  1. 7 inch screen. I'm not sure of the mounting yet. Not small like Edge or Smarty touch.
  2. 7 x 0.009 should hit 40 PSI. My old 7 x0.0085 (75 HP) was doing 40 to 42 PSI even on my little HX35/40.
  3. Timbo's apps is about angle than voltage.
  4. 1989 to 2002 as far as I know are 11quarts with filter. 03 and up are 12 quarts.
  5. I'm set for 18-19 PSI at idle and draws down to 14 to 15 at WOT. About 500 horsepower to the ground.
  6. I was expecting much more from a new turbo.
  7. Only 34 psi is low... My stock HX35W (54/60/12) made 35 to 37 PSI. My current HX35/40 Hybrid (60/60/12) is making an outrageous 47 to 48 PSI. Starting to wonder if the 14cm2 was too big.
  8. My email are not stored on my PC. All my email are IMAP and stored at the server. This allows my to sync all devices to the same email account and nothing ever disappears like POP3 email accounts which are most common.
  9. Quadzilla display is WAY bigger than Edge CTS. Edge CTS screen is smaller that a Smarty display, my LG G5 cellphone is bigger than both Edge and Smarty. The Quadzilla display is bigger than my cellphone.
  10. I don't know what you all are talking about...
  11. Yeah. The weather up here is been bitter cold. I was out chasing two dead Ford trucks and then found a beauty of a 1998 Dodge Ram (p-pump) that has a lift pump problem. Still in all all three job are stuck outside and I've got to get parts and repair ASAP. The Ford trucks are the local Elk ranch. The owner of the ranch. As for the fuel usage. The biggest thing is getting the pyrometer under 600*F constantly and drop that boost to near zero. Hopefully I can get back to a better schedule and quit rushing every where its costing me dearly. Part of it was moving my GF from Nampa to up here. Then Mom running late getting out for her dialysis. Then having to drive like jackass to make it all the way to Ontario on time. Need to get back my tuning and build a winter tune that can work with subzero temperatures. I'm also waiting for winterized diesel to stabilize in content.
  12. No. There is no sign of the Quadzilla during smog checks (electronically) but if the inspector does a physical look then he'll see the Quadzilla some I've heard in Cally have modified the wiring and hid the Quadzilla in the cab.
  13. Because the 3 FASS fuel systems that I sold locally all have issues with gelling up and having the filters struck in off-road conditions. Last one I sold gelled every winter. The guy got so pissed off at the FASS pump and the truck he sold the truck. Every winter New Meadows is subzero like -20F to -30F every winter. Typically the water and slush gets in the motor locking it up or it gelled up tight. These are all installed according to FASS instructions. What is better yet both running the same fuel from the same fuel station. FASS gelled up and the AirDog kept going. My truck has NEVER gelled once. Even working beside a FASS doing the same work that FASS would gel up and I was towing him home. That why. The other two pump end up being replaced because the fact of the filters being struck by off road usage where the filter hang below the frame rails. Once the filter are damage prime is lost and the truck is sitting dead.
  14. My last AirDog failure I was at zero fuel pressure (rotor locked fuse blew) and capable of driving city streets no problem with a completely dead lift pump. Still had it towed home to not damage the VP44. VP44 FAILURES #1 - 48k miles P0216 code fuel pressure at 8 PSI #2 - 243k miles P0216 code and good fuel pressure 17 PSI #3 - Currently running.
  15. I've got a cable builder in Caldwell the build our cables. I don't have any part numbers being its a finished cable when I get them.
  16. Don't rely on the the internal vane pump. Not a sizeable volume pump.
  17. What is your fuel pressure? (Idle and WOT at highway speed) Fuel pressure should be 14 to 20 PSI for optimal performance. Below 14 PSI the overflow valve closes cooling and lubing stops. P0380 or p0382 are grid heater failures. Check the small wires for damage or disconnected. If nothing found then the solenoids should be replaced. There is a open circuit on the small wire side typically.
  18. MPG actually retards the timing in the winter. When the IAT goes below 80*F the ECM jumps up like 4* add degrees of timing advancement.
  19. Most people get the rebuild kit from Pirate Jacks and rebuild the hydroboost unit. https://piratejack.net/hydro-boost-rebuild-kits/
  20. Southern Idaho, I tend to keep the tank above 1/2 tank. That area down there is known for high winds. My last trip from Ontario pushed on me sideways all the way home. Really sucked for MPG performance like 18.38 MPG. High wind gusts. Now starting my morning at 19*F and breezy at 3 to 10 MPH and at least 1 inch of snow. Ugh.
  21. No scan tool can read the MAP sensor correctly. Mine reports 28.3 at 2,800 feet for 2001 MAP sensor. Mine will max out at 37.3 PSI
  22. Yup. The Quad can remain hooked up during a Smarty or TSB flash for high idle. Being the Quadzilla has ZERO connection to the CCD network or the SCI network which does the actual flashing.
  23. I would avoid that kit that is just me though. Quick connectors tend to always leak air. Then having the the stock draw straw used is too restrictive for a 165 pump period. Then if your using the stock backet your returning hot fuel to the pump to pick up first. Should have its own draw straw away from returned fuel from either the pump or the engine. Should be all 1/2 hose from straw to engine. Should KEEP the stock filter. Doubled filter is optimal and the fuel heater helps a bunch for winter. (+19*F here this morning). FASS pumps because of the large size are more prone to gelling issues. (Which my AirDog never had an issues with all the way to -40*F)
