Pencil Injector
Physically missing the hole. Never was machined and missed. 5 guys looked at it and its missing not plugged.
Pencil Injector
I was the first to find this flaw in this tractor. Its a 1984 Case C580 backhoe. Number 2 injector was misfiring kind of. We pull the pencil injectors out to find number only had 3 holes and missing its 4th holein #2 injector. (Personal Trophy) Owner said its been in his father construction company and now he's using it for his construction. I'm the only one that found this rare one with three holes and not spraying right at all. Even did a quick valve lash at .012 Intake and 0.014 Exhaust. The actual size of the injector is just about the same as a standard #2 penicil. Holes are very tiny. Barely see the one hole here.
Multiple LP failures now hard starting when hot
Look at it this way the the ECM should control the lift pump for safety. If your in a accident with a key hot pump then the pump will not know to shut down because the engine has died (impact damage) which now could have a fire up front after batteries or electric shorts. The lift pump will continue to feed the fire will you burn alive in the cab possibly.
Reverse lights fixed!
Per bulb.
New Injectors now Surging
Just like a found out not exactly fitting but shows how things can change. I had job up in Anatone WA doing a injection pump on a Case C580 backhoe. The fly weight spring had failed and it would barely idle. Pulled the injection pump sent it to Lewiston, ID (Idaho Diesel Tech). They rebuilt the injection pump. Next week we went up and installed the injection pump. Got it fired up the backhoe and it was smoking bluish white warming up. Talk with the owner a bit and he said its never smoked before. We called Idaho Diesel Tech we both agree to pull the injectors. We found out that #2 injector is physically missing a hole. So the other 3 injectors are four hole injectors but number 2 is physically missing one hole. Case C580 pencil injectors... No one would of uncovered this mystery until the injectoion pump was rebuilt and had good line pressures once again.
2nd gen PCM functions
PCM is a the master computer. It controls the entire CCD network. Cruise control Transmission control Charging system Automatic trans shift controls Fuel gauge Volt gauge CCD Network Then next in line is the ECM... Which controls all the Engine functions. Tach signal Oil pressure Coolant temp Fueling VP44 (main function) Then the instrument cluster is the bus bias... Required module to set the bus voltage bias of 2.49 and 2.51 Volts. Central timer handles security, cab functions like heat seats, stereo controls, etc. CCD network allows all information to be shared over just two twisted wires. Remember the PCM is the primary computer the ECM is the secondary computer.
alternator "Gen out" no voltage
Yup. The green and blue are control by tach signal so the engine must be running to measure. the blue lead is typically +12V hence why the protection fuse for it. Prevent PCM damage from a shorted alternator. The green wire is a variable ground to control the charge rate vs battery temperature which the PCM checks and adjust accordingly. I do not suggest external regulators I've seen too many hooked up wrong and placement of the external regulator will cause under charging if too cold and over charging if the regulator is too cold. I still is a common problem with the older 89 to 91 trucks. Cold mornings here in Idaho (minus) they could over charge quite a bit.
98.5 24v cummins swap no start! HELP!
Great work is right. Best to keep the match ECM for that block. Makes it worse when retro fits are done without the PCM because now you can't read codes. It required to have the PCM to read error codes.
Converter Unlock/Lock, but only towing
I'm currently like 9 to 11 mV AC last time I check after doing the W-T ground wire mod. Big difference to the 55mV AC I was before the W-T ground wire mod. My whole process is the simplified version.
2nd gen Dodge Ram 1500
I've got 2 of these trucks. 1996 Dodge Ram 1500 Club Cab (without Quad Doors), 5.9L V8 Gasser with a Dynamic built 46RE auto trans. 187k miles. 2002 Dodge Ram 2500 Quad Cab 5.9L I6 Diesel NV4500 transmission. 419k miles.
Just for other to know... I do have LED in stock...
3rd or 4th gen fuel pump in 2nd gen
I'm running the ISSPro EV2 programmable gauges. I've set my fuel pressure for 13 PSI and below for red warning lamp. Boost is set for >45 PSI warning light Fuel pressure is set for <13 PSI warning light EGT's is set for >1200F warning light Transmission temp is set for >220F warning light.
Nv 4500 bell housing torque specs.
I normally just brake clean the spline shaft and leave the grease off the spline shaft. Yes it will splatter grease int the clutch. Throw-out bearings typically already have enough grease in the inner collar. Just make sure to clean it up after installing. Even fuel leaks around 4, 5, 6 can drip fuel into the clutch area.
Dimmer switch, back lights not coming on
- Multiple LP failures now hard starting when hot
Cranking pressute between 7 to 12 PSI will start every time. Above this will cause hard starting because it over advances timing making its tough to start.- New VP44 - Engine requires excessive cranking when hot
Stock pumps tend to create cavitation when the lift pump is dead headed.- Multiple LP failures now hard starting when hot
Hey, @dieselautopower you took away all my fun...- Multiple LP failures now hard starting when hot
I just sold a DAP VP44 injection pump for $1,100 here in the valley plus the labor. Nice to have my vendors @dieselautopower and my sale tax permit I get these pumps at cost and make a bit of profit. I can't tell you my price because I'd have to kill ya when you hear my price.- Multiple LP failures now hard starting when hot
Cranking pressure should be 7 to 12 PSI bouncing. If its too high it will cause hard starts.- Normal Load % for Basically Stock Truck?
Mine is a old 2G AirDog pump originally which lasted 250k miles and about 13 years. I got the short bed bracket so my AirDog is tucked right up behind the transfer case. Out of the debris path of the tires, warmer location for the fuel system and I've ran all the way to -40*F so far and no issues with gelling. I purchased it from another vendor in 2006.- Normal Load % for Basically Stock Truck?
No gains... I can clear the tank all the the way down to EMPTY mark no problem. There is less than 1/16" a inch between the bottom of my tank and the straw when the tank is empty. Then when I fill the tank with diesel is roughly 227 pounds and deflect the bottom at least another 1/4" inch. Never had pressure problems, no wild swing 1/4 tank issues. Cool fuel temps at the VP44.- Normal Load % for Basically Stock Truck?
Exactly. This is proper ECM control of the lift pump it switches the 12V on and off at a about 50% duty cycle to reduce fuel pressure. This is so the proper cycle of the lift pump and should bounce the pressure at 7 to 12 PSI.- Normal Load % for Basically Stock Truck?
You remove the filler neck and filler hose. The LARGER hose you cut and slip in the return fitting. The smaller vent hose is left alone.- Side load intake Manifold
Like myself... 7 x 0.010 DAP injectors popped at 320 bar. HX35/40 Hybrid turbo (60/60/12) Quadzilla Adrenaline Smarty/Edge stack is bad deal for sure. Stacking any tuner is a bad deal. First off neither tuner has good timing control. Then you made a light switch out of the throttle. It can be 100% fuel by 30% throttle position. Too much fuel and no enough timing control. Trust me... I was a ex-Edge Comp runner and managed to make a heck of a high MPG number of 27.2 MPG. The problem is you have to drive below 60 MPH to keep the high timing on Edge products. Then with bigger injectors the timing is too retard and now it creates a lot of EGT's. Where with the Quadzilla I can up the timing to meet the injectors needs. - Multiple LP failures now hard starting when hot
