Electrical Article - Alternator and PCM protection
150 Amp circuit breaker it is mounted on the firewall side of the battery tray away from the heat of the radiator. This will stop false tripping. Fuse should be installed closest to the PCM plug on the blue wire. 5 amp max fuse.
Strange p1689 code with fuel knock
- Strange p1689 code with fuel knock
P1689 is a communication problem between ECM and VP44. There is a CANBus + and - leads. You need to ohm from end to end should result in <5 ohm, over 5 ohm signal is degrading. Then same wire to ground this should result in infinite ohms. Short to ground is bad.- Anyone use any oil drain valves in place of the drain plug
When damaged or weeping. 398k miles still on the OEM plug seal.- What causes Low Line Pressures on a 47re trans? Can we make a list?
Better than being a dumb ...- Second best option for headlights
- Real head banger, built ats transmission
Time to talk to @Dynamic...- Stuck open injector?
Not really. Just need a good sense of touch. Just like installing injectors.- New Quadzilla installed--low power and 0 smoke?
Personally I don't like the straw in the basket. There is the the thought of 1/2 or lower your keeping all the hot return fuel in the basket and very little cooling. Where the AirDog returns to the filler neck, the engine returns to the basket and the draw straw is no where near either. Hottest fuel temp I see typically is 135 to 140*F barely. Typically my IAT and Fuel Temp match. Being I've got 243k miles on the last VP44 not a bad setup. Fuel pressure: 14 to 20 PSI Dual fuel filters: 3 um on the AirDog, 7um in the stock can. Fuel temp: <140*F Wire tapped, 7 x 0.010 @ 320 bar Injectors.- New Quadzilla installed--low power and 0 smoke?
No. It will fail. The measurement has to be done on a empty tank. This will be the shortest distance to the tip. Diesel weighs 6.1 pounds per gallon which is 213 pounds of fuel. This will deflect the tank bottom downward giving more gap. As the fuel is consumed the tank bottom tightens to the tip allowing to draw all the fuel from the the tank. Large notches or making too much gap gives 1/4 tank issues... Tip needs to be tight to the bottom which getting empty to get all the fuel. One quarter coin gap, 1/16 notches... Less than 1 gallon left in the tank. Notice the notch still under the fuel.- New Quadzilla installed--low power and 0 smoke?
Should come as a complete kit. Follow the directions on the straw and cutting. Do not customize or change the cut for performance. The tip should be as close to the tank bottom as possible. FASS suggest stacking two quarters on the bottom and that is your gap. I'm running on a SINGLE quarter gap for the all this time.- W-T ground mod
I tend to agree. There is no reason for over kill cable sizes. The stock size is going to be just fine too. If your worried about it then consider doing the the voltage drop test on the main cables and see if the cable is dropping more than 0.2 volts over the run. If it is I would replace the entire cable and maybe increase one gauge size.- New Quadzilla installed--low power and 0 smoke?
FASS or an AirDog. In tank pump will need to removed and converted to a draw straw. You could do a mechanical belt driven pump too. Same thing in tank pump has to be converted too.- W-T ground mod
Local hardware store... Nothing difficult.- Fuseable links
Risible links are buried in the loom. Check the alternator end for 12V. If the risible link is bad it will be zero volts. Field leads could be bad. If the + side shorts to ground it will blow the ECM voltage regulator.- New NV 4500 with South Bend DD, full package with 1-3/8th input. ( 4th gear vibration on deceleration) trouble
Both on the main shaft. Both are wore out hence why the mainshaft moves and kicks out of gear.- Driveshaft Center Bearing Diameter?
Exactly what you'll do. Pull the clamp, slide the boot back, measure with calipers.- New NV 4500 with South Bend DD, full package with 1-3/8th input. ( 4th gear vibration on deceleration) trouble
That is the only reason it will kick out of gear is the main shaft is moving fore and aft as you decelerate. During all my transmission work I ask for all the old parts during the rebuild. This way I can account for what work was done and see possibly the damaged parts. When I broke the mainshaft I had the same problem of kicking out of gear. Mainshaft was moving. When I ate 5th gear it worked fine. Shaft was solid not moving.- APPS voltage Adjustment - Stopping the Myths!
Should be no wiring mods to the APPS wiring. Either to the signal or ground legs period. Sensor ground is NOT body ground.- New Tires Cause constant Yaw Motion?
Caster angles could possibly affect the thrust angle of the truck slightly too. Might tire checking tire pressure and maybe do a tire rotation.- New NV 4500 with South Bend DD, full package with 1-3/8th input. ( 4th gear vibration on deceleration) trouble
Bearing failure. The mainshaft to moving forward and backwards enough to pop the shift ring out of gear.- Stuck open injector?
Could of been a nozzle that cracked. Pintle needle stuck open. In any case send them off to be pop tested is the right thing to do.- The good headlights
Typical sold as a pair.- Need help with tune
You can tap the wire and tune back on Level 3 which is the same of turning off the wiretap.- New Tires Cause constant Yaw Motion?
Tire pressure? - Strange p1689 code with fuel knock
