a friend that does...Welcome to the family.
Tow or haul ?
You'll be fine. As for the rear axle weight of the truck mine is 2,860 pounds curb weight right now. I've got a rear GAWR of 6,084 pounds which allows roughly 3,224 pounds I could carry over the rear axle. I haul my 700 pound ATV in the back of Mom's 1996 Dodge Ram 1500 without a thought about it. I haul heavier loads in mine as a seasonal thing... I know your toy is less weight than all this... 2002 Dodge 2500 Door sticker http://forum.mopar1973man.com/attachment.php?attachmentid=1546&d=1281643390 1996 Dodge 1500 door sticker
converting a raptor
Cool. Glad to see that. I've been wondering when the time comes about stealing a motor another and stuffing it in. Mine been running for many years now without a issue. (AirDog 150)
6 month old AD frrp left me on side of road today... hot cows in trailer
Ok. We've talked on the phone. Now so other are clear its a AirDog FRRP. So he's direct connected to the ECM as well as using stock plumbing. As for the ECm it would be direct control of the fuel pump and it would be smart to add the relay to take the stress off the ECM. If the rotor is binding up it might be pulling extra amps on the ECM. You might check for the P0230 error code.
P-pumped 24v, now no cruise
Something is missing now that it requires to function this most likely the cause now you'll have to back track a bit and test with devices to see if you can over come this issue.
Newbie 2-cycle questions
I've gotten a few other test at close to 128:1 ratios and the finally number floats around 380-400 HFRR roughly. But I never got a exact 128:1 ratio test yet. Why I said...
BigTex 70TV
:umno:It's maroon.
24 valve fuel additive
The article is here... http://articles.mopar1973man.com/general-cummins/36-fuel-system/63-adding-2-cycle-oil-to-diesel-fuel http://articles.mopar1973man.com/general-cummins/36-fuel-system/68-hfrr-testing-of-common-diesel-fuel-additives
Fly by wire (Manual Trans)PCM -> ECM -> VP44 Automatic TransmissionPCM -> Vacuum servo -> mechanical linkage
Do remember that 474 HFRR score is based on 200:1 ratio where the 128:1 ratio is roughly 380 HFRR which isn't to bad. Since I have a lot of 2 cycle engines (Stihl 046 Magnum, Stihl 461, Weed wacker, etc.) around I might well use the 2 cycle oil. It's always here why not?
BigTex 70TV
No. It's not a dump trailer and No. The sides are fixed and solid. Price prevented me from even going that far. But I will admit the GVWR of this trailer is double easy. Then the dry weight of the trailer is lower than my previous. The tongue is so light empty I can pick it up and place it on the ball. Where the old trailer was so heavy not even Kelly and I as a team could pick up the tongue even empty.
BigTex 70TV
BigTex 70TV
MoparMom didn't unload it. Kelly and myself did. Uh. As for the old trailer it got traded in so that would have to run down to Caldwell and pick it up for what ever price its being sold for.
Help me find the gem...
I think your truck can be made to haul that RV still. But you'll have to invest in changing out the tires and coming back down to a smaller tire. 235's or 265's. 235's will be better for towing better stability. Then add some air bags to the rear axle. Might in invest in some good shocks all the way around. I know your heavy on the rear axle but you not really outrageous.As for finding the gem. I would be hard pressed to find a truck with less than 250K around me. I'm not much for CL or Ebay dealers. I've seen to many people getting scammed with vehicle sales. I would hit the local dealers where your at and see what options you got and maybe ask if they would put there eyes out looking for you.
BigTex 70TV
Well it done...Went from this...To this... BigTex 70TV yea you bit the bullet and push forward.Even on Saturday I made my first run with it getting a load of firewood. Really nice trailer that hauls the weight very, very nicely. Better than the only single axle that was never really designed for that amount of weight. (Kelly peering over the wood pile)Now as for loading its so nice. I was cutting up on the bank so buddy Kelly backed the trailer up near the bank jacked knifed and dropped the tailgate and we just rolled all the wood in the trailer. No more lifting 35-38" to just get it into the truck bed or the trailer bed. Now there was someone that made the comment about "Just wait till every find out about your trailer they'll want to barrow it" Well that's not happening. I've already got friends asking to haul firewood for them as well. Even MoparMom says "Let them speak in Cash". So after pondering the calculator I figured out a nice price per mile for hauling material for people be it firewood or construction materials. Maybe make a bit of money locally doing bit of local hotshotting... Never know...:whistle:As for Raymond at American Trailers Sales Of Caldwell I would like to say "Thank You" for selling me a wonderful product at the right price.
Yes. There is a adjustment on the drag link for center your steering wheel. Make only 1/2 turn adjustments and check. You'll be surprised at how fast that alter the center placement.
Back to stock injectors for a short time
As long as you can reach over 1,000*F for a few miles of heavy towing you'll clean those old ones right up. But you'll enjoy your news ones as well.
Being I've got 2 chainsaws laying in the back of my truck and mixing 2.5 gallons of 2 cycle fuel at a time. I typically always have a few gallons of 2 cycle oil floating around the property. So yes Opti-lube might be cheaper but not as available as 2 cycle oil since I use so many 2 cycle fuel powered engine its foolish to mail-order Opti-lube just for the one purpose.
Yes. Mine is a fly by wire only PCM controlled cruise control. But from what I've learned from everyone here is that all automatic where vacuum servo cruise still controlled by the PCM. So I would attempt to using resistors to fool the APPS sensor to believing its at a idle position of about 0.4 volts, ground the idle leg of the validation switch. Remember this is shooting from the hip. Being that the APPS signal comes from the ECM and then is passed to the PCM. If cruise is set then PCM should take over control feeding signal to the vacuum servo.
Fuel mileage update
4.10 gears?
Someone needs to straighten these people out
Walmart SuperTech Outboard 2 Cycle Oil is about $11 a US Gallon.
