Wanna A Good Laugh???
Looking towards home last summer...
Ladies and Gentlemen I Present To You...
There was a guy long ago on CF.com that was managing to pick the ECM apart using RomRaider and was figuring out how to re-write the ECM software to his own liking. Also he tore into the VP44... But the great hurricane Katrina came and his site disappeared... Personally I would love to be able to re-write a bunch of stuff... Like cruise control min speed is set for 35 MPH drop that to 5 MPH. See a clear copy of of the timing tables and fueling maps. Be able to disable the grid heaters completely.Do away with Torque Management.(Rumor) There is already software present for low fuel pressure switch to be used on the ECM (Engine shut down on low fuel pressure)
Fuel System
Yea... Mine were simular...
Had a snowmobile... This was my last ride... After this I came home and parked and then gave it away... I enjoyed snowmobiling alot. But when you and a girlfriend head out and to trail ride and get stuck. Then have 20+ snowmobiles go by you and laugh and point. Because my sled wasn't brand new anymore (10 years old). It took me 2 hours to dig out. No big deal about digging out. But what bothered me is the fact that 20+ people could ride past you and leave you for dead and not even help. Also that pic the snow is roughly 8 feet deep. After relizing it could of been much worse I simply gave up the sled... (No longer own a sled) 1995 Artic Cat Pather Deluxe (440 Fan cooled)
Machine Hole / Lifter Cover
Yeah I replaced a cam cover gasket on Taz's 1992 Dodge it was the same way brittle and crumble in your hands. I might end up doing mine this spring too...
truck just died
Just because of being common to have starting problems I did some digging in the books and gathered up a quick diagnostic list... http://mopar.mopar1973man.com/cummins/2ndgen24v/diagnostics/diagnostics.htm
Engine Rewiring
I always loved how a 12V cummins would start and run without anything... Just need a bit of power to twist the starter and tank of fuel to keep it fed...
Why not have software like EFI Live for Ford and Chevy's where they are capable of writing there own code into the ECM's. Dodge is the only one without any kind of software like that currently. Even Subaru has RomRaider that allows a re-write of the ECM. Smarty and SuperChips are weak version of this.
MPG fooler - Design phase
Because 110-120*F will put you roughly at 140-150*F IAT. But since the engine was design to be run in weather above that I'm sure its either going to defuel or have some really wild settings for timing... Since no one is capable of seeing the timing table of the ECM lets say its safe to play inside the normal weather span but get above it well your pushing your luck...
Compression Test
Ok... Here you go guys and gals... It posted in the Static Pages now... http://mopar.mopar1973man.com/cummins/general/compression/compression-test.htm
heat shield or no heat shield?
Over all my MPG logs I've kpet since 20K miles to current. My lowest MPG hauling loaded was 14.10 MPG Best was 25.3 MPG (One Hit wonder) But still can hold a floating around 19-21 MPG hand calc'd. But with a heavy foot see a average of 16-18 MPG as well...
Well there is a lot of variables... Like if I kick it up to 65 MPH from 55 MPH I can kill off all my gains to 18-19 MPG. So driving style has something to do with it. Also in my area of Idaho there is no traffic light just stop signs. So its not like I sit in stop and go traffic. Like some of the runs and things I didn't report because knowing I was in a hurry and drove like a bat out of hell and sucked the numbers down. Or happen to be towing at the time (firewood to New Meadows, ID) Still the #1 factor of all this is speed and driving style. Poor driving style can ruin a good MPG...
That's why I got trip to trip basis... Clearing the SGII and record for a single trip... Also my problem is my odometer is off by 0.5 of a MPH slow so my hand numbers typically come out a 0.2 ot 0.3 lower than SGII because of this small error. Then if I happen to haul a load of firewood for friend in New Meadows, ID again that would skew the entire tank (hand clac). Or if I happen to drive up in the mountain to a buddy's place 11 miles back. (Roughly 4-6 MPG the whole way up the 11 miles). So in order to keep clean data I've been using the same test route back and forth to McCall shopping. Because I drive the same way there and back everytime. It involves traveling from 2,800 ft elevation to 5,200 feet in McCall, ID speed zones ranging from 25 MPH in the cities, 45 MPH on the grades, 55 MPH on the highways (Posted 65 MPH).
Pana-Pacific - That particual gauge is no long made... They changed the design...
Here you go... Now why would I try filling a tank here locally when the local diesel price is $4.089 in New Meadows, ID and $4.109 in McCall? Now in I nickle and dime time I make another trip down to Boise, ID its much less... Right now roughly figuring it would cost me $102.26 to fill up... I just don't have that much in my pockets...
Aftermarket Fuel Lift Pump Question
Marking answer in RED... Hopefully that helped.
who else is down here?
There is a lot of guys/gals in that area... I know CajFlynn comes from that area... There is more but got CRS right now... :banghead:
Can't afford to fill the tank... $20 here... $40 there... I'm still logging the fuel data but waiting for the money to fill up. I know my calibration was good as of the start of winter (Nov-Dec) and the only thing changed on the truck is the IAT... Like I've got to head to town soon in the next few days to put another 20-40 buck in it...
Thanks... In New Meadows or Riggins... But I don't think you can handle the cold... So far the coldest morning has been -25*F. Thanks again... It might be beautiful country but being trapped in the bottom of the canyon because of snow really does suck after awhile. I've got a itch to hop on the ATV and head for the hills but won't make it far... No one thought my first video was funny?
Congrads... While your there figure out a way to tap into the ECM's EPROM so we can program in our own code...
Still holding good MPG numbers at 21 MPG on a 11*F day... Cruise set at 55 MPH...
please tell me more about 2 cycle oil
Added more to the 2 cycle oil page...
Easy way to set valves
Added to the HTML archives... Thank You ISX 1st Gens http://articles.mopar1973man.com/1st-generation-dodge-cummins/11-engine-valve-lash-adjustments 2nd Gen 12V's http://articles.mopar1973man.com/2nd-generation-12v-dodge-cummins/20-engine-valve-lash-adjustments
Milestone
Long ways from making the milestone page... 500,000 - 167,750 = 332,250 Miles needed... Get driving...
Sitting and idling in traffic with high IAT temps will not effect the performance because it not rolling anyways... MPG is 0 just sitting at a traffic light. Stop and GO traffic is harsh no matter what the IAT temps are. The other factor is no matter what you want to plumb for cold air intake you got to remember the entire manifold of the 24V has a coolant passage under it not to mention having a coolant pass within 3 inches of the IAT temp sensor now. EDIT: The freeze plug I've been told is intake manifold.
