AH64ID
Everything posted by AH64ID
  1. Interesting, I have always understood it to be the pump. Some pumps limit my AMEX to $75, some to $100, and some to $125. I would have thought a bank would have a constant limit. Maybe I will call and find out. The difference between the card reader and inside is that inside isn't a preauthorization its a regular purchase that requires a signature.
  2. I saw 102° on part of my drive home in Boise today, but by the time I got to Kuna it was 91°.
  3. There has always been a fee, but I am telling you I have called twice and gotten free updates. I asked about software glitches and they upgraded me. If you tell them about your MAP sensor issue, 15.1 psia engine off, I bet they upgrade for free. In my experience the fee is for people that want the upgrade, and it's fee for glitches.
  4. Interesting, I have never been asked for a receipt.. either of the times I sent it back. If the MAP sensor is not bad, and the SGII isn't setup to inHg then it sounds like a SGII software issue.
  5. The SGII should have the option to change the units. It's weird for sure, but it's a SGII issue and not a 24V issue... Or none of the other readers would work. I bet if you call SGII they would have an answer for you, and probably a free software upgrade.
  6. How far behind you was he? Are you sure that wasn't the pump cutoff? seems to coincidental.
  7. The turbine will push 2:1 at around 2800 rpms and 30 psi of boost... The compressor is capable of at least 2x, if not 3x, the flow of the turbine. The tight turbine will also overspeed the turbo. I would set the wastegate at 35, or look for a spare turbo. They don't last long above 38-40, historically speaking. Based on it's map peak airflow occurs at 33psi at sea level.
  8. If other products read correctly then the ECM is putting out the correct MAP pressure, as there is no output for boost only MAP and ambient pressure (IAT). For a SG or Attitude to read boost it does math, it takes the MAP pressure and subtracts ambient. This is also why digital boost gauges will show 1-2 psi more than analog, or even more, since they reference boost from the intake restriction to max pressure. So if others read the MAP sensor correctly why doesn't the SGII? I am not talking about the above 20 psi, as the sensor is beyond limits, but why does it show 15.1 psi at idle? That's not a skewed signal, because if it was nothing would read boost correctly at the low end. Still haven't answered my question about inches of mercury. Why not send the SGII off for an update? They never charged me and I have had it updated twice.
  9. It would be a ECM issue, not a SGII issue as they don't read or even have access to the actual signal from the map sensor. Do products like a edge attitude read boost correctly? Did you see my question about inches of mercury? That figure is very close to the proper level of ambient pressure in inches.
  10. Hmmm.. The upper limit is certainly a OBDII limit, and still holds true on new trucks. OBDII was designed around sending 256 characters, 256 kPa is 37.2 psi. I am not sure the skewing makes sense, why would the ECM want to read 15.1 psig off? There are several connectors for MAP sensors over the years, but all the data I can find shows they are all standard 5V pressure transducers where 0.5V is 0 psi. EDIT: I just had a thought, is that inches of Mercury? and not psi...
  11. Looking at my truck it lines up perfectly with the radiator support, is it possible they share a single long nut?
  12. Your MAP sensor is broken. It was reading 28.3psig with the engine off, or 15.1psi of boost at 3,000 feet on a standard day. The high boost reading with the engine off is indicative of a failed pressure sensor, the 37 psi limit on the upper end is the OBDII limit as you know. I am not sure how much the boost reading effects fueling on a VP motor, but on a HPCR it's huge. What you have there is about a 1/2 smoke switch. No you cannot. I have been thinking about asking them for that, but I don't think it's an OBDII readout but a Dodge specific code. The mileage may not be accurate on an 06, as the OBDII mileage readout isn't very accurate or correct on that generation diesel. My 05 included.
  13. The boost issue, I forgot since I don't watch it so thanks Michael, is that OBDII isn't capable of communicating full boost. I can only transmit ~37psia, which at sea level is 23 psig. The stock 06 makes ~32. The ultra gauge is still a great, and cheap, gauge to have will all of its OBDII sensor read puts and is probably the most reliable rail pressure gauge.
  14. It wasn't too bad, but the front felt a little light in dips. What you can't see is that there where 3 adults and 4 kids in the cab. I get to spend 2-3 weeks a year in or on the border of the Frank Church and I don't thinks it's enough... Yup, well close... we where on the far eastern edge.
  15. I'm not worried in the least about anything. It did very well, no real roll to speak of either and there where some steep/windy sections. The biggest issue was how far back the 11' camper was since my toolbox didn't come out. We ended up on the edge of the Frank Church Wilderness.
  16. My buddy had a power steering pump issue on the way camping, so I took his camper and gear the last 30 miles. He scaled 13,300 that morning in an 07 QC DRW. I am pretty sure I was pushing 14K with 9K on the rear axle. I could only get the air to 94psi with my OBA (I need a new pressure switch), but never topped 20 mph.
  17. Only if tuned, if stock I wouldn't bother... it's a scary sight to see those OE EGT's. But on a tuned motor I agree 100%...
  18. Boost yes, Pyro no.
  19. Not many OEM TT's have inverters, in fact I am not sure if I have ever seen one at a show or otherwise. Some of the $$ RV's do, and probably some $$ 5ers and Toy Haulers too.
  20. There is also wheel bearing cost savings, and u-joint savings. But $$ isn't the real reason to do it, it's the better steering, bearings, and 2Lo.
  21. 2nd gens are looser than 3rd gens and it was a huge difference on stock tires. You would be simply amazed at what it does to an already "tight" front end.
  22. Interesting, you would think it would be easy for a welded manifold like the Steed.
  23. Was your last tank lower than average? Some pumps may "overfill" which lower one tanks economy and raises the next.
  24. Yankneck nailed it, the VE flange is different that a T3 flange. The biggest difference is where the turbo sits, but some get it to fit with just the adapter. You may also ask a company like steedspeed if they will make you a manifold with the WGMT flange in the 2nd gen location.
  25. An ultra gauge will tell you if you have a MAP or IAT sensor on the fritz.
