Dieselfuture
  1. Oh no, don't tell me there is a portable TPMS system out there, and all I need is an app for my phone. I don't want to spend anymore money
  2. Fill out your signature so we can all see what we're working with. Have you read through the Forum to see any related issues. There's been a lot of discussion lately on AC noise ecms and wiring in general. I would definitely start by checking excessive AC noise. Then if money is not a big issue maybe change oil sending unit just to rule out an internal shortage of that sensor. You may have 5 volts at the plug but if the sensor is shorted internally when when you put your plug back in it ruins your 5 volt Loop. Maybe invent in obdlink, then you can monitor sensors life. You can get one online for 50 bucks shipped. All you do is plug this little box in your OBD and download the app to your phone. Look for the loose wires bad connections, make sure all your grounds are in great shape battery terminals etc.
  3. When you do check for Boost leaks make sure you set your pressure at 25 30 PSI don't just blow full compressor pressure in it. I'm sure you probably thought of that but just in case. And make sure whatever you make up to test for pressure is able to hold at least 50 psi or more just to be safe.
  4. There is a lot to learn about Quadzilla and V2 tuning but well worth it in the end. If you do get one there is ton of information on this site and everyone is more than willing to help you get going. There is even pre-written Tunes you can download straight to your phone or tablet. If you order a Quadzilla just tell them to load the latest Flash on it which is 2.7 or you can do it yourself but it takes some knowledge about computers. All this information is on this site. https://mopar1973man.com/forum/174-quadzilla-power/
  5. I'd start at 10.5 or so and work my way up, haven't you seen pawn stars. Lol.
  6. Mine seem to function properly if anyone cares to hear.
  7. Any boost leak is bad, I would double check to be sure. Make something up to go on turbo with an air fitting and pressurize the whole system, go around with spray bottle and some dish soap. 30 PSI is nothing to be scared of and should help with power.
  8. Have you checked for boost leaks
  9. This white truck seems okay with new tranny, but then again why put new tranny in and sell it right away. Unless he's just done with it. You're right about putting price on our trucks, there are some obvious ones that you know being beat and not taking care of, easy to spot. But then there are other ones that are well taken care off and have all the important things done to them. Like for example my truck, I know it's not perfect but I know what I have and what I have invested in it and there is just no way I would let it go for less than 18k, now that sounds like a crazy price for something that has a rust hole in a rocker they would think I'm off my rocker. Then again if they have no clue or knowledge to what we do and what we invest in these trucks, definitely takes special group of people to buy these. So maybe trucks that people want more money for is worth it if they truly are what they say they are.
  10. I used to be amazed that most have no clue what's going on but now I'm getting used to it. And I don't mean this in a bad way, it's just most have enough in their life to worry about then looking into things. The reason I was asking about the whole 5G Network stuff, I figured with some clever Minds on this site I would have more input on the subject other than what random people have to say that might not have a clue about RF /radio frequency. I guess the idea behind 5G is to put transmitters everywhere for better wifi and whatever connection, that means big cities/smart cities will be saturated with this frequencies and eventually It'll spread everywhere. And according to some studies these frequencies are somehow different from 4G and could potentially impact biological life. I basically wanted your guys's take on it if it's all Bs or there is some truth to that. I personally spoke to a few people that work on these antennas, and truthfully never got a straight answer. But they all said that they try to spend least amount of time right next to one and how they can't wait to get out of the field into the office. I know there was a big scare about microwaves and still is but most ignore it, then there is cell phones and how they supposed to cause tumors if you're always glued to one, then the Wi-Fi and smart meters. I don't want to sound paranoid but I would like to know from someone that knows not just thinks. Just because you can't see it doesn't mean it's not there. And that logic can apply to other things. Sorry it's still early just started drinking coffee.
  11. Please forgive me. With all brain power here I'd like to ask an off topic question. @W-T @notlimah @trreed and anyone else has thoughts. There is a lot of controversy going on on Internet over a 5g network topic and health side effects, any input on that. ?
  12. Next time it does it dump cold water on vp44 and see if it helps, almost sounds like lead free solder problem in psg of vp. Is vp original or reman. This is just a guess and I might be off and sometimes this problem won't give you codes ether. On the other hand it may just be a bad crank sensor.
  13. I hate to give you advice on electrical stuff but I have to agree with ^^^ Did you check oil pressure sensor/sending unit And truck will run without lift pump but it's not good for a long time especially if you have to drive it that way. Vp has internal pump sufficient enough to idle that's about it. But with an aftermarket pump like fass it has to work extra hard to pull fuel through it. So best not to run truck without lift pump help.
  14. Is that a good brand to go after
  15. Yeah I agree with the above, but it is much older than the tires I usually get. Maybe it's better to use larger sites where they have more flow.
  16. I believe oil pressure, map, apps sensor maybe some other ones all share one 5v loop. You can unplug any one of them and check for 5 volts, maybe worth checking them all for 5 volts. Also I would ditch AutoZone or whatever apps sensor and get a mechanical one, @Mopar1973Man has them here for sale.
  17. Ha ha, now that you said it I could see how new society would think that way. Man these people are affecting everybody now, wish they would just crawl back under that rock. Penis=boy, vagin a=girl end of story
  18. Did they say it was Salvage, I'm guessing not cuz that would definitely put a dent in the value. I bought a few salvage cars in my life will never do that mistake again. No wonder it has new paint job.... This is kind of off subject but I swear previous salvage vehicles are haunted, if it happened once it'll happen again. Just what I've witnessed.
  19. If you're looking at decent affordable injectors with Bosch bodies I'd probably go with DAP. They have quite a few choices, some are afraid of vco but I heard good things about them. I got sac right now but they are only 75hp I think if you go bigger sac gets to be more dirty. Someone else will know more on injectors.
  20. Thank you, originally I thought you had big ground wires on a switch, I didn't want to go that route without a massive relay or like you said a second set of relays. So now that you've mentioned it again that you have small ground wires to trigger relay on a switch, makes more sense. I'm a slow learner because I'm I am hurry most of time and pay the price for it too sometimes. Is switch sufficient enough for trigger wires or is it better to put them both on a relay, maybe even tie them together on one relay.
  21. I'd have to blame it on the new injectors if it was idling fine before. That are you might of bump some wires make sure everything is plugged in. Edit. Maybe you have a high pressure leak somewhere one of injectors not firing. Crack em one at a time and see which one doesn't make a difference
  22. I've asked this before but I want to ask it again. Let's say before I shut down I download anti-theft tune and live it on level 1 with say 15%, then I'll shut down take the phone with me and live it at the house far away from the truck so it does not connect again, will adrenaline download the latest tune and level that I left it with.
