Dieselfuture
  1. Could be something to do with magnetism from Earth like ac noise
  2. I'm going to plan on hour and a half
  3. Wore out injectors, boost leaks, low compression, something along those lines Edit, come to think about it, dirty air filter
  4. Why you're selling it again, after all that work and love, guessing it's to buy a 5 or 6 Speed without 53 block and Quadzilla already installed
  5. Yeah, get a new gasket regardless
  6. I assume obdlink is good enough to read these types of codes, because that's what I have and I have zero codes thank God
  7. If that's the case then just do it, if you don't like it unplug wires
  8. Seems to be really close +-1/2 mile play with it a bit to get it where you think it needs to be. I still don't know if I want to trust GPS fully.
  9. Ha ha, I think @jlbayes was talking about magnets for gasoline engine, there were a lot of people few years back saying that if you put magnets on fuel line will increase fuel economy. I went a step further and made a hydrogen cell that actually gained me about 3mpg on my sentra I had. Edit, who knows if I would have combined that with magnets I might've been making fuel
  10. To OP. This is not aimed at you by any means, we're just goofing around.
  11. I'm not good at following directions
  12. So is dual disc more for towing, how's daily driving/having fun with it. I've looked at dual disc option before but most say stay with a single disk.
  13. Possible mistake at install, I believe Yukon can tell what went wrong if they see it, but don't know if its worth the headache
  14. Are you telling me that putting 30 some magnets all over inside the engine was a waist of time
  15. I knew these things were a life
  16. I would just put new alternator on and test that if your meter is still all over the place then I would be looking at the different meter
  17. It will help, but if damage is done you need alternator, maybe verify with a different multimeter to be sure.
  18. Maybe both, usually it will try to take ring out 3 teeth one full and one on each side partial, from biting traction or some serious jerking. What brand did you use, did you do break in procedure and oil change soon after. I've done gears before and it takes some time especially if you don't do it every day. Maybe something came lose didn't get lock tited good enough. Need to inspect it closely.
  19. I've witnessed more than once now when I get off the hwy and stab the go pedal quickly few times I'll have white smoke come out, not a lot but definitely white, then I go to take of in gear and it's back to more black puff. Funny thing is it's the same exit, I need to go a different route ha ha.
  20. Sorry to mislead you looks like half of it is discontinued anyway ignore my previous post
  21. http://www.moparpartsdiscounted.com/search_rushmore.php?dl_id=356&srch_str=Spring May want to put correct info of the truck on that website I just went with 01 5 speed I bought a set of front springs for my truck from there, they roll the plow package heaviest rating you could get, did that after I put my heavy homemade front bumper on
  22. You probably don't have Quadzilla, but wouldn't that show a sticking timing piston @Me78569
  23. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/obdii-error-codes_94/
  24. Got anymore pictures of cylinder walls, curious to see comparing to mine. Are you going to surface and check the head, pulling any valves out
  25. Good to hear, hopefully that does it.
