  1. Ok... Give me a sec... --- Done... ODS is added to the attachment list...
  2. I'm surprised... That XLS file is for 97-2003 MS Office... Huh? "ODS"???
  3. Geez... Someday I might do my first brake pad change... (167K on the clock) Yeap... i'm still running the factory brake pads from the day I bought the truck... Never changed them yet... Usually when pads start to wear weird or uneven you can bet money there is a caliper slide pin or a piston that is binding up and causing this pattern... Every other time I bleed my brake system I pull the calipers apart and wash and re-assemble them making sure there is no binding pistons and the slide pins are lubed up good.
  4. Yeah... A slide hammer is the better way of pulling seals out. If the seal being replaced I normally just take a big thick flat blade screwdriver and pry them out too... But this will ruin the seal... But as for your method of sliding against the nut works the best for keeping the seal from getting damaged...
  5. I don't agree with this... If the engine didn't have the ticking noise when it was new then it not normal. But I do understand that as things wear they get play and ticking noise start to occur...
  6. That's really cool... Neat to see the calculations for my inverter and what kind of impact the hydro and solar have against the power bill of the house... You are one smart guy with Excel...
  7. Error codes? Exhaust gasket leak? Bad lifter or colapsed lifter? Weak oil pressure? Carbon track in the distributor? (if equipted with it) Crossfiring plug wires?
  8. Hmmm.. Well like myself I live at 2,800 ft elevation and Riggins, ID is at 1,800 ft elevation. On my to Riggins, ID I see 550-600*F at 65 MPH on my way home I see 850-900*F at 65 MPH. Since the Little Samon River run runs besides the highway water natural flows downhill... So I've got a change of elevation of 1,000 feet in 15 miles of distance but it looks fairly flat...
  9. Water weight? Hmmm... I wish you had a live data tool like ScanGauge II because I'm curious what your IAT temp was. (Crazy idea)
  10. I'm going to have to say its a boost leak somewhere... You getting high pyro temps so that means there is fuel being pumped in but your boost pressure is lower so... Best guess...
  11. Ok... A few things... 1. If this the stock turbo on the truck? (HX35 or HY35) 2. What's your fuel pressure like? (Both WOT and Idle) 3. Do you have any error codes currently? (Codes can be present without the light) 4. What's your pyrometer temps like?
  12. Sorry to hear... But like ISX keep us posted and I'd love to hear what you find... Time to pull the head and take a peek...
  13. I can't even seem to find the owners manual for it...:banghead:
  14. Ummm... What happen then with -20*F weather and DEF are running the A/C compressor? I bet the fuel will go to pour point quick... (Thick glob of bacon grease!)
  15. Ummm... http://en.wikipedia.org/wiki/Poker_Face_(Lady_Gaga_song)
  16. During cranking the lift pump is modulated at 50% duty cycle... Once the engine is started the lift ump runs at 100% duty cycle... Can be seen here in this video...
  17. No... They should be replaced as pairs... Because of the sole fact there is a fine amount of wear on the race and the new bearing will ride funny on a old race and might fail early... At least what I learn on 2 1/2 ton military trucks... Changed lots of those bearing (Ugh)... Funny part is I remove the inner seal the same way... Slide hammer the bearing against the nut...
  18. Only thing that sucks is that since you got the quadzilla hooked up the numbers are going to be all wrong for MPG... That's why I went to ScanGauge II at least I can calibrate it... www.scangauge.com As for temp display my little gauge a friend gave me does more... [*]Inside & Outside [*]Max record for inside and outside temps [*]Min record for inside and outside temps [*]alarm clock [*]min temp alarm for inside or outside temp [*]max temp alarm for inside or outside temp [*]time Don't ask where to get the gauge... I wish I knew where my friend got it because it really cool gauge...
  19. Well after a long wait... I finally got a heater core and got it back together. Come to find out doing a A/C evaporator and heater core are simple jobs to do really... I think the forum hyper and rumors make it sound horrid to do... Really it's not bad... Time consuming but not bad. First thing to pull the battery cables. The big thing is getting the engine bay side first get everything out of your way. http://forum.mopar1973man.com/attachment.php?attachmentid=1039 Evacuate the A/C system and drain your coolant down some for the heater hose. Pull the hoses loose on both the A/C and the heater core. There is 4 nuts holding the HVAC box on the engine side. http://forum.mopar1973man.com/attachment.php?attachmentid=1037 One is hidden under the PCM. Make sure to use duct tape or simular to cover the pipe ends from getting dirt in anything. Now the dash is easy... 2 bolts under each kick panel just loosen them and leave in the body. If you got a manual like me you got to pull up the console. Under the console is 2 nuts and 2 bolts. Now pull your knee bolster and take the 2 nuts out holding the sterring column. Let the steering column rest on the driver seat. Take the 5 screw across the dash top out. http://forum.mopar1973man.com/attachment.php?attachmentid=1035 At this point have a tie strap handy. Take the passenger side and lift up slightly and slide outwards off the bolt. Don't get overly carriered away be careful with all the plastic. Tie the dash up using the strap. At this point you got a few more nuts. There is 3 nuts to pull here. Rught next to the in/out vent door there is a nut hidden in the corner. Then there is 2 nuts stacked on the stud near the heater core. The ground strap in hooked to it.. Now back to the driver side and look for the vacuum connection. It will be rapped in foam it should be near the drivers side floor vent. The electrical on the passenger side needs to be pulled loose too. http://forum.mopar1973man.com/attachment.php?attachmentid=1034 now the HVAC box is ready to come out. Carefully wiggle the box around and it should pop out off the firewall. Guide it to the passenger side floor and slide it out under the dash. You'll need to lift it slightly being careful of the the dash and HVAC box. Don't force anything... If it not coming out double check yourself again... Whew! HVAC is out of the dash now. http://forum.mopar1973man.com/attachment.php?attachmentid=1090 Now the heater core is held in by 3 screw and it can be removed by pulling straight up. Nothing hard or difficult. http://forum.mopar1973man.com/attachment.php?attachmentid=1088 As for the A/C evaporator that requires the case to be split open. There is a mess load of phillip screws running the edge of the box. Now there is 1 screw hidden under a floor vent cover carefully pry the cover off to access it. http://forum.mopar1973man.com/attachment.php?attachmentid=1086 http://forum.mopar1973man.com/attachment.php?attachmentid=1087 Flip the case back over to the other side (screw holes pointing down). Now carefully pry the HVAC case open and lift the top off everything. A/C Evaporator case be lifted out and replaced at this point. But I highly suggest blow out with compressed air the ducts and fan. Your going to need a roll of weather stripping foam to reseal the A/C evaporator and heater core. http://forum.mopar1973man.com/attachment.php?attachmentid=1093 http://forum.mopar1973man.com/attachment.php?attachmentid=1092 Somethings to be careful of during re-assembly. Make sure your careful of the vent doors in side the HVAC case. There is a spring loaded door that you must be careful to not crush or damage. Then the blend door you got to line up the pivot post. Now re-install the HVAC case back in the dash the reverse order you took it out. As for recharging the system... What you need... http://forum.mopar1973man.com/attachment.php?attachmentid=1057 Should look like this hooked up... http://forum.mopar1973man.com/attachment.php?attachmentid=1096 Drawing down a vacuum. http://forum.mopar1973man.com/attachment.php?attachmentid=1097 Then shut your manifold and shut down the vacuum pump. Just for protection I got a can of PAG oil charge for the system. Once you got the can hooked up and punctured I bleed the yellow hooks at the manifold just crak it open and purge the air out. With the vacuum present I opened the low side valve and allow the oil charge to be drawn in. Closed it and switched cean to freon and bleed again. I allowed the first can to be pushed into the system. Now I started the engine. I continued to add freon one can at a time. I also used a bucket of hot water from the tap to help push the freon into the system. But I added 4 cans of freon on got to this point as seen on the gauges. now I got ot remember my current outside temps are about 55*F so the freon will expand more as the days warm up. http://forum.mopar1973man.com/attachment.php?attachmentid=1099 http://forum.mopar1973man.com/attachment.php?attachmentid=1094 Nice part is... http://forum.mopar1973man.com/attachment.php?attachmentid=1095
  20. that's as close as I get... Well like the shop that did my front axle bearings. After it was all said and done the the mechanic screwed up the ABS sensor and go the front axle seals leaking. In a nice and calm manner I requested to have these problems dealt with on there nickle. They did... I had 2 brand new ABS sensor install corrected one problem and then I was sent to another shop to have the seals replaced. The only thing I invested was the time to drive down and the fuel (180 miles 1 way for 2 trips). So needless to say yes a front bearing job endup costly me about $1,100 bucks but the truck was repair to my specs again! Yes I still do business with the orignal shop (Big 0 Tires - Ontario, OR). The guys are great people! So there is my story...
  21. It's taken 22 years of hard work to get this far... As for more vids I got a batch today from the north of me on the highway... I got to get them compiled here soon... Oh yeah... No nice tone of a Cummins... How about a V8 Gasser 5.9L Mopar...
  22. I would get the codes for sure... It really bad to start chuckin' parts at a problem and guessin' it can get really expensive...
  23. My Mitchell One book shows 4 shop hours to change a VP44... Then just figure their shop rate against it...
  24. (shakin' my head) Oh My Gawd... That's just plain wrong... I would drive another vehicle down the and demand he repairs it at you place with the proper parts... You wonder how guys like this survive and make a living...
