Everything posted by IBMobile
7 way trailer harness
Did you smoke the wires on the trailer or the truck? Is it the trailer brakes or the truck brakes that don't work anymore? What happens when " However using a test like everything is hooked up as it should be"?
Ground Reference VP44,ECM,PCM,PDC plus TC lock/unlock
@Dieselfuture is right that If the PCM control wires are grounded to the body then there is a chance of high electrical resistance from rust, undercoating or paint, in any of the body panel spot weld, bolt or screwed connections. By soldering the splices in the PCM grounding wire and keeping it routed straight to the battery ground, a good electrical bound is formed and 0 electrical resistance . The PCM is mounted on plastic so the outside case is grounded (bonded) to the body (fire wall) with a ground strap.
2nd gen engine cooling
Yes "ram air" starts to become greater than fan air above 35mph but, when towing an 8K LB 5th wheel, I've also heard the fan clutch cycle on and off while going up long 6% grades while locked up in 3ed. Exhaust temps will climb to 1200°F+ if left in 4th (over drive), in 3ed I can keep it below 1000°F Truck has 245/75-16 tires with a 4:10 rear end
I can see!!!
Could-a been worse..... LOL ….. Glad you can see now.
Sway bar nuts and bolts
Try Rock Auto for there stabilizer bar (sway bar) parts. They have stabilizer bushings, link rod and hardware parts https://www.rockauto.com/en/catalog/dodge,2001,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1366602,suspension. You can also go here to look up needed parts. Stabilizer bar on page 35, figure 2-130. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/part-number-lookup-tool-2nd-gen-24v/2nd-gen-2001-2002-dodge-ram-part-number-lookup-tool-r389/
Lockup bog/timing torque/general q's
You want it on the trans side but no need to cut just use a quick splice connector to attache the grounding wire to the lockup wire. You can do something like this or trying to just running the wire through a switch to ground. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/52_transmission-transfer-case/diy-converter-lock-up-with-brake-pedal-release-r536/
The OD switch can be replaced by just using a small pocket screwdriver to pop the old one out, unplugging the two wires to it, plug the wires into the new switch and snap the switch into the end of the shifter. You can get the switch out of a wreaking yard. The same switch is used in ram 1500, 2500, 3500, Durango and Dakota.
Roof Issues Anyone?????
My wife must have heard your wife because she said the same thing. I had found a nice 1 year old 5th wheel but "NO" she said "I want new, not someone else's dirty old trailer".
Thanks, it's a piece of cake. I tried to retire but my boss said NO! She's using me as a tax write off.
I finally got around to cleaning up the ground wire splices for the PCM this week end. It's not hard and took very little time to do. NOTE: Do this after the other modifications have been done or you will lose the ECM, VP and grid heater grounds. You need: 2 10-12 gauge butt connectors 2 1/4 heat shrink tube 2" long rosin core solder 140 watt solder gun (Weller) or small butane torch roll of electrical tape razer knife wire cutters wire striper Remove air cleaner housing this will open up the whole area to work in. No need to disconnect the batteries, just unplug the gray connector at the ground wires of the right (AUX) battery. The other gray connector has already been disconnected when the ground wires were relocated to the back of the timing cover. Disconnect the 3 plugs at the PCM Cut and strip the 8 gauge wire then cut the connector off the 10 gauge wire and strip it back to fit the butt connector. This is the connection with the cove off. This is splice #S109 that the grounds for the ECM, PCM, VP44, grid heater relay and data link connector. Slide the heat shrink on to the wire were it won't be affected by the heat of soldering. Remove any plastic covering on the butt connector, insert the wires into the connector and solder. Let cool then cove with the heat shrink. At the PCM find the two 14 gauge black with tan stripe wires. They go up into the split wire cover about 10" that's were you'll find splice #S126 There are two 14 gauge black with tan strip wires coming down to the connector. One is the ground for the data link connector and the other is not used. Repeat the cut, strip and solder process as above. When done it should look like this.
No boost
Have you verified that the boost pressure on the Quadzilla is indeed 0 psi by installing a test gauge pre and post intercooler. You can install it at the fitting on the turbo for the waste gate hose for pre intercooler and at the 1/2 npt plug in the intake manifold next to the fuel filter for post intercooler pressure. O'Reilly's may have one that you can "rent" for free or you can buy one inexpensively for about $14-$30. https://www.harborfreight.com/automotive-motorcycle/diagnostics/fuel-pump-and-vacuum-tester-62637.html
No boost
Is the exhaust system blocked? If it is that would cause reduced air flow through the exhaust and over the turbo wheel.
Holy jump up and sit down!! What a mess. I'd be looking for a replacement. Take the body off, replace the floor and reinstall body. Heck no, you will never be comfortable about the quality of that trailer again. Tell them to get you a new trailer and back charge that clown in Texas for the fine "you will never have trouble with it again" repair. If they do go for a new trailer then push a little more and get a full warranty period for it.
What an evening
- Tame the manual transmission
- Want to increase turbo boost
I had the same set up you have with the boost elbow and 26psi was the best I would see and then bleed of from there to 22psi. I got rid of that boost elbow and put on a manual waste gate controller. Now I'm getting 30psi.- Everyone post a picture of your truck!
My truck on the left and JAG1's truck on the right at he camp grounds in the Sierra Nevada mountains last week. A friends Chevy truck in the background.- Power Steering Pump
It shouldn't mater. They are both return lines to the reservoir part of the pump.- P1291 With grid heats disconnected
I've been starting the engine with the grid heaters disconnected for 6 weeks with morning temps ranging from 28°-55°F with just a little white smoke and a loping idle for about 30 seconds. This afternoon, after my wife drove it this morning, the check engine light was on. I scanned the system with an OBD code reader and fond this, P1291 No temp rise from intake heaters. Monitor & Set Conditions Temperature rise from intake air heaters is monitored for first 15 seconds of engine operation. DTC may be stored if initial Intake Air Temperature (IAT) sensor reading is 0-66°F (-17.8 to 18.8°C), Battery Temperature Sensor (BTS) and IAT sensor are within 10°F of each other, time between end of preheat and engine run state is less than 30 seconds, engine is cranked for less than 5 seconds before engine starts, preheat is completed before engine starts, post-heat is active and no IAT sensor or intake air heater relay DTCs exist. This shows that a code, under the right temp conditions, can still be set with the ECM still closing the rely but the main power to the grids disconnected from the battery.- AC clutch
All the parts you need are not that much more like @dripley said and it's cheaper and more time efficient to do it right the first time.- AC clutch
You can double up the gauges to check a bigger gap, .026+.014= .040" I've pulled clutches and removed shims to adjust the gap on other compressors but I've never done one on these trucks. Yes, You would need the gap measurement, a special tool to remove the clutch disk, check the thickness of the shims to be removed with a micrometer, put it all back together, recheck the gap and and it should work or just buy a new one. The last a/c compressor I replaced was on a Chevy Suburban that I bought from O'rilly's. I don't remember what I paid for it but it still working on the customer's vehicle. I didn't buy their cheapest compressor option. When you do the job be sure to change the expansion tube, accumulator and all the O-rings.- AC clutch
What has happened is the air gap between the clutch plate and the pulley has increased due to wear. The air gap is large enough now were the electromagnet can no longer keep the clutch engaged to the pulley. You can check this air gap with a set of feeler gauges. The gap between the clutch plate and the pulley should be .016"-.031". If it is greater than this then the clutch is wore out and with the miles you have on the compressor it would be best to replace the whole unit and service the complete a/c system.- IBMobile at Mopar1973Man place
My wife and I had a great time visiting Mike and Mopar Mom. Wish we could spend more time with them in this beautiful area. We're heading to the Sierra Nevada mountains south of Carson City for a few days of fishing.- Doors
I'll be there tomorrow. We can try it then. Will need a floor jack and some 2x4, 4x4 or other blocks of wood.- Need help deciding on what color to paint the truck
Changing the paint color of a vehicle drops it's value, is seldom done right, usually looks bad after a few years, rock chips and scratches will show the under lying red paint unless you sand it down to metal and build it back up. - Tame the manual transmission
