Word of thanks and some questions
I'll have to wait till sunrise to get a photo of my location. Just walk out and plugged in the truck damn cold morning at 17*F without grid heater it's not going to fire up very easy.
Normal to have a lag of about 2 minutes till it starts this just ensures the engine is lubed up before placing a load on it. Normal. When making a change that wide across the temperature range the timing map is altered so it skips a beat kind of. Typically people slit the rubber boot on the wiring boo and come through that bulkhead connector. Never thought to use the hood cable hole. As for location mine is hidden in the pouch near the passenger side.
Smarty lvl9 with comp box on 5x5
Just like stacking a Hotrod VP44 and a Edge Comp going to net you about the same thing too much timing. Just because you can do it doesn't mean its a good idea. Like my current tune on the Quadzilla I'm about 2-3*degrees retarded from stock timing in the cold. This gives the same effect of my Mopar1973Man MPG fooler without the fooler in place. Excessive timing will produce a effect of negative torque which believe it or not will increase engine loads.
Boost Whining - Don't Think It's A Boost Leak
I've used the exact same kit to rebuild my HX35/40 hybrid. Good kit everything you need in the kit is there.
NEVER buy parts from eBay just way to risky. Especially being we are taking about parts that spin at speeds of 25,000 RPM's you don't want Chinese Crap to blow up in your turbo. Holset Parts!!! Matter fact being I'm helping with SmartyResource.Com and building them a database for MRP price policy violators... I've done some searching on eBay for some of these providers and there is no support, no contact information, nothing so if something goes wrong your out of luck.
Cummins High Idle and Quadzilla High Idle
Just found out that Quadzilla high idle and Cummins High Idle can co-exist with each other with no problems. This morning I fired up and it was 24*F outside no grid heaters hooked up started easily with about 2 extra revolutions of the engine. 30 seconds later the high idle fire up on the Quadzilla. Walk back in the house. 10 minutes later walked out anf jupm in the truck and looked at the Quadzilla and it was 150*F it should of cancelled. It did the power level was shown in RED and level 3 was selected it was the Cummins High Idle was running 6 cylinder mode. Cancelled normally with the press of the brake pedal and of and running. No issues...
High amp alternator
The armatures are solid rings. So the field power is constant. No like a starter armature with multiple contacts or commutator. The only time you would have make and break is like my second alternator had a bad rear case and the bearing was loose in the case so the armature could bounce away from the brushes and break contact. Not seen another like this ever. Still need to chase down the excessive load problem. Something has changed and exceeding the load rating of the alternator ro cause the diodes to overheat. Currently, I do not have any grid heaters and no alternator issue. So there is something to be said about my theory of the grid heaters being a cause.
High amp alternator
Just for fun... I went out and did the AC noise test grabbed my Fluke 75 meter and got ~0.032 AC volt at idle and with all stock loads on in the cab I barely tipped ~0.040 AC volts. So I pull the alternator cleaned all the contact points of the alternator and brackets. I'll admit the bolts had some rust on the exposed areas but the contact faces and the threads where still clean. I wire brushed everything clean including the brackets and the bolts then lighting greased everything. Assembled again... Retested and got the very same numbers as before. So grounding isn't exactly my issue with my problem it trying to figure out what is dropping the huge load on the diodes and causing them to overheat. Coming back to the grid heater. Now after talking to @W-T that the solenoid/relays could be a issue with contacts pitted over time. Scratching my head and thinking that if the contacts go bad like starter contact then the power is reduced ot the grid heater reducing the load on the alternator. I'm still thinking the grid heater is changing its ohm value over time and becoming a more of dead short as the heating element wears out.
Not starting after warm
Lift pump is directly powered by the ECM in stock form most of us have aftermarket FASS or AirDog pumps with a relay in the system to protect the ECM from damage.
Testing Injector Pop Pressure in the real world
Stock is 310 bar (+/- 250 PSI) which makes it 297-327 Bar which is allowed.
High amp alternator
Might go up against my corrosion free 20 year old house power system with lead-acid batteries. this is only my second set of batteries. Equalized charged after topping off water about every month. These batteries are used 24 hours a day, 7 days a week. This is what powers my house. Even though I do have city power yet.
How to import / Export custom tunes in the IQuad App
Confirmed. Mine is off by at least 2 MPH compared to GPS and the cluster. 99.7" tires and 3.55 gears. Can't be using old technology. Like I've got an LG G5 cellphone (released on April 23, 2016). I know that LG plans on releasing Android 8 (Oreo) update for the LG G5. Like MoparMom's LG G4 phone will not get the update because its too old (release date April 29, 2015). My old Azpen A729 tablet I had to retire early because of the fact it was only $40 buck the software was also older Android. It didn't display the gauge needles at all.
You have to remember at WOT throttle the VP44 creates like 20,000 PSI (1,378 Bar).
High amp alternator
You'll have to go up against me as with some of the longest lasting lead acid batteries at 12-13 years old. There are a few tricks you can't do to AGM and tend to have shorter lifespans typically. You can't equalize charge an AGM. You can't top off AGM with distilled water,
Look at the compressor housing for wheel rub marks. This will be a clue of the imbalance. If so I would suggest the bearing be changed being the turbo spins at about 25,000 RPM's quite fast.
That is partially why I suggest replacing the compressor wheel not knowing if any of the blades are bent or imbalance is occurring. While the turbo is apart you can install bearing and inspect the compressor housing and see if there is any problems with the housing.
Missing, random codes, occasional stumble at idle
If the factory one is still working leave it alone. Cam sensor typically doesn't fail like the early series with the crank sensor which was prone to failure. 333k miles on my sensor still going strong!
Only has a EXPORT button. No import button that I know of on Andriod. All I do is attempt to open the downloaded file and presto the file is imported to the App and just got to name it.
47RE heater exchange flush
There is a few flush kits in a can where they basically just basically screw the can on and pull the trigger...
Too Funny not to share!
I'm not going to touch this... The truth though is the only reason why there is all these problem people are paying 60-70k for a truck are not willing to gamble much with modifications not to mention taking the chance of voiding the warranty. Now if we had prices down to what we paid for our 2nd Gen's then I would jump in and buy a 4th Gen and learn how to make then better without deleting them. That's cheating. Kind of like p-pumping a 24V to ditch the ECM and VP44. So since no one is willing to modify or be there own warranty station on a 4th gen. So here we are complaining about 4th gen problems.
Minnesota... Like myself, I'm in the backcountry of Idaho. Man, I hate it when I got to drive to Ontario, OR or Boise, ID. I'm so ready to bail out and head for the mountains and get away from the crazy people of the big cities. Yes, I've got neighbors but I've got a good margin of space between us. Shot this photo from 5 miles away on east side mountain ridge. I've highlighted home
I tend to agree with @IBMobile . I would consider replacing the compressor wheel. While you got the turbo removed why not just rebuild it with fresh bearings. Bearing kits are less than $100 bucks and really easy to rebuild a turbo. Then I would pull the tube from the input of the intercooler and see how much of that foam rubber is in the bottom of the intercooler or possibly stuck in the tubes. I've been here before too so don't feel bad...
More of this series...
Might be just the lift pump driver is damaged in the ECM. Find the plug for the lift pump near the ECM and test for power after bumping the starter.
Correct me if I'm wrong on this TC issue I have.
Could go ahead and ask our site transmission builder. @Dynamic is a good transmission man and might be able to help out.
