Trying to understand A/C and heating
Comments in blue... Here is a quick vid of the blend door... http-~~-//www.youtube.com/watch?v=-h6ufg1-Dag And here is the wiring...
I'm not certain what would cause that yet... I'll study up though...
Normally charged A/C system will not cycle on and off if charged properly. Like mine runs solid never cycles and pumps out 45*F air from the center vents on a 95*F day... The only time you might see the cycling on and off is in the dead of winter and using DEF then the A/C is cycled because the freon reaches freezing point rather easy so it kicked off. The allows the system to condense moisture on the evaporator and dump it outside the vehicle this why DEF in the newer vehicles work better than old school...
Dead Throttle
Check error codes... P0121, P0122, P0123, P0222, or P0223 are all APPS sensor codes... Ah heck... Here is the error codes for both... http://mopar.mopar1973man.com/cummins/2ndgen24v/apps/apps-codes.htm http://mopar.mopar1973man.com/cummins/2ndgen24v/vp44-replace/vp44-error.htm
Need ideas..
Ok... My I say make a second set of cup holder for the passengers in the back. Then you need a tall bin in the center say about 3-6 tall at the most. But then leave a bit of flat sapce for like toss coins and other small articles so your not digging in the bin. Be kind of cool to have you invert hidden under the plate some where so if you do slam the brakes the cup doesn't sloosh on the inverter... Hmm... Another crazy thought is a rocker switch panel for accessories and such...
Low fuel pressure reading
Ummm... I'm kept my stock filter housing and even got a filter in the stock housing... But I ran 1/2" line from tank to VP44... So now my fuel pressure is rock solid... (AirDog 150) Short vid... Cruising 55 and stomp on it to 70 MPH... http-~~-//www.youtube.com/watch?v=iRoZlLVVxiY
Boost Elbow?
Give it a try and see if the boost is improved... Worth a try!
Dtc code=#215 & #237
Got you covered... http://mopar.mopar1973man.com/cummins/2ndgen24v/vp44-replace/vp44-error.htm DTC P0215: FUEL INJECTION PUMP CONTROL CIRCUIT Description Information for when fuel injection pump control circuit is monitored and conditions required for DTC to be stored are not available from manufacturer. Possible causes are: defective fuel pump relay, defective Engine Control Module (ECM), or defective connectors or wiring.
Boost Elbow?
Here the boost elbow I got from White01 A x10 mag of the bleed hole. Profile pic Another profile pic...
I am on vacation and broke down need some help
At least rebuilt you know the Trans was taken apart and full looked over and clean out internally. Where a use trans might be full of debris, might not ever had the fluid changed and part damaged inside that you won't know till driven under load... Just my
Boost Elbow?
The problem with those is the fact they are extremely hard to adjust just a 1/16 of a turn can mean 10 PSI jump or loss... The one given to me I going to try and modify slightly to improve adjustability... What I'm using is a Edge elbow now and I can hit 35 PSI just about every time...
Gomma bite the bullet I guess
Once long ago my truck looked like that with only 24 miles on the odometer... But after 171K miles and one tree hitting the truck she not a well perfect condition... But I do have to admit they are doing a awesome job on the paint... The part I like about my truck now its got a few paint chips, a few small dings, and still shines up awesome but you can still work with it without total panic...
No clear winner, powerwise..
Go for it... At the worse that will happen is you'll learn something...
Correct Power Puck install w/boost fooler and Smoke switch?
Well that's how you learn from it... But yeap most say its not worth it... But a winning combo that with get the smoke to roll is a set of RV275 injectors and a Edge Comp on 5x5. I've got to roll into the throttle really light to keep my smoke down. But once I clear 5-10 PSI I can roll into the throttle hard and heavy. But now from a dead stop and row out the gears when I hit 3rd gear and drop the hammer you better not be near me... I'll change your paint job to flat black really quick!!
I Did It Today
Holy cow... You didn't make it to 100K but darn close there Dorkweed... Do you have a pic of the Blackstone report? I'm really curious about the results after 84K miles!
Vacuum line Schematics
That right there is the driving force that keep me going here... Thnk you Russ those kind words make the world of difference!
Couple easy questions from a newbie
Comments in blue... ---------- Post added at 04:36 PM ---------- Previous post was at 04:27 PM ---------- Well I double checked my book... It shows the cruise for the Gasoline system which use the vacuum motor setup... But the steering wheel controls are the same... It just the wires don't go to a vacuum motor but the PCM is wired to APPS...
Need some help!!!!!!
Ummm... Do you remember the error code number again? I know I scanned it once but I need the code number again I can look it up in my books...
Painted the OEM Wheels black today..
Hmmm... I got a set of white spoke rims I might have to clean up and shoot black and them mount my Coopers on...
Black is constant vacuum...
Reason why is my stock rims are getting rather corred around the edges from wheel weights being put on and taken off. It has got a couple of small corroded spots on the rims... Sure I know "Diesel" doesn't help it either but hiking his leg and watering my tires in the morning...
Here is a wiring diagram for you... Do me a favor and double check you error codes I got docs for it but I need t oknow if there is error code present from the PCM of cruise control issues. P1595, P1596, P1597, P1683 these are cruise control error codes...
Something I might consider doing myself... But I wondering how long the color hold up to offroad debris and mud??? I'd sure hate to have to paint my rims every weekend...
Saving for new injectors
Right here... http://forum.mopar1973man.com/showthread.php/899-Injector-upgrade?highlight=injectors Then thew write up.. http://mopar.mopar1973man.com/cummins/2ndgen24v/injectors/injectors.htm
