  1. Could be that the pump is installed wrong or the dogs on the vacuum pump or the power steering pump are damaged and not spinning the pump. you might have to check. Also that why I prime the pump by letting the steering box pull the fluid through by vacuum. When the axle is up and you go lock to lock the valve is open to apply power but there is no power there so the vacuum of the steering box will pull the fluid through the pump to prime it up.
  2. I'm assuming this is brake hyrobooster and power steering pump. Typically I prime the system but filling the reservoir and with the front axle lifted off the ground, engine off, key in the OFF position. Now go lock to lock to pull the fluid through the system. The other problem is when a pump fails typically it pushes debris every where plugging ports and orifices in the steering gear box and the hydrobooster. You can verify the prime by leaving the steering box return off and continue to go lock to lock till fluid appears at the return.
  3. Betcha they are replacing ball joints and tierods often. Then like you mention the economy must suck being the rear gear is way lower now and out of the optimal ratio. but hey... I T L O O K S C O O L
  4. Welcome to the family of Cummins Nuts! We've got all types here from daily drivers to performance nuts. There is plenty to learn...
  5. I see this kind of "Cool Factor" every where from totally slammed to the ground to jacked up a mile hifgh. To aggressive rake. No matter how you slice it the geometry of the front axle is trashed and the performance is junk.
  6. Just the rear hoist ring with two 15mm bolts. Just pull all the 10mm bolts holding the injection lines. 8mm bolts in the injector hold downs. Apps sensor and intake horn. That's about it.
  7. Takes me 1.5 hours to change out injectors on a hot engine. Ask @hex0rz about his swap I did at 7pm at night in my yard.
  8. Post it again. I ran into the same problem with Mopar1973Man High Idle Ads and second time they let it go.
  9. From his signature. As I said... Alters the final gearing... https://mopar1973man.com/topic/13623-2000-to-2002-steering-upgrade/?do=findComment&comment=171749
  10. Crap. Then ask DAP for a set of o-rings.
  11. Ahh... DAP injectors come with new o-ring included.
  12. That is for maximum payload. Check out my article on tire pressure it will get you really close to right.
  13. Cummins would be one spot but my experience they quoted me about $660 for all six connector tubes. So I bought mine at Vulcan Performance for way less I think it was right around $100 or so (CRS moment...) Cummins was way too proud of there brand name.
  14. Well, that's wrong... Front axle yeah needs 60 PSI but the rear don't. Maybe 40 PSI at the most. I would say either toe or tierods are getting sloppy. Possibly a track bar.
  15. I wore them nearly out at 25k and sold them with 25% tread just to get rid of them. Got tired of the constant loss of MPG over a heavy tire. Cooper's where closer to 90 pounds per tire 265/75 R16.
  16. Bring out a bit more the design was to have mirror pulses. On one wire there is a positive pulse and then on the other wire there is negative pulse as long as both pulses are seen then the computer assume the signal is valid. So if noise is introduced to one side and another pulse is added there is no mirror pulse so the computers disregard that pulse as being valid. This system runs nearly the same rules as CAT5 cabling for networks.
  17. Hence what I said... The funny part I see about tires and wheel all the time is people buying wheels and tires that are much bigger than factory just for the "Cool Factor". So now what have you done? Reduced your final gear ratio Increased the rolling resistance Increased the rotational mass of the tire Reduced MPG's Increased overall cost of replacement Increased wear on brakes Shorten lifespan of front end part and steering gear. It might not have the "Cool Factor" but I've got more money in my pockets and less failure with the front axles and brakes. Very minor change to final ratio (1 Rev/mile difference) Reduced rolling resistance because of less tread face on the ground and using A/T tread and not an M/T tread. Improved ice and snow traction. Reduced the rotational mass by at least 25 pounds per tire! Increased MPG's (Record is 27.2 MPG hand math) Reduced cost of replacement this set cost me $580 bucks for the 235/85 R16 Hankook. Reduced wear on the brakes not having to stop that rotational mass spinning on the axles. (Brakes are replaced for the first time at 185k) Extended the life of all the front end parts and steering gear. (Still got factory OEM Tierods, gearing gear and power steering pump)
  18. That only 50mm or 2 inches in width difference.
  19. Hard to tell a 235 vs 265 being there is only 1.1 inch (30 mm) difference.
  20. Call your local tire shop and see what they can order.
  21. Being you live in salt country, I don't suggest fender flare. Like most of the trucks around here with oversized tire and fender flare end up with fenders rotting out from the fender flares.
  22. 7.86 - 7.82 = 0.04 inches 1mm = 0.039 inches Yes, 235's are 1mm taller. For the 265/75 R16 vs 235/85 R16
