Egt’s
No, It will gain you MPG for sure. Like me, I'm twisting 2,500 RPM at 82 MPH but still kicking out 19.58 MPG. My last 3 years of fuel logs. You can see my Economy tune is also a big gain. 3.69:1 final ratio to the pavement.
Towing...Your Experience Is Appreciated 98.5 24V 2500
Not really. The top two gears are the same. Is just there is an extra gear in the bottom. Just consider the thought my current setup (NV4500 and 245's) I'm in 4th gear at 25 MPH. NV4500 - 5th gear - 0.75 NV6500 - 6th gear - 0.73 NV4500 - 4th gear - Direct NV5600 - 5th gear - Direct
Mechanical lift pump
Little birdie told me Assassin is China Made now.
Egt’s
Excessive wind drag and excessive low final ratio which I calculate 3.39:1 to the ground. You need to change your gears to 4.10 at least to fix this problem. Wind drag will ever go away with the lift. Bigger exhaust isn't going to fix the problem. 4" is plenty big enough which it will take care of 600 HP easy.
If you have 3.55 gears... Now for towing if you want a killer setup, drop the stock 265/75 R16 tires and switch out for the 245/75/ R16 you'll find you have way more torque and cooler EGT's. Then the exhaust brake works even better with the 245's vs the 265's.
VERY IMPORTANT!
2000 3500 no power,sucks fuel like it's free
That sucks...
No Start... Please Help!!!
- Best Place To get a new ECM
I would love to build and sell a VP44 test lead for that purpose with a toggle switch for power and protection fuse.- Quadzilla V2 reading inconsistent boost under load on 1999 24V.
Here is our list...- Towing...Your Experience Is Appreciated 98.5 24V 2500
Lots of options for exhaust brakes. If mine dies this is the exhaust brake I'll buy next. https://pacbrake.com/product-lines/exhaust-brakes/- 2000 3500 no power,sucks fuel like it's free
Not really. 12 MPG is something you should see towing 8,000 pound trailer.- Egt’s
You should be able to monitor engine load as your traveling. Max number doesn't mean much. I need to know your tire size most likely your final ratio is too low and the engine is struggling excessively. Final ratio to the pavement should be in the 3.55 to 3.73 optimally.- Egt’s
Extremely high. I barely float 700°F with the Quadzilla on Level 7 (full wire tap). I'm running 82 MPH at 2,500 RPM and still after nearly 100 miles of this netted 19.58 MPG. Engine load just barely below 25% which is my cruise limit and floating 26.89° of timing at 2,500 RPM cruise timing. What is your engine load like at 80 MPH? What size tires are you running? What gear ratio is in the rear axle?- No Start... Please Help!!!
What codes? Still need to know about WTS light?- Mechanical lift pump
Rare but does happen to get above 20 PSI of fuel pressure and push the front seal out of the VP44 dumping fuel in the crankcase. Remember the return port on the VP44 is much much smaller than the supply hole. Return in on the left and supply is on the right.- 98.5 QC seatbelts
Just a steep slope on my truck is enough to lock the seat belt and piss me off. The later truck use a swinging weight system to lock the seat belt.- VE pump tune up
From the videos I found they all show CCW from the front to advance.- No Start... Please Help!!!
First the ECM has to boot up and sense that the starter was bumped. If the ECM is not booting the prime cycle will not happen. Because aftermarket direct connect pumps like FASS and AirDog DDRP draw more amps than what the ECM is design to withstand. Full FASS and Full AirDog pump are fine with a protection relay. The other ones like AirTex pump etc. They again draw more amps to create the volume. You need the light in the cab. Being you have no way to read error codes being there is no PCM to start the CCD network nor the cluster to bias the voltage for the bus. Cummins Insite tool might help too if you have one. The WTS light should come on every key on cycle for at least a bulb test. No light, No boot.- Snap On tools are the best
I just got majorly ripped off. I needed a 17mm crowfoot to get 2 injection lines loose on a 92 Dodge. They always say shop local. $50 for a set of metric crows feet. If I would have waited and just gone down today I can get the entire set for mere $9 in Ontario OR. Yeah it might be Harbor Freight but $50 for crows feet is just sick and wrong. At the time I needed them so I ate the bill but now kicking my own tail for it. I gave up on expensive tools long ago. I use to make sure to buy quality Craftsman tools (Sears). Just no sense in it. Most of the time they argue about if it failed or was it abused or used improperly and failed.- No Start... Please Help!!!
Lift pump should pulse during cranking. 50% duty cycle. The reason for this is to keep the VP44 from over advancing during startup. This why you don't want direct power to the FASS. Then you'll get hard starts hot later on. WTS light is the next thing I need to know if it's coming on. If not then the ECM is NOT booting up at all. The first instruction is to light the WTS light and fire the grid heaters if needed.- The Quad is installed!
Actually low on the bottom fine up top. About 26° to 27° is all stock engine will give. Even with the injectors, I'm running I get bucking above 27°. The bottom end can come up another degree but you have to look at how much low boost retards and load base retard will cut back.- No Start... Please Help!!!
Might be to send the ECM in for repair. ECM should cycle on and off pulsing during cranking.- EGT Gauge Help
Glad you figured it out. Now you might want to order the ISSPro USB programming cable. Then you can program your warning light and the gauge lighting, also how fast the needle reacts. I would post up more about this but the search function is now broke and I can't find the article or my forum post. EDIT: Finally found it using Google. - Best Place To get a new ECM
