Everything posted by JAG1
Roof Issues Anyone?????
Lazy Bones!
Tom, I'm sorry this happened to you and the wife, but I want you to get a new unit. Repairs of this magnitude render it almost worthless if the flooring is damaged enough. Their insurance should be contacted for an adjuster to come out (both insurance companies involved) and decide on the work having been done wrong by both the repair shop and the manufacturer. Those two insurance companies can hash it out, but should let you pick one of equal value off the lot soon. Don't accept this damaged unit any longer. OK?
That trailer/ camper is now a lemon since the damaged flooring goes underneath the outside walls. That's the way they all built and makes it almost impossible to rebuild or fix. I'd be looking for my money refunded and stay away from FR products.
Ready to do a fuel system
It works is all I can say.... Had some difficult prime time going on and the blow side of the shop vac down the tank throat worked. The rag can help seal the air into the tank.
I've been able to prime my fuel system using a shop vac blowing down inside the fill neck. It doesn't take very long. Just about a 3 second blast of air down the tank. May need to do it a couple times and using a clean rag to filter the air a little bit helps.
Bosch VP44 injection pump removal the fast way!
I really like the step by step presentation. Nothing like simplifying to help eliminate the fear. I'm still afraid of dropping the keyway inside the gear case..... does it fit tight or does it easily pull or fall right out if not careful? The way I get it is you just cannot bump the key when removing or replacing, so when placing the new VP how do you hold onto the VP and look in front, while your hands arms tend to wiggle to see if lined up?
That's what I mean with lack of caring for your trailer like that, why would you want those people to repair it? I would ask for what it cost them to do the work to be put in your pocket and put that toward a sheet aluminum roof. I would do it myself because I also have experienced the lack of real service and frustration it causes. Years ago I told them I did not want their crummy work and will warranty it myself. My attorney went to bat for me and got an amount returned to me to take care of the issues I was having. It was a fair amount to cover my labor and expenses. Try to get pictures of it uncovered in the rain and some after it is soaked. That would be perfect for negotiating for a new RV, but I wouldn't get one that has that shop do the work. The RV industry is so far down there.... you have to watch out for yourself.
Saying hi again
Welcome back Stranger! I remember you. Did you get side tracked over a blonde?
I would entertain the option of getting the repair cost added to my pocket and put that toward an aluminum sheet roof. May not be realistic idea though
Remaned ECM took out vp44?
Did you get a chance to look at W-Ts articles on the grounding issues? Basically it shows the factories grounding blunders in the harness.
Bouncing Around
I jumped on the KYB MonoMax since I heard a few companies with big name brands were having their products made elsewhere or were cutting back on how it used to be made. Kinda running more on the name than the old quality.
I thank you for sharing your experience. I heard the newer RVs are worse on workmanship/ quality. Wafer board is so rot prone and won't hold adhesives well. At another place I work we are framing up a tiny house. I'm in charge of the project and now can't blame folks for wanting to build their own rv since I see that may be the direction things go. I would have to take a different position on this and think about getting my money back and build my own camp trailer, Or find a real good older one. Once when younger I was crawling under some older used RVs and found one with standing seam metal clad on the bottom. It was terrific.
Bouncing Around
Do you have air bags on it? Sometimes over inflating them causes the bounce like there are no shocks at all, so I had to ask. Those Ranchos are warranteed and really should do the job of dampening the effects of the road. I also know that the adjustables get clogged up to where you can't adjust them anyway so I stayed with a non adjustable for hauling the camper, but went with the Japanese KYB MonoMax shocks. They are stiff so are better suited for loads, but not aggressive.
What an evening
I poured about a fourth of the bottle in there each treatment, that's just a guess since It may have been a half gallon bottle. What happened was I bought what I thought was good juice, but saw the ingredients had citric acid which my dentist tells me to avoid, so I tried dumping it it in the black tank and see if it made any difference. I was amazed how well it worked till the tank was emptied a week later, without any other treatment in there.
Lift Pump
Your obviously not married yet.
What an evening
Speaking of which...... I found out cranberry juice works better than RV toilet tank deordorant. It works so much better I was astonished when I had to dump twice the amount of RV black tank treatment needed to get the same results as cranberry juice when I ran out. The cranberry juice was a cheap brand with citric acid as one of the ingredients. Just so you know.... Its better for the septic an drainfield too.
What an evening
Did you warsh yer hands before getting in your truck?....... I dealt in that type fishing once.... made $2150 in a day and a half about 12 years ago
What an evening
Grease trap interceptor not functioning properly? May find a post hole digging tool handy for getting that out. Yum Yum
Cummins mistake
Price of nice second gens just went up two clicks
Tame the manual transmission
Michael, didn't you say you had a grillfriend that thought you had one like that? allways taking off in first and slamming in reverse?
Need help deciding on what color to paint the truck
That is my favorite color also. I once saw a green so dark it almost looked black. It was nice lookin', but like a black truck it showed all the dirt.
IBMobile, forgive me bud, why does your icon have to look like your running away with the ladies purse?
Bap, start checking the ECM harness connection and the VP connection. Look at all the pins/ connection points closely, that all look the same nothing distorted. Make sure clicked all the way in. Check for clean electrical connections on battery posts, everywhere you can.
Bulletproof mods
The only things I've done; Trans Temp and fuel pressure gauges. Mag Hytech Trans pan.. IBM's Mystery switch ECM housing battery ground. Timbo Apps. Vented fuel cap. Tank access plate in bed (not recommended). Greasable lower ball joints. Heavier PCM ground to firewall. Vulcan big line kit, draw straw and frame mounted lift pump / relay 2 stroke in every tank. Future mods W-T,s grounding mods.
Bulletproof mods
Oh thats too good
