Bobbing of idle with larger injectors fix
Logic would say yes, but I'm not me either
Well the Order is in
I think we all cuss at our trucks once in awhile. But it's that time when it purrs like a tiger and pulls like an elephant that makes it up for it
1999 2500 just shut down
I didn't care for my Boost elbow maybe I have a junk one, hard to adjust to just the right spot and it has a small pin hole in it for bleeding air off, so basically it's a constant small boost leak. I just put a plug where a boost elbow goes and now rely on Quadzilla defuel settings
I must have missed it somewhere, did you already get rid of your 2nd gen
No Fuel
I believe you're on the right track sadly that is no easy way to tell, like Mike suggested if there is another pump in line that's slowing flow down and there were occasions with plugged screens. Plus if it's all factory, lines are pretty restrictive. In my opinion chances are VP is probably shot or on the last leg after a treatment like that. If he's planning on keeping this truck I'd say new fuel system with a gauge obviously and possible new VP
bucking in drive and OD
Max load timing offset
Lift pump issue
Yes check that first ^^^ sounds like a possible ecm problem, which leads to checking alternator for excessive ac noise. Also relay that comes with fass or air dog is not a protective one, you need to get one that has a resistor or diode for when it's denergized and doesn't send current spike back to ecm
Quadzilla
I was going to comment on how to make it smoke but, nah... I guess I don't care for smoke myself ether. When I used to race smoke meant you didn't know how to tune properly, but when new to this game it's cool for a little bit but gets rather annoying soon after. PS. if you want to smoke. Less air more fuel will get you there but most will not like it and will point fingers in our direction, which is not cool and gives us bad name. Use at your own risk.
Truck race
I actually watchedthe whole thing
Drive train info
I bumped mine to 98 it's about perfect now. I'm happy. Funny thing is I tried GPS on my Honda and if I'm going 65 GPS is telling me I'm going 61 so somehow it's off even with correct size tires. Truck was opposite lol.
Any one use these injectors
I'd go with Vulcan then if they are genuine, keep competition honest.
New member..frustrated..abs/brake light
Sometimes a broken wire by rear axle, it rubs on sway bar.
Starter turning slow
I see I'm late to the party and you already made right choice, contact and plunger kit usually does the trick. And yes very easy to do.
HELP With 1/2" fuel line barb fittings
Yes^^^^^, but baby in boiling water now I know what's wrong with me
Need HELP With Vulcan Intercooler Boots
Man... isn't there any real man left out there or is it all keyboard warriors.
I just want to clarify that I'm not a girl Ha ha kidding I know you speak of your self, hats off to you madam. I can just picture my wife laying next to me under my tuck handing me tools .....
I've built a lot of projects in gravel lol
Fuel injector lines
This brings another question, by raising pop pressure does it reduce life of vp
Just seeing who's paying attention ha ha, you get a
air filter
You probably going to want to make some kind of heat shield for it and put some rubber hoses on air conditioning lines and whatever else will be in the way of heat shield and filter so things don't get robbed through
That's exactly what I did on mine too That's exactly what I did on mine too That's exactly what I did on mine too
95 12 valve busted gear case
Another update for those who is interested. Finally figured out why torque converter would do a lock unlock with similar symptoms as a bad alternator. So he had his alternator rebuilt now has about .03 VAC but that didn't help the way torque converter was acting up. Problem was in TPS voltage setting, his whole lever must have been worn enough it wasn't grabbing sensor to rotate it and change voltage, it was basically always reading 0.3 volts so I made a shim and we got it to about 1.2v. Now torque converter does what it's supposed to, he's all happy and giggly.
Quadzilla PV1
That's why I'm hanging on to my S6 in fact I got two of them one for the truck and one for normal use, you can find them used for under a hundred bucks. This last one I got I had to update software about five times before it was on the new enough version to work good with quad. But I stopped updating it after I liked what I've seen, I think it said something 2016. Reason I don't update to the latest is sometimes they don't have all the bugs worked out and you have problems, like battery goes dead too fast. Reason I was suggesting Droid is just to use with quad, it's more friendly and you can use apple core for whatever else.
intermediate miss at idle
Something ain't right, I would be checking for possible boost leaks. Did it get model laggy on take off and more smoke. Little smoke is ok with slightly bigger injectors, but if it takes longer to spool turbo you probably have a boost leak.
How many KMS/MILES you got
@bigfish95971 this is the thread I was talking about, so your post is here now too. 650,000 MILES! this past week Mine 99 2500, 53 block, lilt pump in tank now. 650k mi today. Afe filter cleaned once a year whether it needs it or o=not. Same with an oil change. up to 30k. Several years of constantly watching alt AC and lockup issues, One ECM about 3 ev44's, no issues since lift pump to tank. Rebuilt front end mostly once and several track bars until Good Moog problem solver.Engine or head never out, valves adjusted twice, one radiator leaked.cleaned external twice+two sets of starter contacts and one brush job. Couple of trani output gears in to the TC. NO other hard parts for trani. Nw that replaced the Tappet cover and Vacuum pump seal and sleeve again and controlled most leaks, not not more thant w spots of anything, pan seeps but never off. Uses Walmart oil from major mfg in Texas, Uses about a quart in 1000-2000 miles. GETS 17-21 MPG. DRIVE IT LINK A GRANDPA EVERY MINUTE. SELDOM OVER 54-62. SEMI'S DRAFT NICELY. 99 4x4 SLT, 47re, in tank pump, winch and bumper, BD van Aaken chip, 650k miles.
